Torque Wrench for Wiper shaft
Sherrinonie
Sherrinonie is offline
PostPosted: Sat Feb 01, 2014 9:47 pm    Post subject: Torque Wrench for Wiper shaft Reply with quote
So before looking for the valuable info the samba offers, I phoned Gowesty and explained that my passenger windshield wiper blade motor was working but wiper was not moving. I was told that I needed a new wiper arm shaft. It arrive today but I am going to head to the hardware store tomorrow and looking for info on what tools to pick up that are needed to remove the wiper arm. Which torque wrench and lug nut attachments do I need? I'm going to pick up a sharp pick or exact o knife to clean the threads/spines. Hoping that's all that needs to be done. Shoot, there are no returns for this wiper arm shaft that I received, only exchanges. Rolling Eyes
Thanks Laughing
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Feb 01, 2014 10:23 pm    Post subject: Reply with quote
I'm not positive but I think replacing the shaft is major. Is that really what you bought, and am I correct that replacing it means pulling the entire dash to get to that shaft and wiper linkage? More details please.
pnwkayaker
pnwkayaker is offline
PostPosted: Sun Feb 02, 2014 12:57 am    Post subject: Reply with quote
Might be obvious, but did you try to adjust the screw in the wiper arm, before assuming the arm was broken? I had a similar problem a while ago, and it turned out it was a lose screw at the end of the arm
87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link)
zeohsix
zeohsix is offline
PostPosted: Sun Feb 02, 2014 7:53 am    Post subject: Reply with quote
I've had success putting shim stock between the wiper shaft and the wiper on shafts with worn out splines. Carefully tightening that little nut Very Happy
Sherrinonie
PostPosted: Sun Feb 02, 2014 7:55 am    Post subject: Reply with quote
I'm going to attempt to adjust the nut on wiper arm today. Looking for suggestions on which torque wrench and lug nut attachment kit I should buy.
Letsgo
Letsgo is offline
PostPosted: Sun Feb 02, 2014 8:02 am    Post subject: Reply with quote
This may help you.
http://www.youtube.com/watch?v=Pqk--uQUQ8w&feature=youtube_gdata_player
?Waldo?
?Waldo? is offline
PostPosted: Sun Feb 02, 2014 9:01 am    Post subject: Reply with quote
THE SPLINES ON THE STEEL WIPER SHAFTS DO NOT WEAR OUT. When there is something stopping the wiper arm from moving (e.g. frozen to windshield) and someone turns on the wipers, the force of the wiper motor overcomes the strength of the aluminum wiper arms and smears the aluminum. When that has happened and the wiper arm is then removed, it may LOOK like the splines are worn out, but instead, they are just filled with aluminum. Sometimes, the wiper arms have had that happen enough times that the hole in the arm gets enlarged enough that they need replacement. Usually the solution is much easier. I remove the wiper arms and then use the point of a sharp utility blade to scrape the aluminum out of the splines of the shaft. Once all traces have been removed, I replace the wiper arms and crank them on fairly well. If the splines are all clean and the wiper arm holes are not overly enlarged, then the wiper arm will hold fairly well. In working on many vans for many years, the only issue I've seen with the wiper shafts themselves is where the threaded part has snapped off.
dobryan Premium Member
dobryan is offline
PostPosted: Sun Feb 02, 2014 9:05 am    Post subject: Reply with quote
^^^^^ This X2!
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
?Waldo?
?Waldo? is offline
PostPosted: Sun Feb 02, 2014 9:08 am    Post subject: Reply with quote
I would add that if the splines are filled with aluminum and the arm is installed, no amount of cranking on the nut will get the arms to hold to the shafts. If you try to crank them on tight enough to hold (with filled splines) you WILL snap off the threaded portion of the shaft.
IdahoDoug
PostPosted: Sun Feb 02, 2014 10:47 am    Post subject: Reply with quote
Again - details? Not sure we are getting a clear enough picture what's wrong n what parts r being replaced, to help the poster.
chimivee
chimivee is offline
PostPosted: Sun Feb 02, 2014 10:58 am    Post subject: Reply with quote
Most folks probably wouldn't use a torque wrench for this - not critical. A basic metric socket wrench set is all you need - one that has at least 8mm, 10mm, and 13mm sockets will cover most small jobs on the van.
