pdxeuro Samba Member
Posted: Sun Jun 03, 2012 2:03 pm Post subject: Seat recliner dis-assembly? |
I'm curious if these are worth pulling apart to clean up and repaint? They seem like they can be tricky to put back together and I'm worried about breaking or messing up the pins on the inside.
1) Has anyone taken these apart?
2) is there a procedure listed anywhere (I've searched high and low to see)?
3) If not worth taking apart, should I tape off and spray and then paint brush the small parts to avoid gooing the mechanism up?
Thanks for any help
[/img] _________________ ----------------------------------------
Portland, Oregon
1991 Westy MV
1959 Bug
1977 Westy Bus - sold
1968 Bug - sold
2002 Eurovan - sold |
ryohey Samba Member
Joined: August 08, 2007 Posts: 562 Location: Plains, PA
Posted: Sun Jun 03, 2012 2:31 pm Post subject: |
I wouldnt do it. The pin is tough to get out. I did it to an old set I had and its a pain. just rough it up as best you can, prime and paint. it wont gum up the mechanism if you paint it. _________________ 69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight= |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26534 Location: Douglas, WY
Posted: Sun Jun 03, 2012 2:48 pm Post subject: |
The 61-65 Bentley talks about it briefly, but it only just shows them using a punch to drive that pin out, and not really anything else. I'm not sure if the later seats are much different from the older ones, I can't recall ever taking the later ones apart before. |
Posted: Sun Jun 03, 2012 9:51 pm Post subject: |
Thanks! Does anyone know what the flat disk with the tab sticking up (the tab has the middle hollow) is used for? I can't figure out the purpose. _________________ ----------------------------------------
Portland, Oregon
1991 Westy MV
1959 Bug
1968 Bug - sold
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Mon Jun 04, 2012 7:54 am Post subject: |
Just went thru that with my Ghia Vert build. Someone had beat the heck out of the back of the seats and bent in the seat tube and binding up the rod for the seat back release. It is not hard to do, just have to study how it works and reassemble. There are 2 rods or tubes that go thru there one is for the seat back release attached to the pieces you asked about and 1 for the seat back angle adjuster. The pins that hald the angle adjust is really a screw nail and will come out easily enough. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Posted: Fri Jul 27, 2012 8:50 pm Post subject: |
So, I finally broke down and took apart a set of these seats. The hardware is pretty straight forward if you look at it before taking it apart. The hole just opposite of the nail head is for a punch (or in my case I sawed off the point on a thin long nail). Just insert and hammer that screw-pin out. I left the spring in it's normal spot. Notice the grey cap in the middle - it goes on top of the spring.
FYI in case anyone tackles this in the future
Portland, Oregon
1991 Westy MV
1959 Bug
1968 Bug - sold
type241 Samba Member
Joined: June 02, 2006 Posts: 1013 Location: MOSES LAKE, WA
Posted: Thu Feb 12, 2015 10:03 am Post subject: Seat Recliner pieces |
Is there a source for the grey cap(mine is white plastic) that goes on the spring? If it gets worn the adjuster dimples dont work well. |
joemama Samba Member
Joined: February 09, 2006 Posts: 1667 Location: La Crescenta, California
Posted: Thu Feb 12, 2015 4:01 pm Post subject: |
Not to hijack this thread, but, just how does this work? I try turning the knob and it wont turn. Maybe its because I have the seat back off, but I cant budge the knob. |
Matt1972 Samba Member
Posted: Thu Feb 12, 2015 6:17 pm Post subject: |
I too am now dealing with this......my whole assembly has fallen apart and cannot get it to stay together......both ends just keep falling off.
What holds all of it together on the seat?
Was thinking of just welding (jb or otherwise) it together but then would lose the function of moving seat forward to access rear seat.....
sorry to hijack as well but this actually just came up today. |
Posted: Fri Feb 13, 2015 7:04 am Post subject: |
I am in the process of tearing my seat frames totally apart so I can powdercoat them. I will get pics soon. As far as removing just RE-read this thread.
