Cracks in #3 and #4 cylinder head
JK73Super
JK73Super is offline
PostPosted: Thu Jan 02, 2014 5:42 pm    Post subject: Cracks in #3 and #4 cylinder head Reply with quote
Is this head scrap, or can it be repaired, or worth a repairing?
Recently, I disassembled by engine due to low compression and ended up with an alignment bore, new bearings, new pistons, cylinder, tappets…….
Before assembling the case, I decided to clean up the heads and found #3 and #4 cylinder head cracked between the spark plug hole and valve seats, as can be seen below.
I had a pile of parts given to me a while ago and I found two heads, which are very dirty and carboned up. I’m in the process of cleaning them up. However, I’m not sure if this head is an exact fit (appears to be) for my 1600 DP, since it came with a different type engine.
Other than type 1, I’m not familiar with the others. Can anyone tell what type the engine is in the picture below, and if the head came off of that block, can they be used on the standard 1600 DP engine case. Or for that matter are the engine cases the same?
[/img]
johnnypan
johnnypan is offline
PostPosted: Thu Jan 02, 2014 5:52 pm    Post subject: Reply with quote
Type 3/4 late bus engine fuel injected...heads wont work..
Been involved in a few debates over reusing cracked heads,some say never,some say never if cracked to the spark plug hole,but ok between the valves...some say its okay to reuse cracked heads regardless of cracked area..Im inclined to go with the last,Ive pulled down engines than ran fine with cracked heads, its impossible to tell when the head cracked,its possible its ran for thousands of hard miles like that..Id timesert that spark plug hole to stabilize the crack and rock those heads..if the guides and seats play out...
volksworld
volksworld is offline
PostPosted: Thu Jan 02, 2014 8:06 pm    Post subject: Reply with quote
never use a head cracked to the plug hole....the engine in the picture is a type III...should be a 1600...head will fit but if it doesn't have the step around the edge it is a higher compression and would need a barrel spacer under the cylinder to match it to the other side...after 40 years you never know what has been installed,it could have a head of any year or model on it
75smith
75smith is offline
PostPosted: Thu Jan 02, 2014 8:27 pm    Post subject: Reply with quote
post a pic of the whole head, and the part number under the rockers
could be type 1 heads with a late motor, no way to completely tell with those pictures,
but those heads aren't good, unless you get them welded, and very few people will weld heads anymore, cause the welds just don't last
My 1975 Beetle Build Updated 8-21-12
My engine build
Bashr52
Bashr52 is offline
PostPosted: Fri Jan 03, 2014 7:30 am    Post subject: Reply with quote
Cracks from plug to valve are junk heads. Cracks just between valves are ok.
thechief86
thechief86 is offline
PostPosted: Fri Jan 03, 2014 7:54 am    Post subject: Reply with quote
I guess I learned something today! I scrapped about a dozen heads because they were cracked between the valves, even though my engine ran fine with one of them. I spent a lot of time looking around for original German heads to port and polish for my 1679, and after several months found a perfect set.
Does anyone else agree that cracks between the valves are ok? I have a few of those left that I might not scrap now...
I had been told that any cracks of any type in any location on a Vw head meant they were junk.
"A poor workman always blames his parts... Ya gotta have skillz to hang junk." -johnnypan
drs1023
drs1023 is offline
PostPosted: Fri Jan 03, 2014 8:09 am    Post subject: Reply with quote
Another point of view - V-grind the crack past the depth of the crack and weld it back in. For those who say "Never run a cracked head" (either plug to valve or valve to valve), please consider the reason you are tearing down the engine. If the crack is the root cause of the teardown such as blowing exhaust through the crack or losing vacuum or compression, then, by all means, scrap it, but if you are tearing down an engine for burning oil, rattling, poor oil pressure, etc. and that engine just happens to have a cracked head . . . well, you get my logic. Of course, I wouldn't build a drag car using cracked heads, but I'd wager that literally thousands of beetles are running around with unknown cracked heads with no consequences.
