Make Air-cooled Engine Compartment Air-tight
Page: Previous  1, 2
reluctantartist
reluctantartist is offline
PostPosted: Sat Jun 01, 2013 1:54 am    Post subject: Reply with quote
That black and red wire in the picture is for a cylinder head temperature gauge. Do you have one installed on your dash somewhere? If you do then you need to get a new sender that is usually installed under a spark plug.
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
onemat
onemat is offline
PostPosted: Tue May 20, 2014 2:19 pm    Post subject: Reply with quote
While I wait for my new seal to come from Bus Depot, I'm going to use duct tape between the old seal and the sides of the engine well. I hate the stuff but it will do for a few weeks. Someone in this thread mentioned a wireless temperature gauge for inside the engine compartment from Autozone. It seems to me that it's not going to give you true engine temperature. Has any figured out roughly what a is a good engine compartment temperature is? Another words, if the compartment is 200 degrees what is the engine temperature? WOuld using this kind of temperature gauge be a waste of my money?
Thanks,
Matt
'82 Vanagon GL with 2.0 4-speed. Long term plan is to turn it into a camper.
Randy in Maine
Randy in Maine is offline
PostPosted: Tue May 20, 2014 3:08 pm    Post subject: Reply with quote
Nobody cares what the engine compartment temp is.
The only temps you care about are the cylinder head temps...
http://www.dakotadigital.com/index.cfm/page/ptype=...prd347.htm
and the oil temperature....
http://www.dakotadigital.com/index.cfm/page/ptype=...prd326.htm
Oil temperature is normally sampled at the "taco plate" as it is easy to do.....
MarkWard
MarkWard is offline
PostPosted: Wed May 21, 2014 7:02 am    Post subject: Reply with quote
For a temporary seal, you might try swinging by the hardware store. On the race cars we use water heater hose insulation between the shroud and the radiator. It is gray and has a slit with adhesive running down the seam. I bet you could use that and it would fill the gap quiet neatly. Duct tape will leave a glue residue and will not stick to anything that is not perfectly clean. If you use the insulation, post a picture if it works.
ryecatcher
ryecatcher is offline
PostPosted: Wed May 21, 2014 7:25 am    Post subject: Reply with quote
Re: Duct tape: fwiw, I've heard not to use duct tape, as it can loosen and get sucked up into the fan which creates an whole mess of problems.
I've waiting on my seal to come in for a month. It seems everyone is out of it or back-ordered...
1982 Westfalia Camper, Air Cooled
"Wendeline"
MarkWard
MarkWard is offline
PostPosted: Wed May 21, 2014 9:43 am    Post subject: Reply with quote
This is what I am talking about.
You can see the slit where you could fit it of the sheet metal lip.
VWinVT
VWinVT is offline
PostPosted: Wed May 21, 2014 4:52 pm    Post subject: Reply with quote
I used that pipe insulation. I used the rubber type, not the foam, as the rubber is more pliable and forgiving. It works VERY well to fill the gaps. I have it pressed in place right now. We are in the process of moving. Once we settle, I will use contact cement to secure it to the body, as it will work itself free after about a week of daily driving (makes a great moving van)!!
reluctantartist
PostPosted: Tue Jun 24, 2014 5:46 pm    Post subject: Reply with quote
Since summer is well upon us and I see newer airheads on the forum I thought I would bump this up again so we can keep the airheads running happily down the road.
ryecatcher
PostPosted: Tue Jun 24, 2014 9:09 pm    Post subject: Reply with quote
I just did my seal, which I got from Bus Depot. Not too hard a job, just a bit painstaking at times. A one hour, much-cursing job at most. I combined it with installing new air filter an cleaning off some grounds at the same time.
"Wendeline"
a2d2
a2d2 is offline
PostPosted: Sun Apr 26, 2015 10:46 am    Post subject: Re: Make Air-cooled Engine Compartment Air-tight Reply with quote
reluctantartist wrote:
Heater tube:
The heater tube seal is NLA as well as the filler tub e seal and a few others. So you will have to get good at using RTV or something else to make one. This is what I did for my heater tube (luckily my oil filler seal is still good)
Does anyone have a picture of the oil filler seal in use? I have never seen one and a search just gave me a lot of fuel filler seals.
