Helicopter bus?
74 Cosa
74 Cosa is offline
PostPosted: Wed Apr 23, 2014 7:39 am    Post subject: Helicopter bus? Reply with quote
Is this real, or a great Photoshop job?
RPGreg2600
RPGreg2600 is offline
PostPosted: Wed Apr 23, 2014 7:41 am    Post subject: Reply with quote
Looks like a crappy photoshop to me
74 Cosa
74 Cosa is offline
PostPosted: Wed Apr 23, 2014 8:16 am    Post subject: Reply with quote
....then there is this VW helicopter!
campingbox Premium Member
campingbox is offline
PostPosted: Wed Apr 23, 2014 8:20 am    Post subject: Reply with quote
Mad Max VW powered helicopter
Lind
Lind is offline
PostPosted: Wed Apr 23, 2014 11:09 am    Post subject: Reply with quote
that is an autogyro, not a helicopter. looks similar, but functions differently. totally bad-ass, best use for a 40hp engine ever.
Wanted:
c21darrel
c21darrel is offline
PostPosted: Wed Apr 23, 2014 11:40 am    Post subject: Reply with quote
GhiaBuild
1967 DC build
grey60
grey60 is offline
PostPosted: Wed Apr 23, 2014 12:05 pm    Post subject: Reply with quote
c21darrel wrote:
That is one of the coolest things I've seen lately.
What's that? You've got a BMX bicycle or motorcycle or an open-wheel race car in the bed of your truck? I've got a freakin helicopter!
Now on my ever-growing list of VW-related things I need research in case I ever win the lottery.
1960 grey panel
PostPosted: Wed Apr 23, 2014 1:31 pm    Post subject: Reply with quote
I think you need to build one of those.
DannoT
DannoT is offline
PostPosted: Wed Apr 23, 2014 2:35 pm    Post subject: Reply with quote
Its fun to think about a vw powered helicopter, people have been using air cooled 2 and 4 cylinder vw engines in experimental airplanes for years but making an airplane fly vs a helicopter fly are two completely different subjects. To make a halfway decent helicopter the engine should be able to put out at least 120hp which would require a performance vw engine running at the top of it's rpm band for long periods of time. An airplane needs maximum performance for its take off and climb out while a helicopter requires it for hovering, take off, climbing and cruise flight at altitude and speed. Vw engines are more suited for planes and gyroplanes but I would be reluctant to trust one to keep me in the air in a helicopter, though that being said if a large fuel injected vw engine were to be stripped down and made as light as possible it could be feasibly done.
RPGreg2600
PostPosted: Wed Apr 23, 2014 4:41 pm    Post subject: Reply with quote
I'm with you on that. An air plane can glide if the engine stalls out, but when you suck that #3 valve in a helicopter, you're going straight down! No thanks!
sub-hatchtim
sub-hatchtim is offline
PostPosted: Wed Apr 23, 2014 5:19 pm    Post subject: Reply with quote
I'll pass
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
cdennisg
cdennisg is offline
PostPosted: Wed Apr 23, 2014 7:12 pm    Post subject: Reply with quote
Not in a gyrocopter like Campingbox posted, but in a heli, yes.
mandraks
mandraks is offline
PostPosted: Wed Apr 23, 2014 8:06 pm    Post subject: Reply with quote
most people don't know the difference, i guess
regards
Uli
cdennisg
cdennisg is offline
PostPosted: Wed Apr 23, 2014 8:19 pm    Post subject: Reply with quote
true. A pilot can auto-rotate a heli to make an impromptu gyorcopter, but the results can be less than desirous. A gyro is actually an amazing feat of flight.
sub-hatchtim
PostPosted: Thu Apr 24, 2014 5:34 pm    Post subject: Reply with quote
A pilot told me helicopter's never land it's more of a controlled crash.
I was a uh-60 repairer, after working on helicopter's I can tell you there is no way I'd fly in one of these shown above.
76 911S
Culito
11010101
Culito is offline
PostPosted: Thu Apr 24, 2014 10:40 pm    Post subject: Reply with quote
Boobs!
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
DannoT
DannoT is offline
PostPosted: Fri Apr 25, 2014 1:20 am    Post subject: Reply with quote
It's a well known saying in the aviation industry that you could here from any good pilot that an airplane wants to fly and it takes an idiot to crash one, and a helicopter wants to crash and it takes an idiot to fly one Laughing
pondoras box
pondoras box is offline
PostPosted: Fri Apr 25, 2014 8:35 am    Post subject: Reply with quote
You can land a rotary winged aircraft with an engine out no problem. In fact its part of the certification and recertification of military pilots.
The only thing that needs to happen is an automatic clutch that will allow the blades to still freely rotate if the engine or transmission should fail and seize. Then the auto gyro effect works, its like wind blowing through a fan when you free fall through the air it keeps the rotor speed up to normal operating parameters. You simply pull up on the collective and you can safely and smoothly land a helicopter without engine power.
Auto gyros on the other hand have a terrible safety record, but you can build one cheaply and use a motorcycle or snowmobile engine to power it.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
cdennisg
cdennisg is offline
PostPosted: Fri Apr 25, 2014 3:31 pm    Post subject: Reply with quote
A helicopter in auto-rotation mode is a compromise, and is rarely smooth. Yes, it is a necessary skill to learn to obtain your rotary license, but it is pretty rare to land smoothly. Here is a good example of an auto-rotation landing...
http://www.youtube.com/watch?v=MvMcsJTOYI0
A smoother auto rotate, but they don't actually land. Just practicing.
http://www.youtube.com/watch?v=pzWw5U3eCok
66uno
66uno is offline
PostPosted: Fri Apr 25, 2014 3:54 pm    Post subject: Reply with quote
I used to read the Bob Hoover "sermons". For those unfamiliar, Bob was a technical writer, a builder of vw's and vw engines both for the road and for the air. He was a pilot and a brilliant self taught engineer.
In one of his sermons, he described how the vw air cooled engine was just barely able to cool itself. He went on to explain that at higher atmospheres, were the air is thinner, it has an even more difficult time. And though they make good airplane engines, cooling it properly is always a problem.
Now, knowing all of this, it would seem very foolhardy to me to use one for a helicopter. Rolling Eyes
