Alternator stand gasket
BestCoast
BestCoast is offline
PostPosted: Sun Sep 09, 2012 2:46 pm    Post subject: Alternator stand gasket Reply with quote
Took off my alternator stand and got confused. There are 0 gaskets existing so i dont know where to put it.
BestCoast
PostPosted: Sun Sep 09, 2012 2:46 pm    Post subject: Reply with quote
Above or below this plate?
Joey
Joey is offline
PostPosted: Sun Sep 09, 2012 2:52 pm    Post subject: Reply with quote
I always use two and put the metal baffle in between the two.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
Cusser
Cusser is offline
PostPosted: Sun Sep 09, 2012 2:53 pm    Post subject: Reply with quote
Same here.
BestCoast
PostPosted: Sun Sep 09, 2012 3:04 pm    Post subject: Reply with quote
Thank you. Will go buy a 2nd one now :/
jgrexx
jgrexx is offline
PostPosted: Sun Sep 09, 2012 3:16 pm    Post subject: Reply with quote
you dont' need two. in fact you really don't need any. all you need is a new metal piece. they are a crush style washer.
..but you can use just one of the gaskets. put it on top of the metal piece. that's what i have right now and no leaks.
1970 Baja Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=520964&postdays=0&postorder=asc&start=0
wbrown45
wbrown45 is offline
PostPosted: Sun Sep 09, 2012 3:57 pm    Post subject: Reply with quote
I use only the metal gasket (installed in the correct orientation) with Loctite 518, or any non-silicone sealer you prefer. I have never had one leak in the hundreds I have installed over the years.
OK Thang
Q-Dog
Q-Dog is offline
PostPosted: Sun Sep 09, 2012 4:22 pm    Post subject: Reply with quote
No gaskets needed because the metal baffle has a crush ridge on it and is supposed to be non-reusable. That's why you always get one in a complete gasket set. But if you do reuse the baffle, then you should probably use 2 gaskets and maybe a prayer it won't leak.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Sep 09, 2012 4:24 pm    Post subject: Reply with quote
The Elring kits i get have 2 gaskets and the baffle.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
BestCoast
PostPosted: Sun Sep 09, 2012 5:05 pm    Post subject: Reply with quote
Oh damn crush style :/ i plan on reusing that crush washer thing and made a 2nd gasket out of cork material
Think shell be ok?
jgrexx
jgrexx is offline
PostPosted: Sun Sep 09, 2012 5:40 pm    Post subject: Reply with quote
yeah should be fine. will probably be better. those normal gaskets are just cardboard paper. cork is better than that.
1970 Baja Bug
saucerman
saucerman is offline
PostPosted: Sun Sep 09, 2012 7:25 pm    Post subject: Reply with quote
Nothing to do with gaskets really, but why not take the opportunity to replace the Alternator studs with bolts so the stand can be unbolted and slid forward in the event you ever have to replace the Alternator and don't want to or have time to remove the entire engine.
Someone told me that a while back and it ended up really helping me.
70 Beetle (1776 MoFoCo)
68 Bus (1600DP)
02 Beetle
I have my Bus, my backpack full of food and my AK47...bring on the Zombies!
BestCoast
PostPosted: Sun Sep 09, 2012 8:10 pm    Post subject: Reply with quote
That sounds like an awesome upgrade, i had no idea about it.
jgrexx
jgrexx is offline
PostPosted: Sun Sep 09, 2012 8:27 pm    Post subject: Reply with quote
or make it a baja and you can remove the whole fan shroud and alternator by removing 2 bolts. 1 on each side of the fan shroud. lol
makes things very simple to work on. no engine removal or difficult ways of removing stuff. Razz
1970 Baja Bug
