forged or cast lightened flywheel
advinnie
advinnie is offline
PostPosted: Mon Jan 06, 2014 2:46 pm    Post subject: forged or cast lightened flywheel Reply with quote
Hi all I need a lightened 8 dowelled flywheel but should I get a cast or forged one and why?
I'm not going to be racing my bug on a track at all and it will not be reved above 6000 RPM.
Brian_e Premium Member
Brian_e is offline
PostPosted: Mon Jan 06, 2014 3:08 pm    Post subject: Reply with quote
This one of the best deals around. Good quality.
http://vwparts.aircooled.net/Economy-Lightened-Flywheel-13lb-8-Doweled-p/light-flywheel-ec.htm
Danwvw
Danwvw is offline
PostPosted: Mon Jan 06, 2014 3:12 pm    Post subject: Reply with quote
Is there such a thing as a forged VW Flywheel?
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jan 06, 2014 3:15 pm    Post subject: Reply with quote
Stock flywheels are forged.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Danwvw
Danwvw is offline
PostPosted: Mon Jan 06, 2014 4:24 pm    Post subject: Reply with quote
Saw this one on e-bay for $120, says it's supposed to be a lightened VW Flywheel. When I built my 1800cc Type 1 engine for my bus, I had an old stock VW flywheel surfaced and drilled for 8 dowels and balanced to the crank with the clutch but not lightened.
"VW Forged Lightened Chromoly Flywheel 8-Dowel Type-1"
gt1953
gt1953 is offline
PostPosted: Mon Jan 06, 2014 5:49 pm    Post subject: Reply with quote
A lightened flywheel revs quicker, in a bus you are better off with the heavy flywheel. It keeps the inertia better.
72 type 1
72 Squareback
vwracerdave
vwracerdave is offline
PostPosted: Mon Jan 06, 2014 6:07 pm    Post subject: Reply with quote
The $79 cast flywheel are fine for a street engine if you're never going to drag race or see over 6000 RPM.
If your racing (street or track) or turning more RPM's then you should get a $120 forged chromoly flywheel or use a genuine VW flywheel.
Brian
Brian is offline
PostPosted: Mon Jan 06, 2014 11:34 pm    Post subject: Reply with quote
I'm a strong believer in this, but while on the subject, what about a heavier pulley? I remember reading a post in a debate with Gene Berg about a heavy pulley and how they found the best combination for increased bearing life was a heavy pulley and lightened fly-wheel. It's all about inertia and the engine's resonance.
These suckers are 5.5 pounds
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Mr.Duncan
Mr.Duncan is offline
PostPosted: Tue Jan 07, 2014 7:29 am    Post subject: Reply with quote
That does make sense.
But, I assume the idea is the heavy flywheel wants to pull UP on the end with the pulley right?
So install a heavy pulley on that end to kinda "even the balance out"
But, wouldn't the Generator/alt belt tension pull up on that end of the crank so there is no real gain?
Just wondering.
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
slalombuggy
slalombuggy is offline
PostPosted: Tue Jan 07, 2014 9:38 am    Post subject: Reply with quote
IF you are racing you CANNOT use a cast flywheel, they are banned on NHRA tracks. There was a picture last year going around of a bug with the rear end blown off of it and the engine hanging on the accelerator cable after a cast flywheel exploded at the line injuring some people.
brad
modok
modok is offline
PostPosted: Tue Jan 07, 2014 6:42 pm    Post subject: Reply with quote
The cast iron flywheels are from mexican bugs. They are not very good, and not cheaper either. Get a modified OE flywheel from DPR, made of German STEEL
modok
modok is offline
PostPosted: Tue Jan 07, 2014 6:44 pm    Post subject: Reply with quote
brad
ah jeez, that should never have happened but I guess it would be an easy mistake to make with these darn iron "lightened" flywheels being sold.
hooker
hooker is offline
PostPosted: Wed Jan 08, 2014 8:27 am    Post subject: flywheels Reply with quote
In NHRA drag racing the porsche and volkswagen flywheels were the only "STOCK" flywheels that were allowed to run on a turbo charged VW or Porsche engine. All other vehicles (chebys,fords etc) had to use an after market flywheel.
That should tell you something.
2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted.
