AlteWagen Troll
Posted: Sun Feb 28, 2010 1:19 pm Post subject: Type 181 / 126 - Industrial heater box delete tin |
In another thread about sled tins and their importance in engine cooling the topic of "j tube" tin was brought up. I started this thread to make it easier to find when searching.
In order to direct the spent cooling air out the back of the car the sled tin and heater boxes must be in place. If the heater boxes are removed the spent air goes out the sides of the tin instead of to the rear of the car. Type 181 (thing/safari) with gas heaters and industrial engines did not have heater boxes but still needed to direct the air away from the engine. VW used these small tins to box in the sled tin as the heater box once did.
Below is a pic of the tin and a drawing with dimensions so you can make your own.
Dimensions:
Right
Left
[/quote]
Drawings not to scale |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80410 Location: Sneaking up behind you
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Sun Feb 28, 2010 1:43 pm Post subject: |
These tins were factory installed on 1500 engines and 1600 engines in a Type 181/Thing without heater boxes and on all Type 126 industrial engines. _________________
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Glenn  Mr. 010
Posted: Sun Feb 28, 2010 1:50 pm Post subject: |
| Chad1376 wrote: |
| What secures the outside edge of the tin? It looks like it could create an irritating rattle/buzz. |
Nothing..... I twisted the sleds so they apply some pressure to the shields and are held tightly against the heads.
They do not rattle. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
durfeec Samba Member
Posted: Fri Feb 03, 2012 11:34 pm Post subject: |
Glenn, have you tested temps with and without these tins? First time I have ever heard of these. I am running j-tubes on my bus but right now its winter so I'm not concerned with overheating but when summer comes and I move out west, I'll be driving in heat and will be concerned. _________________ 1960 Bus Panel/Camper |
Glenn  Mr. 010
Posted: Sat Feb 04, 2012 4:36 am Post subject: |
I've only run my engine with them. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Feb 04, 2012 1:32 pm Post subject: |
ok. looks like ill be making them when it starts to warm up. thank you. _________________ 1960 Bus Panel/Camper |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4005 Location: SANDY VALLEY, NEVADA
Posted: Sat Feb 04, 2012 4:28 pm Post subject: |
As soon as we get the water jet set back up I will be making a few sets from stainless.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Lucatero Samba Member
Posted: Sun Feb 05, 2012 11:32 am Post subject: |
I hear alot about Jtubes and I am not sure what people are talking about, as I am have not owned aircools very long. I have a 64 with heater boxes and I a have a 71 without. It has aftermarket exhaust and have simaler tubes as the pic below, but tucked up closer to the head. Are the J tubes the tubes that connect to the exhaust and are running alongside the head? _________________ 64 Beetle Type 1/Totaled
64 Beetle Type 1/Totaled after owning 5day!
71 Beetle Type 1
70 Karmann Ghia |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Sun Feb 05, 2012 11:37 am Post subject: |
J-tube:
_________________ (3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's |
Altema Samba Member
Joined: June 20, 2010 Posts: 2907 Location: Lower Michigan
Posted: Sun Feb 05, 2012 11:38 am Post subject: |
| Lucatero wrote: |
| Are the J tubes the tubes that connect to the exhaust and are running alongside the head? |
Yes, that's them.
Paul |
Posted: Sun Feb 05, 2012 11:52 am Post subject: |
Thanks for the speedy reply, those are in place, now I just need to put the pieces of tin on the sled and box it in to make it complete. _________________ 64 Beetle Type 1/Totaled
71 Beetle Type 1
70 Karmann Ghia |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17667 Location: Left coast, Canada
Posted: Sun Feb 05, 2012 12:41 pm Post subject: |
| durfeec wrote: |
| Glenn, have you tested temps with and without these tins? First time I have ever heard of these. I am running j-tubes on my bus but right now its winter so I'm not concerned with overheating but when summer comes and I move out west, I'll be driving in heat and will be concerned. |
Howard Washington reported a 10ºF oil temp drop by installing a sheet metal shield between the J tube and the pushrod tubes. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Sun Feb 05, 2012 8:12 pm Post subject: |
| Bruce wrote: |
| durfeec wrote: |
Howard Washington reported a 10ºF oil temp drop by installing a sheet metal shield between the J tube and the pushrod tubes. |
wow. thank you. _________________ 1960 Bus Panel/Camper |
AlteWagen Troll
Posted: Tue Feb 07, 2012 3:24 pm Post subject: |
| Bruce wrote: |
| durfeec wrote: |
Ive noticed that there is no more burnt oil in the tubes when running the industrial tins, evidence that it was heating the oil when going back into the case from the heads |
chrisdiehl Samba Member
Joined: October 10, 2011 Posts: 183 Location: middle ga
Posted: Tue Aug 14, 2012 7:07 pm Post subject: |
| I'm glad I ran across this. I installed j tubes a couple of weeks ago and hadn't heard of these sleds until now. Stupid question.....engine doesn't have to be out to install right? |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Tue Aug 14, 2012 7:28 pm Post subject: |
Right _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
| modok wrote: |
| I am an expert at fitting things in holes, been doing it a long time |
Posted: Wed Aug 15, 2012 1:36 pm Post subject: |
| chrisdiehl wrote: |
sleds are used even with factory heater boxes. they are what protect your push rod tubes. and it would be easier to install with the motor out since they bolt to the backside of the cylinder head tin. the tin that this thread is about is something different than just a sled and can be installed without removing the motor. _________________ 1960 Bus Panel/Camper |
Posted: Tue Aug 21, 2012 4:52 am Post subject: |
Just as a note, next to Glenn´s Berg header, I just found out thtat CSP Python fits with original 1600 engine sled tins and industrial tins too! _________________
|82x94|
