j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Mon Jan 09, 2012 8:28 pm Post subject: Split Bus Dolly Jacks |
I'm building a set of dolly jacks to roll my buses around without a front beam.
I really liked Swervyjoe's setup shown here:
So, I looked to get a similar trailer jack pair to fab my own.
Picked up a pair from our favorite Chinese supplier:
They were $27 each, relatively cheap.
So, I figured I could just make up a mounting plate rather than welding like Swervyjoe did.
Logged onto emachineshop.com and with a little help from jeremyrockjock's front beam measurements, drew up a design. Then printed it out full size and checked if it was lined up OK, and if the crank handle would clear the wheel well.
Emachineshop.com is really cool, I submitted my plan, and it instantly gives a firm price quote, takes your credit card, and viola', four days later I pick up a box:
and inside:
1/4" aluminium, which I figured would be strong enough when combined with the mounting bars which come with the trailer jack. I'm running the mounting bars on one side from the top beam bolt, added a hole in the middle of the plate, and joined the other mounting bar on the other side from the top jack plate bolt.
The lowered height of the jacks is 19" off the floor for the lower beam bolt, which is about 1" higher than a stock height bus. I should be able to raise the bus up to 30" off the floor, high enough to get some real work done under there.
I'll be mounting them up later this week, I'll let you know how she works. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
turkis-deluxe Samba Security
Posted: Mon Jan 09, 2012 8:43 pm Post subject: |
Word up J.dot. Looks good but remember those jackstands!! |
Posted: Mon Jan 09, 2012 8:51 pm Post subject: |
I plan to use these instead of jackstands.
Should I be concerned? _________________ Founder and Chairman Emeritus, ECMSAS
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1888 Location: Clearwater Fl.
Posted: Mon Jan 09, 2012 8:58 pm Post subject: |
Neat!...I own swervyjoes and they are on my truck...work good!
Thanks Joe!! _________________ www.blastserv.com
wanted:
Nothing! |
dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Mon Jan 09, 2012 9:01 pm Post subject: |
j.pickens wrote: |
Should I be concerned? |
Personally, that set up gives me a bit of concern. I work in the marine industry and have lots of experience with those things. When they decide to buckle, they do so quickly. Plus, yours don't look nearly as beefy as the ones used by the other member. I would use them to CAREFULLY move my bus around in the shop, but never without adequate jack stands would I get under it.
Be safe! Cool ass idea though. _________________ 66 Riviera |
Posted: Mon Jan 09, 2012 9:11 pm Post subject: |
dreadnotmusic wrote: |
j.pickens wrote: |
Be safe! Cool ass idea though. |
Since the bus will be without front and rear suspension, I'm guessing it will weigh about 2000 pounds. That's about 500 pounds for each of the four dolly wheels. The trailer jacks are rated for 1000 pounds.
But I hear you. I'll be careful. _________________ Founder and Chairman Emeritus, ECMSAS
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10255 Location: Petaluma, CA
Posted: Mon Jan 09, 2012 10:04 pm Post subject: |
If it's just the shell, it will weigh less than 2000 pounds. |
Posted: Mon Jan 09, 2012 10:42 pm Post subject: |
campingbox wrote: |
I was just estimating.
The tech specs are for a Kombi to weigh 2400 lbs.
I was being conservative and estimating 400 lbs. for front beam, rear tranny, engine, etc.
Its good to estimate high for stuff like this. _________________ Founder and Chairman Emeritus, ECMSAS
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20906 Location: Sandpoint, ID
Posted: Tue Jan 10, 2012 12:52 am Post subject: |
j.pickens wrote: |
campingbox wrote: |
Its good to estimate high for stuff like this. |
I just scrapped a front beam minus brakes and spindles, and it was 94 pounds. A complete engine is around 240 pounds, give or take a few. Tranny is around 200 pounds with RGB's. Just FYI.
I too, have worked in the marine industry and have seen those tongue jacks buckle, but usually after some heavy use and abuse by undiscerning owners and mechanics. I think you'll be fine using them to roll around and adjust height for working on the bus, but I would use jack stands before I spent much time under them. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3504 Location: Anderson SC
Posted: Tue Jan 10, 2012 6:20 am Post subject: |
very nice. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12556 Location: Over 2002 posts deleted!
Posted: Tue Jan 10, 2012 7:30 am Post subject: |
Like your idea but I would rather weld up the "tube" to the plate WITHOUT the rotary part!!! That's the "weak" point of it and you really don't need it for the intended use!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Tue Jan 10, 2012 7:42 am Post subject: |
pyrOman wrote: |
Like your idea but I would rather weld up the "tube" to the plate WITHOUT the rotary part!!! That's the "weak" point of it and you really don't need it for the intended use!  |
There are two available holes which can bolt the swivel part to the mounting plate. Already planned to do this. You can see the four inner holes here, two which engage the quick release, and two available for more permanent bolting togetherness. If I get the time, I may remove the quick release pins and put four bolts in.
Posted: Tue Jan 10, 2012 7:50 am Post subject: |
cdennisg wrote: |
I too, have worked in the marine industry and have seen those tongue jacks buckle, but usually after some heavy use and abuse by undiscerning owners and mechanics. I think you'll be fine using them to roll around and adjust height for working on the bus, but I would use jack stands before I spent much time under them. |
Sounds right, that's the approach I'll take. _________________ Founder and Chairman Emeritus, ECMSAS
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Tue Jan 10, 2012 3:03 pm Post subject: |
cru62 wrote: |
Thanks for the heads up about http://www.emachineshop.com/ . That is a pretty awesome site. Check out the videos. It looks easy for simple parts. |
I too played with it last night and made some wheel adapters I need and they were 276.00 each! I passed. what did you pay for those plates? cool site and idea _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
Posted: Tue Jan 10, 2012 3:15 pm Post subject: |
They were $42 each plus shipping.
Their price for machining steel is much higher than aluminum.
Probably because aluminum uses a computerized router instead of a true cnc milling machine. _________________ Founder and Chairman Emeritus, ECMSAS
my65vert Samba Member
Joined: November 09, 2003 Posts: 6187 Location: Middleburg, Florida
Posted: Tue Jan 10, 2012 4:18 pm Post subject: |
I have also buckled a couple of those while attached to car trailers. The higher you go the easier they buckle, fully lowered or just up a bit shouldnt be an issue but I wouldnt use them at full lift. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
Posted: Thu Jan 12, 2012 6:03 pm Post subject: |
OK,
Went up to Rusthaven to mount the new dolly jacks on the sunroof swivelseat. They fit up very nicely, only had to file two holes to get the bolts into the mount points. I removed the spring folding assembly and put four bolts around the swivel assembly to firm it up.
Here's the results, and yes, the crank handle clears the wheel wells:
Posted: Thu Jan 12, 2012 6:14 pm Post subject: |
Cool. Looks like they will do the trick. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
UZI Platinum FUBU
Joined: February 08, 2002 Posts: 13335 Location: phila-DELFT-ia
Posted: Thu Jan 12, 2012 7:03 pm Post subject: |
do the wheels lock? _________________ Extravagant Lifestyle
Quote: |
mannys66: South Philly Van Club, only the most influential and freshest van club in the vw scene |
Quote: |
Cuñado: Chrome will get you home!!!!!!!!!! |
