February 1962 Type 34 Ghia junkyard rescue - build thread
Page: 1, 2, 3, 4, 5, 6  Next
thom
thom is offline
PostPosted: Mon Feb 13, 2012 7:54 pm    Post subject: February 1962 Type 34 Ghia junkyard rescue - build thread Reply with quote
This is the build thread for my 1962 Type 34 Karmann Ghia, # 18896 with matching engine #14504 (I have some catching up to do)
This car was originally pulled out of a junkyard in Fairfield in 1998 by Larry Edson & Richard Troy. Larry had collected a zillion parts for it over the years, a lot of them NOS, but finally decided it was time to let it go.
Here's a picture with Richard Troy following the forklift out of the yard.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 7:56 pm    Post subject: Reply with quote
Initial evaluation:
The little thermostat dealy has been nicked
Started digging out some of the bondo
Taking a good hard look at some of the damage
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
Doesn't look too bad; there's a little bit of rust, but I knew that when I bought the car.
Hmm. It's a little worse than I thought
Holy mother of god, that's a lot of bondo! It was over 1/2" thick in places.
What's even better is the dark grey stuff at the bottom isn't bondo. I was heating it and it wouldn't budge, and it smelled really bad, but familiar. It's JB-Weld!.
We're gonna need a bigger repair piece.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 7:57 pm    Post subject: Reply with quote
I pulled the oil sump plate. Ick. Lots of chunks, but it seems to be petrified dirt; the chunks crush easily in my fingers. I don't think I'm going to be able to just jump in and drive this one.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 7:58 pm    Post subject: Reply with quote
I swapped in the 009 from my panel, and a spare 6v coil I had laying around, new plugs and wires, and after much futzing, I finally got it running. It doesn't run well, but there's no expensive noises. If I heard a car running down the street that sounded this bad I'd pre-dial AAA for the poor guy. Compression on 3 & 4 was only ~80-90lbs, 1 & 2 ~100-15lbs. It has that kerflufflel sound like a head wants to fall off.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 7:59 pm    Post subject: Reply with quote
Here's something you don't see every day - original, solid axle boots. They've more than likely never been changed
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 8:01 pm    Post subject: Reply with quote
Blasted off some of the rust and bondo
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 8:02 pm    Post subject: Reply with quote
Further dismantling of my T34. Trying to get the dash pads off was trying at best. I pre-soaked the fasteners with penetrating oil, took a small brush and cleaned the threads as well as I could reach, knowing that too much torque would rip the stud right out. I'm trying to be super-surgical-careful, but all of the studs on the top pad were turning. I lifted gently upwards, and the entire thing popped off in two pieces. Judging by the oxidation of the foam, it's been in two pieces for quite a while, and it looks like the studs shuffled off this mortal coil decades ago. The dash also has a rich Corinthian leather overlay which has been fun to peel off.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
Disassembled the rest of the dash over the past couple of days. When the weather clears up, I'll blast some of the problem areas.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 8:03 pm    Post subject: Reply with quote
Did some more blasting today. Looks like I'm going to need to section in a good-sized chunk of the passenger-side floor pan.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
This is going to be one of my biggest challenges. Note how the door frame is pushed inward w/r/t the other side. This poor thing took a pretty good hit at some point. The door is full of bondo. I have a replacement door, but I haven't tried fitting it yet.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 8:05 pm    Post subject: Reply with quote
Pushed out my passenger-side B pillar a little. I need to straighten out the inner structure so the fender can go back where it is supposed to be. I could really use a new section, as this one is pretty hammered. I have one of the repro sections, but that won't begin to cover it.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
Got my engine torn most of the way down.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 8:06 pm    Post subject: Reply with quote
This is exactly how it looked when I pulled the valve cover off.
One of these things is not like the other.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Feb 13, 2012 8:07 pm    Post subject: Reply with quote
I've cleaned the heads up a little bit, and found some trauma from a previous life. My guess is they either sucked a valve or some other FOD.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
notchboy
notchboy is offline
PostPosted: Mon Feb 13, 2012 9:30 pm    Post subject: Reply with quote
Glad to see it all here Thom Applause
Now I need some
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
EatACactus
EatACactus is offline
PostPosted: Mon Feb 13, 2012 9:45 pm    Post subject: Reply with quote
I'll be keeping an eye on this one! Great progress so far!
'73 Squareback Bodydrop Build
11th Hour Industries
View user's profile Send private message Visit poster's website Facebook Classifieds Feedback
FASTBACKDON
The other insensitive jerk like Neil
FASTBACKDON is offline
PostPosted: Mon Feb 13, 2012 10:52 pm    Post subject: Reply with quote
Great save Thom I am glad to see you saved the car it deserves you
Keep up the good work.
FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult.
Bobnotch
Bobnotch is offline
PostPosted: Mon Feb 13, 2012 10:56 pm    Post subject: Reply with quote
Now we can see the real progress. Twisted Evil Nice to see it all in 1 place. Cool You're going to find you'll get more comments on the car this way. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
gt1953
gt1953 is offline
PostPosted: Tue Feb 14, 2012 7:06 am    Post subject: Reply with quote
Rare car and even rarer guy doing it best of luck.
72 type 1
72 Squareback
Page 1 of 6