johnnypan
PostPosted: Fri Jan 03, 2014 8:42 am    Post subject: Reply with quote
Heads crack from heat stress.. once cracked, the stress is relieved.I was of the opinion of bashr and volksworld, the crack to the plug hole could allow the valve seat to dislodge, no doubt.. but there are some folks on here working with heads cracked like that,they have success timeserting the plug hole,basically closing the edge of the crack once they felt the seat was anchored..then peening the crack itself to prevent hotspots..takes guts however,if your wrong it will cost ya..
djkeev
djkeev is offline
PostPosted: Fri Jan 03, 2014 8:50 am    Post subject: Reply with quote
Different engine...... Same discussion only we are running water through the heads but........
The 2.1 Vanagon WBX engines crack a lot.
Here's a photo of the crack and the calipers open to the allowable crack width.......
And Bentley telling me to run this head.........
Dave
Ghia
Vanagon
Beetle
Dwayne1m
Dwayne1m is offline
PostPosted: Fri Jan 03, 2014 9:13 am    Post subject: Reply with quote
Knowing I have a crack of any kind in the head or case would make me very nervous. Every strange noise or stumble from the engine would make me cringe. I just wouldn't be able to trust that car. But that's just me.
djkeev
djkeev is offline
PostPosted: Fri Jan 03, 2014 9:26 am    Post subject: Reply with quote
Yeah, there is discussion if running a cracked head is actually OK......
OR......
If VW was simply trying to minimize their financial exposure that replacing every Vanagon head in the World would inflict upon the company!
So they issue a service bulletin..... "Cracks are good! Yeah.... You WANT cracks! See..... Everyone has cracks!....... But BIG cracks are bad! Boo! Big Cracks!" Smile
Dave
Ghia
Vanagon
Beetle
Volks Wagen
Volks Wagen is offline
PostPosted: Fri Jan 03, 2014 1:26 pm    Post subject: Reply with quote
This would be my approach too. I'd at least investigate how far the crack went - could be surface. That may have been heat, may have been someone overtorquing a plug, may have been plug wound in on top of hardcarbon deposits. There's a lot of meat around the seat and it doesn't look like it's lifting.
Of course if you ask anyone who may be blamed they'll say replace the head. Logical. But it's your money, get out the dremel.
Other guys throwing heads out without checking must have more money than sense. Recycle! Smile
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
thechief86
PostPosted: Fri Jan 03, 2014 3:59 pm    Post subject: Reply with quote
I wouldn't say I have more money than sense, but rather listen to the advice of older guys who have more experience with aircooled motors than I. I never really considered that if the motor ran ok the heads must be fine...
I did have one cracked head that allowed one exhaust valve seat to sink about .25" into the head. That one ran fine, too, as long as I adjusted the valve back out every 500 miles or so, then installing washers between the head and rocker rail so I could get some lash, lol.
I think I'd rather just use uncracked heads so I don't have to tear the motor back down when it messes up again. For the record, I have some cool friends with fields of junk cars that I was able to rob heads off of. I just had to lap the valves and put in new springs is all. The set I'm going to put on next week got a lot of port and polish work before I put the valves back in...
JK73Super
PostPosted: Fri Jan 03, 2014 5:56 pm    Post subject: Reply with quote
Someone asked for the Head ID number to determine whether my spare carboned up heads can be used as replacement for my cracked head.
Below are the picture with the head ID. I hope I can use the spares.
djkeev
djkeev is offline
PostPosted: Fri Jan 03, 2014 6:13 pm    Post subject: Reply with quote
Your alternate heads are from a 1600 type 3..... Late 60's into early 70's.
They lack the shelf in the combustion chamber that your type I has.
Will they work? Probably but that is a question for people smarter than me to answer!
Ghia
Vanagon
Beetle
