advinnie Samba Member
Joined: November 18, 2011 Posts: 1405 Location: oxfordshire
Posted: Mon Jan 06, 2014 2:46 pm Post subject: forged or cast lightened flywheel |
Hi all I need a lightened 8 dowelled flywheel but should I get a cast or forged one and why?
I'm not going to be racing my bug on a track at all and it will not be reved above 6000 RPM. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4001 Location: Rapid City, South Dakota
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79507 Location: Sneaking up behind you
Posted: Mon Jan 06, 2014 3:15 pm Post subject: |
Danwvw wrote: |
Is there such a thing as a forged VW Flywheel? |
Stock flywheels are forged. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Danwvw Samba Member
Posted: Mon Jan 06, 2014 4:24 pm Post subject: |
Saw this one on e-bay for $120, says it's supposed to be a lightened VW Flywheel. When I built my 1800cc Type 1 engine for my bus, I had an old stock VW flywheel surfaced and drilled for 8 dowels and balanced to the crank with the clutch but not lightened.
"VW Forged Lightened Chromoly Flywheel 8-Dowel Type-1"
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Mon Jan 06, 2014 5:49 pm Post subject: |
A lightened flywheel revs quicker, in a bus you are better off with the heavy flywheel. It keeps the inertia better. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15600 Location: Deep in the 405
Posted: Mon Jan 06, 2014 6:07 pm Post subject: |
The $79 cast flywheel are fine for a street engine if you're never going to drag race or see over 6000 RPM.
If your racing (street or track) or turning more RPM's then you should get a $120 forged chromoly flywheel or use a genuine VW flywheel. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Brian Samba Moderator
Posted: Mon Jan 06, 2014 11:34 pm Post subject: |
vwracerdave wrote: |
If your racing (street or track) or turning more RPM's then you should get a $120 forged chromoly flywheel or use a genuine VW flywheel. |
I'm a strong believer in this, but while on the subject, what about a heavier pulley? I remember reading a post in a debate with Gene Berg about a heavy pulley and how they found the best combination for increased bearing life was a heavy pulley and lightened fly-wheel. It's all about inertia and the engine's resonance.
These suckers are 5.5 pounds
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Tue Jan 07, 2014 7:29 am Post subject: |
lustig69 wrote: |
I'm a strong believer in this, but while on the subject, what about a heavier pulley? |
That does make sense.
But, I assume the idea is the heavy flywheel wants to pull UP on the end with the pulley right?
So install a heavy pulley on that end to kinda "even the balance out"
But, wouldn't the Generator/alt belt tension pull up on that end of the crank so there is no real gain?
Just wondering. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
slalombuggy Samba Member
Posted: Tue Jan 07, 2014 9:38 am Post subject: |
IF you are racing you CANNOT use a cast flywheel, they are banned on NHRA tracks. There was a picture last year going around of a bug with the rear end blown off of it and the engine hanging on the accelerator cable after a cast flywheel exploded at the line injuring some people.
brad |
modok Samba Member
Joined: October 30, 2009 Posts: 27667 Location: Colorado Springs
Posted: Tue Jan 07, 2014 6:42 pm Post subject: |
The cast iron flywheels are from mexican bugs. They are not very good, and not cheaper either. Get a modified OE flywheel from DPR, made of German STEEL |
modok Samba Member
Posted: Tue Jan 07, 2014 6:44 pm Post subject: |
slalombuggy wrote: |
brad |
ah jeez, that should never have happened but I guess it would be an easy mistake to make with these darn iron "lightened" flywheels being sold. |
hooker Samba Member
Joined: October 07, 2004 Posts: 261 Location: Bend, Oregon
Posted: Wed Jan 08, 2014 8:27 am Post subject: flywheels |
In NHRA drag racing the porsche and volkswagen flywheels were the only "STOCK" flywheels that were allowed to run on a turbo charged VW or Porsche engine. All other vehicles (chebys,fords etc) had to use an after market flywheel.
That should tell you something. _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted. |
