.2 volts through the rear defrost - improvement ideas?
kirkvw72
kirkvw72 is offline
PostPosted: Sat Feb 08, 2014 5:31 pm    Post subject: .2 volts through the rear defrost - improvement ideas? Reply with quote
My rear defrost has never worked. It never been an issue safety wise, but it has always bothered me that it doesn't work. Mirror heat fine. Switch is good. Fuse is good. Connections to the grid are good.
I get .2 volts in all places. At the wire, anywhere on the grid, and on the other side. So, I guess the good news is the grid is good.
Why would my voltage from the switched wire be so low? High resistance? Any suggestions?
1997 Miata
1988 Vanagon Wolfsburg
1987 Porsche 944 (951) Turbo
1987 Vanagon GL, Rocky Jennings Heads, RMW Exhaust, ASL 5-speed, AMG Wheels
1972 Beetle (standard)
1986 Westy, 2.5 Subaru
1973 Porsche 914 2.0
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Feb 08, 2014 5:41 pm    Post subject: Reply with quote
measure the voltage drop across the switch (volts reading from the hot input wire at the switch, to the output wire on the switch, with the switch TURNED ON. if you see a big 12 volt or so drop, then the switch is bad. you should have about 12 volts when switched off however, if not (ie you get low to zero volts when switch is off) then you have a bad ground at the window, if and only if you determine that the hot input wire to the switch is being supplied with 12 volts. by testing voltage between the hot switch input wire and a known good ground.
kirkvw72
kirkvw72 is offline
PostPosted: Sat Feb 08, 2014 6:00 pm    Post subject: Reply with quote
Thanks for the tip.
I've got 12v through the wires. Voltage drop through the switch drops it to the .2 volts I'm seeing. Guess the switch is bad!
Not sure how the mirrors still heat with a bad switch.
1997 Miata
Wildthings
Wildthings is offline
PostPosted: Sat Feb 08, 2014 7:29 pm    Post subject: Reply with quote
kirkvw72 wrote:
Thanks for the tip.
If you had 12.5 volts at the battery side of the switch and 0.2 V across the switch then you should be seeing 12.3 volts across the grid. What do you get when you read between the ground end of the grid and a good ground on the body?
kirkvw72
kirkvw72 is offline
PostPosted: Sat Feb 08, 2014 7:33 pm    Post subject: Reply with quote
The switch is definitely bad. Light works fine a through me off. Looks like someone tried and failed to fix it in the past. 12+ volts go in the switch, only .2 come out. I get .2 across the entire grid.
1997 Miata
