vw-man-with-saturn Samba Member
Posted: Wed Oct 02, 2013 4:43 pm Post subject: simple way adjusting lifters |
Can someone tell me a step by step of adjusting valves on a hydraulic lifter engine? Please dont tell me to search because the stuff Ive read seems like chinese to me |
my59 Samba Member
Joined: August 13, 2003 Posts: 3977 Location: connecting the dots
Posted: Wed Oct 02, 2013 5:03 pm Post subject: |
Have you ever adjusted valves before?
Do you have the Muir book? _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26533 Location: Douglas, WY
Posted: Wed Oct 02, 2013 5:13 pm Post subject: |
Why do you want to adjust them? Is there some issue where you suspect they aren't set up properly? Once set up, you don't need to check them.
Adjusting - it's about the same as adjusting the valves on a mechanical lifter engine, except that you back the adjusters out til they have clearance, screw them in until they contact the valve stem, then turn them in 2 full turns and tighten the locknuts.
So:
Engine cold -
Pull the valve covers off, clean and re-gasket them as needed.
Remove the distributor cap and then turn the engine over until the rotor points at cylinder number 1 and is at TDC on the timing scale (there's a mark on edge of distributor body, and verify that it's the same as where the number one spark plug is plugged into.)
Adjust number 1 as mentioned above.
Rotate engine by hand backwards 90 degrees, repeat for cylinder two.
Rotate engine by hand backwards 90 degrees, repeat for cylinder three.
Rotate engine by hand backwards 90 degrees, repeat for cylinder four.
Replace valve covers and distributor cap.
Start engine and watch for valve cover leaks. |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1603 Location: Indianapolis, IN
Posted: Wed Oct 02, 2013 5:46 pm Post subject: |
glutamodo wrote: |
So:
Engine cold -
Close but.......
If the motor is in it... go for a drive, 15-30 minutes
When its cool enough to work on; 30mins to 6 hours then you do the valve adjust procedure except you want to set the adjustment screws between 1 and 1.5 turns in... not 2 _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52822 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 02, 2013 6:02 pm Post subject: |
I agree yet disagree with both of you in a way
Never trust the mark in the distributor as #1 TDC, get familiar with cylinder numbering and follow the plug wire from that cylinder to the distributor, then make a mark on the side of the distributor body with a Sharpie at each wires location with the corresponding number where it plugs in, there's too many differently marked distributors and dumbs**t mechanics installing drives to assume the mark is correct. Once it's marked adjust the valves on the cylinder number the rotor is currently pointing to.
Secondly Hydros don't really need to be warm for adjusting, you can still feel the end of the internal spring where it goes to zero lash even if they are dry.
As for don't need adjusting?, technically they don't but it's good to unwind them and readjust every year or two just to get a read on the health of the valve train and heads. Log how many turns it takes to reach zero lash for each cylinder and compare to previous jobs, if one requires more or less it may be eating a lifter or dropping a seat and things like that are best dealt with in the driveway opposed to roadside in the middle of nowhere. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Oct 02, 2013 6:10 pm Post subject: |
busdaddy wrote: |
Never trust the mark in the distributor as #1 TDC, get familiar with cylinder numbering and follow the plug wire from that cylinder to the distributor, . |
Uhh, that's exactly what I meant when I said: and verify that it's the same as where the number one spark plug is plugged into
So busdaddy, how many turns in do you like to go? I said 2 full turns above mostly because that's what the Bentley says. Back when I worked on these, I never liked going that far myself, and usually went around 1.5 turns. |
Posted: Wed Oct 02, 2013 6:14 pm Post subject: |
local vw tech said that the right front one needed to be adjusted. All this from revving the engine and listening wow!!