To get the wiper off, hold the wiper base firmly as you loosen the nut (10mm?). There's a thin washer under there too. After removing the wiper and cleaning out the splines you may have to give it a couple tries to get the wiper aligned properly on the shaft so that it is in the correct position on the window - but definitely check this before you fully tighten the nut.
As far as tightening the nut... hard to describe how tight to go if you don't have a feel for this stuff. Maybe hold the wrench fairly close (to the socket end) to avoid over tightening. I would think your wrist strength alone would be sufficient here (without putting your whole arm/body into it).
-James
86 Syncro Westy, etc
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
Sherrinonie
PostPosted: Sun Feb 02, 2014 1:53 pm    Post subject: Reply with quote
You all have been so generous with your help!! So I picked up a cool little kit with torque wrench and an assortment of adapters 5-10mm. I wish I would have had this from the beginning before calling gowesty. The lug nut was completely loose and just needed tightening. I didn't tighten too tight as to avoid causing damage to the wiper arm shaft. Now I will return the gowesty wiper arm shaft in exchange for a new pair of wipers for the future. Any suggestions on the best wiper blades? Thanks again!! Very Happy
?Waldo?
?Waldo? is offline
PostPosted: Sun Feb 02, 2014 4:12 pm    Post subject: Reply with quote
If you didn't clean the splines of the shaft as I described earlier, then the first time it's snowing, the wiper arm will very likely slip on the shaft.
kamzcab86
kamzcab86 is offline
PostPosted: Sun Feb 02, 2014 4:44 pm    Post subject: Reply with quote
For the record, in case anyone cares about precision Razz , Bentley says...
Front wiper arm nut: 43 inch-pounds (5 Nm / 3.5 ft. lbs.)
Front wiper relay rod nut: 69 inch-pounds (8 Nm / 5.75 ft. lbs.)
Rear wiper arm nut: 54 inch-pounds (6 Nm / 4.5 ft. lbs.)
Rear wiper mounting nut: 54 inch-pounds (6 Nm / 4.5 ft. lbs.)
In other words, not extremely tight. Wink
2016 Golf GTI S
geo_tonz
geo_tonz is offline
PostPosted: Sun Feb 02, 2014 5:12 pm    Post subject: Reply with quote
I put Bosch Icons on mine and liked them. Get a 21" (drivers side) and a 19" (passenger side) this is bigger than the stock 2x 18" wipers but will still fit without bumping the seals and give you more clear wind sheild. This is the same as the Go Westy big wiper kit (which is actually not too badly priced if shipping costs aren't astronomical).
Red Vanagon "Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper
woggs1
woggs1 is offline
PostPosted: Sun Feb 02, 2014 8:05 pm    Post subject: Reply with quote
What do you recommend for the biggest back wiper size?
4 speed 88 Westy
IdahoDoug
PostPosted: Sun Feb 02, 2014 10:48 pm    Post subject: Reply with quote
I'm apparently in a parallel universe.... Laughing
geo_tonz
geo_tonz is offline
PostPosted: Mon Feb 03, 2014 2:03 am    Post subject: Reply with quote
They're 16's stock. You might get a 17" to work. I mistakenly bought an 18" and it hit the rubber window seal and rode up on it. I returned it for a 16".
Because? Are the Darleks still alive in your world?
IdahoDoug
PostPosted: Mon Feb 03, 2014 5:14 pm    Post subject: Reply with quote
Poster: lug nuts, wiper shaft, torque wrench, adapters
Me: makes no sense, clarify?
Poster: zip nada
Outcome:
lug nuts = nut
wiper shaft = arm
torque wrench = ratchet
adapters = sockets
Thus, I am in a parallel universe in a land far away....
Dampcamper
Dampcamper is offline
PostPosted: Mon Feb 03, 2014 5:54 pm    Post subject: Reply with quote
You might be right. I've driven through Northern Idaho and it seemed...different. Wink
But therein is the charm.
