Fuel Injection Diagrams Collection FAQ
Mal evolent
Mal evolent is offline
PostPosted: Sat May 26, 2012 9:51 am    Post subject: Fuel Injection Diagrams Collection FAQ Reply with quote
To link to this thread copy and paste
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=513607&start=0&postdays=0&postorder=asc&highlight=]Fuel Injection Diagrams Collection FAQ[/url]
1978 FI System:
FI Wiring simplified:
AFM (air flow meter)
7 pin AFM
From AMSkeptics Double Relay Tutorial
Double Relay simplified
Double Relay Ignition on, engine off:
Double Relay Start:
Double Relay Run:
Double Relay Wire Colors:
Double Relay Plugs:
White wire is a bonus wire found on a 79 Calif?
The Fuel Flow
Injector Leak Down Test
______________________________________________________________________________________________________________________
--VACUUM HOSE DIAGRAMS
Vacuum Hoses 73-74 Carbureted
Vacuum Hoses 75
DVDA
SVDA
Vacuum Hoses to 76 1/2
Vacuum Hoses to 76 1/2 with EGR
Vacuum hoses 76 1/2 to 79 Federal:
Vacuum hose 75-76.5 and 79 CA models DVDA
From RATWells vacuum hose page
Vacuum Hoses 1
Vapor Hoses Overview
Vapor hoses T:
Aux Air regulator:
vapor hoses to carbon canister:
Pressure Regulator:
SVDA:
Breather and Decel valve:
ECU CONTROL UNIT BLOCK DIAGRAM:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8575116#8575116
"The Bosch L-Jetronic Technical Instruction manual has a really good overview on that. You can find it as a PDF online and read pages 16 and 17 for more info, but it all boils down to this diagram and the fact that a basic injector time is calculated and then corrected by a given factor that is a combination of the engine condition read from the sensors."
http://www.cardiagnostics.be/-now/Educational_site...Manual.pdf
"The best block diagram of an L-Jetronic ECU I've found does not come from Bosch, but from a 1977 Datsun 280Z manual. It's for 6 cylinders, but the logic is exactly the same (just think 4 cylinders and engine temp instead): "
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
Collie
Collie is offline
PostPosted: Sat May 26, 2012 9:53 am    Post subject: Reply with quote
Now THATS a sticky candidate right there!! Applause
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Sat May 26, 2012 10:24 pm    Post subject: Reply with quote
As always, AWESOME work! Applause
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
timo78
timo78 is offline
PostPosted: Sun May 27, 2012 9:06 am    Post subject: Reply with quote
Nice collection, thank you for compiling these together.
Green Bay Bus > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it?
curtis4085
curtis4085 is offline
PostPosted: Sun May 27, 2012 9:39 am    Post subject: Reply with quote
Great work gathering the info. One suggestion would be to post the key as well so others can know what the letters mean.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
onion456
onion456 is offline
PostPosted: Sun May 27, 2012 5:18 pm    Post subject: Reply with quote
found this one in the gallery thought it was cool...
i have some stuff on my other computer too ill try n dig it up.
'76 Sage Green Westy 2.0 FI
'76 Creamsicle 7-passenger 2.0 CS FI
'85 Tan Westy
Wildthings
Wildthings is offline
PostPosted: Sun May 27, 2012 6:09 pm    Post subject: Reply with quote
Looks like D-jet and not L-jet. Crying or Very sad
Wildthings
PostPosted: Sun May 27, 2012 6:16 pm    Post subject: Reply with quote
I find the schematic for the FI shown in the standard current track diagram to be the most helpful. Just separating out the FI part of the standard drawing would be quite helpful.
Another thing that would be great to have would be a trouble shooting chart similar to what the Vanagon Bentley has. It takes almost no thought to use the Vanagon chart, whereas using the info in the Bay Window Bentley can be trying.
onion456
onion456 is offline
PostPosted: Sun May 27, 2012 6:44 pm    Post subject: Reply with quote
dang, wasnt sure bout that air cleaner =)
heres a few more, probably raped from ratwells, ive found em useful.
85 - Ground
86 - Thermo time switch and ECU pin 4
86a - Starter
86b - AFM harness connector #36
86c - Terminal 15 of ignition coil (+12v)
88a - AFM harness connector #39
88b - Series resistors and ECU pin 10
88c - Aux air regulator
88d - Fuel Pump
88y - Battery +12v
88z - Battery +12v
'85 Tan Westy
SGKent Premium Member
SGKent is offline
PostPosted: Sun May 27, 2012 11:59 pm    Post subject: Reply with quote
really nice but too bad you didn't post it in the FI sticky so everyone can find it 2 years from now.
George Carlin:
Skills@EuroCarsPlus:
Tcash
Tcash is offline
PostPosted: Mon Oct 14, 2013 8:29 pm    Post subject: ECM diagram, schematic, pin out Reply with quote
78 Calif. ECU Schematic/thanks ratwell
ser123ser
ser123ser is offline
PostPosted: Thu Nov 21, 2013 8:07 pm    Post subject: Reply with quote
OMG".......
I have seen a lot of this back in 2011 when I built my motor and fi system, just Ina lot of different places. Now it is all in one place.
Outstanding "..........
74Pepper
74Pepper is offline
PostPosted: Tue Jan 21, 2014 4:38 pm    Post subject: Reply with quote
I think I just wet myself....I was hearing angels and harps flipping through these images! Converting back to FI from scrounged parts just got that much easier!
Thank you, thank you, THANK YOU! Very Happy
'66 Beetle, in restoration
'74 Ghia, in restoration
'77 Westfalia Campmobile - Dangit - rear-ended! Now has primer-butt!
Per Gary, A.K.A. "Purple dress girl")
russwiththebus
russwiththebus is offline
PostPosted: Tue Jan 21, 2014 7:31 pm    Post subject: Reply with quote
I love it! Some I've seen, some I hadn't. Nice to have them all in one place!
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Tcash
Tcash is offline
PostPosted: Thu Mar 13, 2014 10:09 am    Post subject: FI Daigrams Reply with quote
HerrMahnenschmidt
HerrMahnenschmidt is offline
PostPosted: Fri Jun 20, 2014 8:32 am    Post subject: Reply with quote
Would it be unseemly to say -- I love you all? This thread is so beautiful I have to choke back the tears...
1977 Westfalia --
- rebuilt stock-spec 2.0l FI engine; 002 tranny w/stock gearing with 215mm flywheel/clutch/pp
Tcash
Tcash is offline
PostPosted: Sun Dec 07, 2014 3:36 pm    Post subject: Reply with quote
73 Vacuum hose diagram
Wildthings
PostPosted: Sun Dec 07, 2014 6:16 pm    Post subject: Reply with quote
Shouldn't the one hose to the charcoal canister tie into the fan shroud and not the air cleaner?
Tcash
Tcash is offline
PostPosted: Sun Dec 21, 2014 8:52 am    Post subject: Reply with quote
Thanks Wildthings. I deleted the diagram.
Tcash
Tcash
Tcash is offline
PostPosted: Sat Feb 07, 2015 11:44 am    Post subject: Early EGR Temperature Switch Reply with quote
In the fuel injection section. Temperature switch Prt# 022 131 519.
Could not find a diagram with it.
I drew this one in. I would think it goes here, to not allow the EGR to operate when the engine is cold.
Tcash