Need to fabricate something here and am hoping to keep it looking "stock-ish" and removable so would prefer to not use RTV.
Thanks!
1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.)
Mark70baja
Mark70baja is offline
PostPosted: Sun Apr 26, 2015 11:01 am    Post subject: Thanks. Reply with quote
Getting our 82 out and on the road. Hadn't even thought of filling all the holes, of which there are many. It's on the list. Learn something new and vital every time I visit this group. And I'm very happy to see so many Air Cooled posts. Thanks again.
Try talking yours ideas up, without talking other peoples ideas down. Everyone stays much happier that way.
82 Vanagon with ASI Full Camper Conversion, 2010 Jeep Rubicon
sandoz
sandoz is offline
PostPosted: Sun Apr 26, 2015 3:20 pm    Post subject: Reply with quote
1983 Air Cooled Westy (Shaniqua)
sandoz
sandoz is offline
PostPosted: Sun Apr 26, 2015 3:49 pm    Post subject: Reply with quote
Pouring rain out and I don't have a picture of one installed.... Hope a couple of pics of one out will do. It isn't easy to install with all the tin in place but it can be done....
a2d2
a2d2 is offline
PostPosted: Sun Apr 26, 2015 6:45 pm    Post subject: Reply with quote
Thanks for the pics, very helpful. I think I can picture how that fits in the tin so now I just have to search for something similar to modify.
Looks easy enough to reproduce, strange that no one's done it yet.
sandoz
sandoz is offline
PostPosted: Sun Apr 26, 2015 7:15 pm    Post subject: Reply with quote
De nada, glad I could give you a visual....
I am also befuddled as to why this part is not reproduced, seems simple enough?!
nunzio82
nunzio82 is offline
PostPosted: Sun Jun 16, 2019 2:15 pm    Post subject: Re: Make Air-cooled Engine Compartment Air-tight Reply with quote
If I use RTV high temp sealant as another poster suggested will or can it cause any hot spots on my engine? Should I avoid using it in the engine bay?
1982 Westfalia camper vanagon air-cooled
daroota
daroota is offline
PostPosted: Fri Jun 21, 2019 10:36 am    Post subject: Re: Make Air-cooled Engine Compartment Air-tight Reply with quote
Check Out VersiMould. You can make a nice seal out of these for around the engine tin. Like for the cooling tubes and oil filler
1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Air Cooled Vanagon's FaceBook Group:
www.facebook.com/groups/AirCooledVanagon/
fiftytakedowns
fiftytakedowns is offline
PostPosted: Tue Aug 20, 2019 9:53 pm    Post subject: Re: Make Air-cooled Engine Compartment Air-tight Reply with quote
What type of temperature drops could I expect after performing all these sealing tips.
My van doesn't run too hot, but I haven't climbed the mountain yet... Whats the CHT danger zone?
TEAM USA Greco Roman Wrestling 67KG
www.mogotraining.com
daroota
daroota is offline
PostPosted: Wed Aug 21, 2019 4:54 am    Post subject: Re: Make Air-cooled Engine Compartment Air-tight Reply with quote
Temps you want should be under 400f.
At 430, is when aluminum starts to warp, and it's especially important on how you bring the temperatures back down again. At 450+ it is critical, slowly bring the temperatures back down otherwise if you bring it down too quickly the engine may definitely Warp. You may cause other damage like blowing out seals, damaging rings, Pistons, recessing valves, or worse.
Typical temperatures are about 290 Fahrenheit to 400. This also brings into the equation just how accurate a cylinder head temperature gauge is as well. O have a vdo that I've had a few years now, it shows me about 48f hotter on the gauge. I used an ir thermometer and check it now and then and idle, warm and hot.
Page: Previous  1, 2
Page 2 of 2
