It's hardly ever...
sb001
sb001 is offline
PostPosted: Sun Sep 29, 2013 7:17 pm    Post subject: It's hardly ever... Reply with quote
vacuum leak
fuel filter
battery.
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
JONSMITHBUG
JONSMITHBUG is offline
PostPosted: Sun Sep 29, 2013 7:24 pm    Post subject: Reply with quote
fat chicks leg hittin the shifter
73 beetle w 70 eng 1600sp daily driver,72 squareback
Cusser
Cusser is offline
PostPosted: Sun Sep 29, 2013 7:38 pm    Post subject: Reply with quote
You mean like "famous last words" ?
My battery is OK
I re-checked the spark plug wires order
The coil is wired correctly
I adjusted the timing right
The carb is getting fuel
It CAN'T be....
I've tried EVERYTHING !!!
I don't need a spare tire, I NEVER get flat tires or blowouts
MY fuel filter won't leak and catch the engine on fire
I don't need to wear a seat belt
My car ALWAYS starts
I've never had trouble on the road
I don't need to use a torque wrench
sb001
sb001 is offline
PostPosted: Sun Sep 29, 2013 7:59 pm    Post subject: Reply with quote
No. I was totally serious. A lot of bandwidth could be saved.
I forgot one-- bad gas.
1600 SP engine
olmer2
olmer2 is offline
PostPosted: Sun Sep 29, 2013 8:22 pm    Post subject: Reply with quote
I have fiber optics Smile
A fuse, it's usually a bad ground.
MAGIC SMOKE. The mysterious internal component of all electrical parts that allows them to work. If you let it out, the part will no longer work and could start a fire
'64? http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
Buggy (sold) http://www.thesamba.com/vw/forum/viewtopic.php?t=399142&highlight=
74 bug http://www.thesamba.com/vw/forum/viewtopic.php?t=547777
sb001
sb001 is offline
PostPosted: Sun Sep 29, 2013 8:50 pm    Post subject: Reply with quote
olmer2 wrote:
A fuse
Applause
1600 SP engine
volksworld
volksworld is offline
PostPosted: Mon Sep 30, 2013 4:30 am    Post subject: Reply with quote
it just needs a tune up....
zombiebug
zombiebug is offline
PostPosted: Mon Sep 30, 2013 5:22 am    Post subject: Reply with quote
I already adjusted valves.
'74 Super
drs1023
drs1023 is offline
PostPosted: Mon Sep 30, 2013 5:28 am    Post subject: Reply with quote
Running good when it was parked.
Mr.Duncan
Mr.Duncan is offline
PostPosted: Mon Sep 30, 2013 6:13 am    Post subject: Reply with quote
Personal one- "my brakes are fine"
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
ROCKOROD71
ROCKOROD71 is offline
PostPosted: Mon Sep 30, 2013 6:34 am    Post subject: Reply with quote
the fan belt isn't tight enough and/or something is caught up in the fan...
1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote:
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it.
asiab3 wrote:
Careful guys, a petulant child can grow up to be president these days.
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy**
DJ Bill
DJ Bill is offline
PostPosted: Mon Sep 30, 2013 6:51 am    Post subject: Reply with quote
Points are fine I changed them last spring.... Rolling Eyes Must be the carb then, huh?
I don't need that wire to the idle solenoid, cuz all that emissions stuff is better left unhooked or left off.
Cusser
Cusser is offline
PostPosted: Mon Sep 30, 2013 11:59 am    Post subject: Reply with quote
One of favorites (non air-cooled VWs):
AC only needs a recharge
...that means that there's a leak, which must be found and repaired, and usually not so straightforward, then evacuation and recharge. And sometimes a guess on how much refrigeration oil to add back....
Volks Wagen
Volks Wagen is offline
PostPosted: Mon Sep 30, 2013 12:10 pm    Post subject: Reply with quote
...just surface rust on the fenders
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
Mr.Duncan
"just patina"
1966 Ghia (sold)
1966 Red Beetle
Mr.Duncan
PostPosted: Mon Sep 30, 2013 12:12 pm    Post subject: Reply with quote
My favorite. "Just needs a tune up" -Personally said to myself.
Meanwhile, 1 whole engine rebuild later, I finally have a nice running bug.
1966 Ghia (sold)
1966 Red Beetle
sb001
sb001 is offline
PostPosted: Mon Sep 30, 2013 7:35 pm    Post subject: Reply with quote
An ignition coil wire Wink Rolling Eyes
1600 SP engine
camaroboi13
camaroboi13 is offline
PostPosted: Mon Sep 30, 2013 9:06 pm    Post subject: Reply with quote
It just needs a wheel balance... Shocked
3 wheel motion is scary when you don't expect it!
69 bug 1600sp buckpack ceramic header w mondo muffler, riviera wheels, 185/65 front 205/70 rear, dual baby webers, big stereo in the works.
2001 Yukon Denali 6.0l AWD 24s TVs surround sound playstation 6 disc dvd etc etc.
2005 Nissan Maxima 3.5l stock mama's car
FFL GUN DEALER! PM ME FOR SOCAL TRANSFERS!
