das20v Samba Member
Joined: July 04, 2006 Posts: 151 Location: Garden Grove, Cali USA
Posted: Fri Mar 08, 2013 12:58 pm Post subject: '52 Panel scale model |
Hi guys, I am doing a ground-up scale model project on an early (1950~1952) Panel Barndoor (check back often for progress). I will do a 3D print in 1/16th scale and then strip it down to cast copies in resin/vacu-form and photo-etch.
So far, I would like to thank the following individuals for measurements/dimensions, I couldn't do it without your help:
Capriacci
RockStock
2Pack
Gustav Petri
Carl L.
Also thanks for everyones input, it keeps me inspired. Please let me if I forgot YOUR name on the appreciation list I am compiling.
das20v Samba Member
Posted: Fri Mar 08, 2013 3:15 pm Post subject: Rear engine lid |
This is a sample of the rear engine lid. I did this in Solidworks, and the output will be 1:16 scale. The sheet metal thickness is thick (0.320" in real life size), but will end up being about .020" thick in 1:16 scale due to model building materials and strength required. I appreciate any help I can get, this forum is a wealth of info for this project already, so I'll try not to bother everyone with questions too often.
2Pack Samba Member
Joined: September 20, 2005 Posts: 813 Location: Virginia
Posted: Fri Mar 08, 2013 3:53 pm Post subject: |
So you're 3D printing a bus? Bad ass. The bus pictured is a '53 which you probably know. Alot of the details will be different from a 50-52, but the dimensions you asked for should be ok. Except the horn button would be a little lower on the early buses. _________________ Please buy my Treasure |
das20v Samba Member
Posted: Fri Mar 08, 2013 3:59 pm Post subject: 1953 |
I am a Barndoor newbie as far as correct details, so I appreciate the pointers.
The project will be multi-media. Some 3D printing, some vacu-forming, some resin casting and some photo-etch parts. I plan to master the parts in 3D CAD first, then I can disect the assemblies into managable parts with the various methods I mentioned. It will be a long-term project due to the complexity, and the fact that I want to "get it right". I will post progress pics as I go.
Thanks. |
RockStock Samba Member
Joined: November 26, 2004 Posts: 4237 Location: England
Posted: Fri Mar 08, 2013 4:12 pm Post subject: |
Looks interesting
A1 is 445mm _________________ -StockRocks- |
das20v Samba Member
Posted: Fri Mar 08, 2013 4:14 pm Post subject: |
| Awesome, Ill get started on the Steering wheel now! Thanks! |
exciter Samba Member
Posted: Fri Mar 08, 2013 6:34 pm Post subject: |
Very cool!!! _________________ Joe
419-236-9781 |
2Pack Samba Member
Posted: Fri Mar 08, 2013 8:24 pm Post subject: |
B1 11.0 inches
B2 9 3/4 inches
B3 6 15/16 inches
*Edit* I had B2 and B3 switched _________________ Please buy my Treasure |
das20v Samba Member
Posted: Sat Mar 09, 2013 1:05 am Post subject: |
| RockStock & 2Pack...thank you! |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 892 Location: Cornwall, UK
Posted: Sat Mar 09, 2013 2:34 am Post subject: |
Very cool!
What type of barndoor are you making? Panelvan? Kombi?
Guess it's not a deluxe as you want the non-deluxe dash
Gustav Petri Samba Member
Joined: December 26, 2004 Posts: 140 Location: NORWAY
Posted: Sat Mar 09, 2013 2:37 am Post subject: |
C1 305mm
C2 438mm
C/c screw on handle longest 412mm
C/c screw on handle shortest 35mm
Handle tube outer dia 18mm |
Posted: Sat Mar 09, 2013 9:24 am Post subject: |
D1 looks like its 70mm. _________________ -StockRocks- |
das20v Samba Member
Posted: Sun Mar 10, 2013 11:38 pm Post subject: |
| Lowdown Dirty Rat wrote: |
Very cool!
Doing a panelvan first, then maybe a Kombi or Deluxe later. |
Posted: Mon Mar 11, 2013 2:29 am Post subject: |
Here's an idea.
Do it all in 3d printing.
You can now get a home 3d printer for just under £1000 and they are coming down all the time. If you were willing to share your schematics for a small price, or maybe as a thank you for those who helped. Then I for one would buy a 3d printer just to make one. Looking at the quality of your engine lid, its superb.
Offer that insentive and you'll have barndoor owners at your beckoning call ready to give you the correct dimensions for every washer, nut and bolt
A 3d resin print schematic for a barndoor would be amazing!!!!!
Checkout this video of a sand beast that can basically walk out of a 3d printer. How cool! Now imagine a barndoor
2Pack Samba Member
Posted: Mon Mar 11, 2013 9:13 am Post subject: |
I should clarify that the B2 value I gave above is measured to the vertical surface that the grab bar is mounted to. _________________ Please buy my Treasure |
das20v Samba Member
Posted: Mon Mar 11, 2013 10:37 am Post subject: |
| 2Pack wrote: |
| I should clarify that the B2 value I gave above is measured to the vertical surface that the grab bar is mounted to. |
Thanks 2Pack! Info updated |
das20v Samba Member
Posted: Mon Mar 11, 2013 4:21 pm Post subject: Steering Wheel |
How does this look everyone?
I still need the dimension from the steering column (floor to top of wheel), then I can add the column to this. Need the ØOD of the column too.
2Pack Samba Member
Posted: Mon Mar 11, 2013 8:17 pm Post subject: |
That looks awesome!
I don't know how far you want to go with the details, but you may want to pick a production date. The steering tube for example was skinny, then fat in '51, then skinny again as I read on here somewhere. _________________ Please buy my Treasure |
OvalinAz Samba Mini Tech
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Mon Mar 11, 2013 9:44 pm Post subject: |
I have an accurate stl file of the semaphore switch knob I can post to you, if it helps.
Here it is in actual size getting printed on my Thing-O-Matic:
_________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