There are two tubes inside the seat frame tube.
- One tube has the adjuster knobs held on by the 2 inch long spiraled nail. Once you remove the nail it takes some beating to get them off. On the inside face of the knobs is the spring with plastic cap the indexes the four positions of adjustment in the side of the seat frame(4 dimples).
- The other tube has the plates press fit on the end. |
Posted: Fri Feb 13, 2015 11:03 am Post subject: |
vamram  Samba Member
Posted: Fri Feb 13, 2015 11:46 am Post subject: |
Thanks for doing this thread, it's very helpful to me. I plan on re-upholstering the seats on my '72 Super in about a month and will need to take apart the driver side mechanism because it does not work properly. I have to manually reach over to one of the hinges to align it while pulling up on the backrest button. I'm not sure if a link is missing or one of the sprockets is bent, pin is broken, or any combo of the above, etc. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Posted: Fri Feb 13, 2015 2:25 pm Post subject: |
Thanks as well - my seat did not have the spiral nail at all - now I know why it keeps falling apart!
Something to work on this weekend - in addition to the 1K other things. |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Fri Feb 13, 2015 2:28 pm Post subject: |
easy to take apart.
I took mine apart to re-weld the grooves that were dug into the seat reclining cam. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
jmr1234 Samba Member
Posted: Thu Nov 14, 2019 9:10 pm Post subject: |
pdxeuro wrote: |
How does the recline feature work, do you need to lift the seat back forward and rotate the knob to a new flat? Mine are both seized and will not turn. What is the purpose of the spring and cap, is it just a detent so that you know you are properly rotated to a flat? I think if something is jammed it's probably the spring or the pivot shaft. I'll try to take it apart, I just pulled out the drivers seat. The passenger seat is stuck on the tracks but nothing works on that one. |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Sun Nov 17, 2019 3:05 am Post subject: Re: Seat recliner dis-assembly? |
Mine were sticky so I just oiled them. _________________ '72 Beetle |
Posted: Mon Nov 18, 2019 8:02 pm Post subject: Re: Seat recliner dis-assembly? |
Took the non functioning recliners apart by removing the spiral nail. wiped and greased each part and they work great now. |
buggyrider Samba Member
Joined: November 03, 2013 Posts: 62 Location: Danville, CA
Posted: Fri Nov 29, 2019 7:01 pm Post subject: Re: Seat recliner dis-assembly? |
jmr1234 wrote: |
jmw, can you please defined "works great"? I'm not sure what the seat adjuster cam is supposed to do. On both my passenger and driver seat, it is frozen in one position (although the catch that allows the seat to push forward rotates as expected). Is the purpose of this to change the angle of the seat? Or is the purpose to enable the seat to tilt forward so that rear passengers can get out (it's hard for passengers in the rear to operate the release mechanism on the side of the backrest, maybe this is an easier way to do that)?
If the purpose of this adjustor cam is to change the angle of the seat, I'll just leave it, as since the seat angle is fine. If to enable the passengers in the rear to push the seat forward, I'd probably address it since that is a continued difficulty.
This is a 1972 Super Beetle convertible.
Thanks!
Toby
hulk72 Samba Member
Posted: Sat Jan 18, 2020 8:40 am Post subject: Re: Seat recliner dis-assembly? |
PDxEuro and Type241, thank you for the info and pics. I need to find the plastic spacer/component for the adjustment group. The black plastic piece that gets sandwiched in between the metal parts...Does anyone know this part name/number? Where to source? |
kd69bug Samba Member
Joined: December 24, 2019 Posts: 109 Location: Pennsylvania
Posted: Sun Feb 23, 2020 5:24 am Post subject: Re: Seat recliner dis-assembly? |
Does anyone know where to get the spring cap?
...or what would work as a substitute?
I tried the clicker from a couple old ball point pens but none fit...
Thanks
