AlteWagen Troll
Posted: Thu Oct 10, 2013 1:36 pm Post subject: VW Cylinder Head Quick Reference Sheet |
I think I will make this a topic of its own
Trying to find this data in one place is frustrating when deciding what heads to use for a specific build or if heads have been modified significantly from as cast form.
Combustion chamber volume is ACTUAL chamber cc not including step volume if present. Step height is measurement is in the adjacent column with total advertised combustion volume listed under the miscellaneous column.
Retail listing is for TWO cylinder heads at current market prices as of Jan 2014
If product manufacturers/distributors have more accurate/updated data please let me know and I will update the listing immediately. Any new products will also be gladly added as they become available.
edit: updated sheet
edit: updated again
edit: still updating
edit: did I mention update?
edit: newb clarification
edit: update some more _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1206 Location: Melbourne Australia
Posted: Thu Oct 10, 2013 4:33 pm Post subject: |
It would be useful to have the available valve sizes in a separate column, as some CB heads are available in different combos
the JPM230 valve size is 48/38. no step
CB street elim 42/37.5, 44/37.5, 46/38 no step
the chart is a great idea  |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Oct 10, 2013 7:34 pm Post subject: |
It would be also handy to add other shops specs too such as DRD's L3,5,6,7 etc _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Fri Oct 11, 2013 12:02 am Post subject: |
Hmm, interesting - but you show the Los Panchitos as not having a step and the guys who have bought them say they do, even if bored to a larger cylinder size? _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3295 Location: SOUTH DAKOTA
Posted: Fri Oct 11, 2013 6:13 am Post subject: |
Mofoco 042's have a step. Roy told me that the step is about .060" high and that on a head bored for 90.5/92 mm cylinders the 53cc volume includes the step. I haven't done the math but he said removing it would leave a chamber volume of about 43cc. |
AlteWagen Troll
Posted: Fri Oct 11, 2013 9:18 am Post subject: |
Quokka42 wrote: |
Hmm, interesting - but you show the Los Panchitos as not having a step and the guys who have bought them say they do, even if bored to a larger cylinder size? |
I know they have a step but couldnt find any measurements other than whats listed at the site. Since they are based on the 043 I will measure the chamber vs step and update the listing.
As for the Mofoco step, Ive read several recent posts that state .050 but if Roy wants to correct that Ill update as well.
Anyone have port volume numbers for the DRD L3-7? _________________ Grapes of Wrath $200 Engine Rebuild
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 506 Location: Nowhere, USA
Posted: Sat Oct 12, 2013 5:39 am Post subject: |
Excellent information, and nice to see it coming together in one place. The trouble is, there are a lot of information holes that really need to be filled to make this super useful. This is a nice starting point for guys with the appropriate equipment to help fill in the blanks.
If somebody had a flow-bench, and could post observed (as opposed to reported) numbers at .5" of lift and 25" vacuum, as well as accurate cc measurements of the intakes and chambers, we wouldn't all stumble around in the dark when trying to put together combinations.
The same applies to camshafts. If somebody had a profiler and could digitize the various popular grinds, the combination of real flow data and real cam profiles would allow desk-top dyno simulations with real numbers.
We tend to worship in "air-cooled orthodox" chapels of one stripe or another, and there are guys that have observed a lot over many years of screwing engines together. But building combinations and trying them to see how they work is a hideously expensive way to experiment, and it's what keeps guys from coloring outside the lines. As software gets better and better, at least the first stages of experimentation can occur in the digital (as opposed to physical) world and weed out the combinations that look promising, but are fatally flawed in some way.
This is a fantastic step in the right direction. I appreciate the time and effort to share with the class. _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
AlteWagen Troll
Posted: Sat Oct 12, 2013 11:47 am Post subject: |
58 Plastic Tub wrote: |
The trouble is, there are a lot of information holes that really need to be filled to make this super useful |
I agree. Since there are only a few manufacturers of cylinder heads out there I wanted to put together a base line list so you could at least see what you should be able to expect "out of the box". There are vendors that improve on the base casting and actually post numbers on what was done which is helpful in trying to compare products.
Does anyone know what lift the CB numbers are at? Ive heard .650 but not sure and have not heard back from CB.
I was adding the DRD heads and noticed his numbers are done at 28" rather than 25" most VW heads are measured at. DRD also list the as cast 049 at 138@ .500 28" [email protected] 28" which converts to [email protected] 25" [email protected] 25". Wondering why he stopped testing at .500, the CE flow sheet went all the way to .600 and got intake [email protected] 25” exhaust [email protected] 25”. The difference in flow bench data really seems to confuse the issue even more.
The same problem is with the Bill Fisher How to Hot Rod book. It lists flow numbers for both the single port and dual port head with various modifications done to show what works or doesnt work. Unfortunately they dont give ANY readings but show some pretty high numbers for stock ports. Single ports were Intake [email protected] Exhaust [email protected], Dual ports were Intake [email protected] [email protected]. Anyone know the depression readings that were used back in the day?