How can I tell for sure its a hydrualic lifter engine? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79569 Location: Sneaking up behind you
Posted: Wed Oct 02, 2013 6:20 pm Post subject: Re: simple way adjusting lifters |
vw-man-with-saturn wrote: |
路加福音,使用搜索
我用 1.5 輪流 _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Oct 02, 2013 6:27 pm Post subject: |
Well, it's hard to know what previous owners and mechanics have done to the engine over the years. But, back when these were knew, VW made a visual change to the rocker arms at the same time they went hydraulic, a spacer bushing between rockers instead of the spring they used previously.
Also - what's your engine number? |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Wed Oct 02, 2013 6:28 pm Post subject: |
他妈的格伦!! _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Desertbusman Samba Member
Posted: Wed Oct 02, 2013 6:36 pm Post subject: |
At least it isn't Greek. _________________ 71 Superbug
71 Westy |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Wed Oct 02, 2013 6:40 pm Post subject: |
1.5 turns past 0 lash please. Not 2 turns. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Posted: Wed Oct 02, 2013 6:50 pm Post subject: |
glutamodo wrote: |
busdaddy wrote: |
I know what you meant but some of the ummm.....grey matter deprived readers here could mistake that as the cylinder the rotor actually points to like on a compass or don't fully understand cylinder numbering, just clarifying
I too say 1.5 turns. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aopisa Samba Member
Posted: Wed Oct 02, 2013 8:23 pm Post subject: |
Desertbusman wrote: |
At least it isn't Greek. |
Χρησιμοποιώ πάντα 1,5 στροφές. _________________ 1977 Westy 2.0L FI
Leap into the boundless and make it your home! ---Chuang-Tzu
Please let me know if you do not receive this message... |
Posted: Thu Oct 03, 2013 5:05 am Post subject: |
Here are my questions
If it was converted to solid lifter would it have to have the springs on the rocker shaft or still left with the solid spacer?
So to adjust I turn it in so its touching the valve and then clockwise another 1.5 turns? |
curtis4085 Samba Member
Posted: Thu Oct 03, 2013 6:05 am Post subject: |
Could have solid spacer and be solid lifter. I run non hydros with a solid spacer
Check your push rods. Aluminum or steel. Not fool proof though as some run steel pushrods on solid lifters.
The safest way to tell is pull a lifter. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Thu Oct 03, 2013 10:26 am Post subject: |
If it was converted to solid lifter would it have to have the springs on the rocker shaft or still left with the solid spacer? |
Yes you can have solid spacers with solid lifters, this is actually very preferable. You can feel the difference between solid and hydraulic lifters when adjusting the valves. Hard to explain it but it is very noticeable.
Yes, just be aware that the point of contact can be very subtle if the lifters are not fully pumped up, which is typical. Just use your finger tips and check the point of contact repeatedly if you are not sure. |
Mobiltune Samba Road Ranger
Joined: April 16, 2008 Posts: 499 Location: San diego county
Posted: Thu Oct 03, 2013 10:55 am Post subject: Re: simple way adjusting lifters |
Glenn wrote: |
路加福音,使用搜索
我用 1.5 輪流 |
Luke, use the search
I used 1.5 turns
Luke, χρησιμοποιήστε την αναζήτηση
Θα χρησιμοποιηθεί για 1,5 στροφές _________________ Roadster Bus |
Posted: Thu Oct 03, 2013 12:51 pm Post subject: |
Sometimes you can just shine a light down a pushrod tube and see the retaining clip that holds the hydraulic lifter together.
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Thu Oct 03, 2013 1:04 pm Post subject: |
I followed Ratwell....I confirmed all 6 and did 1.5 turns;
Here are some clues to look for in order to help you determine if you have hydraulic lifters:
The engine case number begins with GE (bus) or CV (Vanagon).
The fan shroud has a similarly prefixed number.
There is a sticker on the fan shroud indicating zero lash.
The case lacks a bolt with a large 13mm triple square head on the right side of the case between the push rod tubes.
The rocker arms are separated by a wavy spacer washer instead of a spring.
The push rods are one piece steel instead of a large aluminum tube with small steel tips. _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
