74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Wed Apr 23, 2014 7:39 am Post subject: Helicopter bus? |
Is this real, or a great Photoshop job? |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Wed Apr 23, 2014 7:41 am Post subject: |
| Looks like a crappy photoshop to me |
Posted: Wed Apr 23, 2014 8:16 am Post subject: |
....then there is this VW helicopter! |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10267 Location: Petaluma, CA
Posted: Wed Apr 23, 2014 8:20 am Post subject: |
Mad Max VW powered helicopter
Lind Samba Member
Joined: November 06, 2000 Posts: 10285 Location: idaho
Posted: Wed Apr 23, 2014 11:09 am Post subject: |
| campingbox wrote: |
that is an autogyro, not a helicopter. looks similar, but functions differently. totally bad-ass, best use for a 40hp engine ever. _________________ .
Wanted:
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8246 Location: San Dimas
grey60 Samba Member
Posted: Wed Apr 23, 2014 12:05 pm Post subject: |
That is one of the coolest things I've seen lately.
What's that? You've got a BMX bicycle or motorcycle or an open-wheel race car in the bed of your truck? I've got a freakin helicopter!
Now on my ever-growing list of VW-related things I need research in case I ever win the lottery. _________________ 1960 grey panel |
Posted: Wed Apr 23, 2014 1:31 pm Post subject: |
| Lind wrote: |
| campingbox wrote: |
that is an autogyro, not a helicopter. looks similar, but functions differently. totally bad-ass, best use for a 40hp engine ever. |
I think you need to build one of those. |
DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Wed Apr 23, 2014 2:35 pm Post subject: |
| Its fun to think about a vw powered helicopter, people have been using air cooled 2 and 4 cylinder vw engines in experimental airplanes for years but making an airplane fly vs a helicopter fly are two completely different subjects. To make a halfway decent helicopter the engine should be able to put out at least 120hp which would require a performance vw engine running at the top of it's rpm band for long periods of time. An airplane needs maximum performance for its take off and climb out while a helicopter requires it for hovering, take off, climbing and cruise flight at altitude and speed. Vw engines are more suited for planes and gyroplanes but I would be reluctant to trust one to keep me in the air in a helicopter, though that being said if a large fuel injected vw engine were to be stripped down and made as light as possible it could be feasibly done. |
Posted: Wed Apr 23, 2014 4:41 pm Post subject: |
| DannoT wrote: |
I'm with you on that. An air plane can glide if the engine stalls out, but when you suck that #3 valve in a helicopter, you're going straight down! No thanks! |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2696 Location: Phoenix AZ
Posted: Wed Apr 23, 2014 5:19 pm Post subject: |
I'll pass _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 21018 Location: Sandpoint, ID
Posted: Wed Apr 23, 2014 7:12 pm Post subject: |
| RPGreg2600 wrote: |
| DannoT wrote: |
Not in a gyrocopter like Campingbox posted, but in a heli, yes. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7125 Location: Lawrenceville, Ga
Posted: Wed Apr 23, 2014 8:06 pm Post subject: |
most people don't know the difference, i guess _________________ regards
Uli
Posted: Wed Apr 23, 2014 8:19 pm Post subject: |
| mandraks wrote: |
| most people don't know the difference, i guess |
true. A pilot can auto-rotate a heli to make an impromptu gyorcopter, but the results can be less than desirous. A gyro is actually an amazing feat of flight. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Posted: Thu Apr 24, 2014 5:34 pm Post subject: |
A pilot told me helicopter's never land it's more of a controlled crash.
I was a uh-60 repairer, after working on helicopter's I can tell you there is no way I'd fly in one of these shown above. _________________ 58' pg/sg silo fridge westy
76 911S |
Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Thu Apr 24, 2014 10:40 pm Post subject: |
| campingbox wrote: |
Boobs! _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
DannoT Samba Member
Posted: Fri Apr 25, 2014 1:20 am Post subject: |
It's a well known saying in the aviation industry that you could here from any good pilot that an airplane wants to fly and it takes an idiot to crash one, and a helicopter wants to crash and it takes an idiot to fly one  |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1940 Location: Warren, PA
Posted: Fri Apr 25, 2014 8:35 am Post subject: |
You can land a rotary winged aircraft with an engine out no problem. In fact its part of the certification and recertification of military pilots.
The only thing that needs to happen is an automatic clutch that will allow the blades to still freely rotate if the engine or transmission should fail and seize. Then the auto gyro effect works, its like wind blowing through a fan when you free fall through the air it keeps the rotor speed up to normal operating parameters. You simply pull up on the collective and you can safely and smoothly land a helicopter without engine power.
Auto gyros on the other hand have a terrible safety record, but you can build one cheaply and use a motorcycle or snowmobile engine to power it. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
Posted: Fri Apr 25, 2014 3:31 pm Post subject: |
| pondoras box wrote: |
Auto gyros on the other hand have a terrible safety record, but you can build one cheaply and use a motorcycle or snowmobile engine to power it. |
| cdennisg wrote: |
| mandraks wrote: |
true. A pilot can auto-rotate a heli to make an impromptu gyorcopter, but the results can be less than desirous. A gyro is actually an amazing feat of flight. |
A helicopter in auto-rotation mode is a compromise, and is rarely smooth. Yes, it is a necessary skill to learn to obtain your rotary license, but it is pretty rare to land smoothly. Here is a good example of an auto-rotation landing...
http://www.youtube.com/watch?v=MvMcsJTOYI0
A smoother auto rotate, but they don't actually land. Just practicing.
http://www.youtube.com/watch?v=pzWw5U3eCok _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
66uno Samba Member
Joined: December 05, 2006 Posts: 604 Location: maryland
Posted: Fri Apr 25, 2014 3:54 pm Post subject: |
I used to read the Bob Hoover "sermons". For those unfamiliar, Bob was a technical writer, a builder of vw's and vw engines both for the road and for the air. He was a pilot and a brilliant self taught engineer.
In one of his sermons, he described how the vw air cooled engine was just barely able to cool itself. He went on to explain that at higher atmospheres, were the air is thinner, it has an even more difficult time. And though they make good airplane engines, cooling it properly is always a problem.
Now, knowing all of this, it would seem very foolhardy to me to use one for a helicopter.  |