I was originally not going to put flow numbers and just list port cc but since I was able to find some data on stock heads I thought it would be nice to compare and then got carried away. Ideally I would love to have flow readings for all heads at .300, .400, .500, .600 so the typical street guy can make a good decision on what they need. Since not many street cars are running more than .600 lift numbers above that would not be useful. _________________ Grapes of Wrath $200 Engine Rebuild
Posted: Sat Oct 12, 2013 2:21 pm Post subject: |
AlteWagen wrote: |
Does anyone know what lift the CB numbers are at? Ive heard .650 but not sure and have not heard back from CB. |
From CB's website:
Super Mag: 140 cfm @ .5" @ 25"
Ultra Mag Plus: 165 cfm @ .5" @ 25"
Super Pro: 203 cfm @ .5" @ 25"
Mini Wedge: 182 cfm @ .5" @ 25"
Wedge Port: 197 cfm @ .5" @ 25"
Ultra Wedge: 208 cfm @ .5 @ 25"
Street Eliminator, all intake sizes: 193.5@ 25" (lift unknown)
Competition Eliminator, 48 mm intake: 219 cfm @ .5" @ 25"
There's good information for all the heads except Los Panchitos, and the Street Eliminators. The heads with various valve-sizes available have the flow information listed for the biggest valve size. _________________ Stan Galat
AlteWagen Troll
Posted: Sat Oct 12, 2013 2:40 pm Post subject: |
thats great info, i will update the table with that as it seems more standard and easier to compare. The data I had came from their ad in HVW so maybe the higher numbers were at higher lift.
The info on the panchito was directly from Pat Downs in one of the threads here. I still wish I could find the actual chamber and step measurement separate not combined as published. _________________ Grapes of Wrath $200 Engine Rebuild
modok Samba Member
Joined: October 30, 2009 Posts: 27689 Location: Colorado Springs
Posted: Sat Oct 12, 2013 3:01 pm Post subject: |
Assume a .055 step of stock bore size and do the math, it won't be far off.
The super-pro heads sure ought to be killer eh? They look to make the mini-wedge obsolete! Man, I want some!
But what if you want a high velocity 60-65cc intake port to make big torque for a smaller CC engine???? many aftermarket heads are too big already!  |
AlteWagen Troll
Posted: Sat Oct 12, 2013 3:14 pm Post subject: |
Im waiting for RM to respond with the port cc of an as cast head, the only problem is they dont have stock sized valves. Since it looks just like the old 041 Im guessing 59-61cc.
On a smaller engine (1679-1835) is there any downside to having 40x35 with no port work and an as cast 60cc port? To me the 049 in stock form looks to be the same as the ponchito _________________ Grapes of Wrath $200 Engine Rebuild
modok Samba Member
Posted: Sat Oct 12, 2013 3:36 pm Post subject: |
Depends. If single carb then it's not too big a deal to have a too big port, since the port is a much smaller section of the "intake system"
With IR carbs the port is very important!
The panchito could support a 1600cc to north of 7k rpm! if the port is bigger than needed all you get is less torque, that's all you get, less!  |
AlteWagen Troll
modok Samba Member
Posted: Sat Oct 12, 2013 8:53 pm Post subject: |
Some of the different castings have a little different port shape so the intake CC isn't exactly comparable, for instance the 040 and 041 have a HIGHER port compared to 311, 113, 043, if you compare them.
since this thread is about head castings I will say 043 or 113 or 311, maybe 311 mexicans.
Modified by someone who knows what they are doing, which is a point we don't always agree on, so maybe we open a new thread for that
Larger intake valves may be a good idea but only in moderation and probably only with larger bore, and depending on lift..... the 120 and 110 are medium lift; you could go either way |
Posted: Sat Oct 12, 2013 9:18 pm Post subject: |
modok wrote: |
The super-pro heads sure ought to be killer eh? They look to make the mini-wedge obsolete! Man, I want some! |
Yeah. The numbers really look almost too good to be true.
I also agree with you that there'd be a good market for a head with flow numbers in the 160- 180 cfm range (@ .5" lift and 25"), and really modest intake port volume. I'd love to see some real flow number for the Los Panchitos heads, as they seem to fit the bill in both regards. _________________ Stan Galat
AlteWagen Troll
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Mon Oct 14, 2013 10:19 am Post subject: |
You need to update the original chart in the first post of this thread. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
bvilletom Samba Member
Joined: January 22, 2006 Posts: 95 Location: cedar rapids iowa usa
Posted: Wed Oct 23, 2013 9:02 am Post subject: Vintage VW Head Flow Chart revision |
A great idea to make a VW cylinder head flow chart. I can help fill in some of the blanks on the chart.
The Fisher book on "How to Hot Rod the VW" lists the head flow numbers for single port and dual port 1600 VW heads but does not have the test pressures. I have a Super Flow bench and I tried all kinds of test pressures to duplicate the figures in the book and failed to match them. They all seem to be too high but the modifications they did all pretty much checked out as far as the gains and losses went. Even lowering the valve seats the large amount recommended by the book worked really well.
Here are some of the flow numbers for the vintage style heads.
Bvilletom (Tom Bruch) _________________ bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction |
AlteWagen Troll
