reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1929 Location: Bloomington, IN
Posted: Sat Jun 01, 2013 1:54 am Post subject: |
That black and red wire in the picture is for a cylinder head temperature gauge. Do you have one installed on your dash somewhere? If you do then you need to get a new sender that is usually installed under a spark plug. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
onemat Samba Member
Joined: November 17, 2011 Posts: 418 Location: Ashland City, TN
Posted: Tue May 20, 2014 2:19 pm Post subject: |
While I wait for my new seal to come from Bus Depot, I'm going to use duct tape between the old seal and the sides of the engine well. I hate the stuff but it will do for a few weeks. Someone in this thread mentioned a wireless temperature gauge for inside the engine compartment from Autozone. It seems to me that it's not going to give you true engine temperature. Has any figured out roughly what a is a good engine compartment temperature is? Another words, if the compartment is 200 degrees what is the engine temperature? WOuld using this kind of temperature gauge be a waste of my money?
Thanks,
Matt _________________ '82 Vanagon GL with 2.0 4-speed. Long term plan is to turn it into a camper. |
Randy in Maine Samba Member
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18824 Location: Retired South Florida
Posted: Wed May 21, 2014 7:02 am Post subject: |
For a temporary seal, you might try swinging by the hardware store. On the race cars we use water heater hose insulation between the shroud and the radiator. It is gray and has a slit with adhesive running down the seam. I bet you could use that and it would fill the gap quiet neatly. Duct tape will leave a glue residue and will not stick to anything that is not perfectly clean. If you use the insulation, post a picture if it works. |
ryecatcher Samba Member
Joined: January 02, 2014 Posts: 81 Location: Tampa, Florida
Posted: Wed May 21, 2014 7:25 am Post subject: |
Re: Duct tape: fwiw, I've heard not to use duct tape, as it can loosen and get sucked up into the fan which creates an whole mess of problems.
I've waiting on my seal to come in for a month. It seems everyone is out of it or back-ordered... _________________ 1982 Westfalia Camper, Air Cooled
"Wendeline" |
Posted: Wed May 21, 2014 9:43 am Post subject: |
This is what I am talking about.
You can see the slit where you could fit it of the sheet metal lip. |
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Wed May 21, 2014 4:52 pm Post subject: |
I used that pipe insulation. I used the rubber type, not the foam, as the rubber is more pliable and forgiving. It works VERY well to fill the gaps. I have it pressed in place right now. We are in the process of moving. Once we settle, I will use contact cement to secure it to the body, as it will work itself free after about a week of daily driving (makes a great moving van)!! |
Posted: Tue Jun 24, 2014 5:46 pm Post subject: |
Since summer is well upon us and I see newer airheads on the forum I thought I would bump this up again so we can keep the airheads running happily down the road. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
Posted: Tue Jun 24, 2014 9:09 pm Post subject: |
I just did my seal, which I got from Bus Depot. Not too hard a job, just a bit painstaking at times. A one hour, much-cursing job at most. I combined it with installing new air filter an cleaning off some grounds at the same time. _________________ 1982 Westfalia Camper, Air Cooled
"Wendeline" |
a2d2 Samba Member
Joined: March 28, 2013 Posts: 366 Location: EastVanagon, BC
Posted: Sun Apr 26, 2015 10:46 am Post subject: Re: Make Air-cooled Engine Compartment Air-tight |
reluctantartist wrote: |
Heater tube:
The heater tube seal is NLA as well as the filler tub e seal and a few others. So you will have to get good at using RTV or something else to make one. This is what I did for my heater tube (luckily my oil filler seal is still good) |
Does anyone have a picture of the oil filler seal in use? I have never seen one and a search just gave me a lot of fuel filler seals.
Need to fabricate something here and am hoping to keep it looking "stock-ish" and removable so would prefer to not use RTV.
Thanks! _________________ 1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.) |
Mark70baja Samba Member
Joined: August 13, 2008 Posts: 152 Location: Heron, MT
Posted: Sun Apr 26, 2015 11:01 am Post subject: Thanks. |
Getting our 82 out and on the road. Hadn't even thought of filling all the holes, of which there are many. It's on the list. Learn something new and vital every time I visit this group. And I'm very happy to see so many Air Cooled posts. Thanks again. _________________ Try talking yours ideas up, without talking other peoples ideas down. Everyone stays much happier that way.
82 Vanagon with ASI Full Camper Conversion, 2010 Jeep Rubicon |
sandoz Samba Member
Joined: November 17, 2007 Posts: 86 Location: Denver, CO
Posted: Sun Apr 26, 2015 3:20 pm Post subject: |
_________________ 1983 Air Cooled Westy (Shaniqua) |
sandoz Samba Member
Posted: Sun Apr 26, 2015 3:49 pm Post subject: |
Pouring rain out and I don't have a picture of one installed.... Hope a couple of pics of one out will do. It isn't easy to install with all the tin in place but it can be done.... _________________ 1983 Air Cooled Westy (Shaniqua) |
a2d2 Samba Member
Posted: Sun Apr 26, 2015 6:45 pm Post subject: |
sandoz wrote: |
Pouring rain out and I don't have a picture of one installed.... Hope a couple of pics of one out will do. It isn't easy to install with all the tin in place but it can be done.... |
Thanks for the pics, very helpful. I think I can picture how that fits in the tin so now I just have to search for something similar to modify.
Looks easy enough to reproduce, strange that no one's done it yet. _________________ 1981 Vanagon, Aircooled 2.0 AFC
sandoz Samba Member
Posted: Sun Apr 26, 2015 7:15 pm Post subject: |
De nada, glad I could give you a visual....
I am also befuddled as to why this part is not reproduced, seems simple enough?! _________________ 1983 Air Cooled Westy (Shaniqua) |
nunzio82 Samba Member
Joined: April 05, 2019 Posts: 14 Location: Los Angeles
Posted: Sun Jun 16, 2019 2:15 pm Post subject: Re: Make Air-cooled Engine Compartment Air-tight |
If I use RTV high temp sealant as another poster suggested will or can it cause any hot spots on my engine? Should I avoid using it in the engine bay? _________________ 1982 Westfalia camper vanagon air-cooled |
daroota Samba Member
Posted: Fri Jun 21, 2019 10:36 am Post subject: Re: Make Air-cooled Engine Compartment Air-tight |
nunzio82 wrote: |
If I use RTV high temp sealant as another poster suggested will or can it cause any hot spots on my engine? Should I avoid using it in the engine bay? |
Check Out VersiMould. You can make a nice seal out of these for around the engine tin. Like for the cooling tubes and oil filler _________________ 1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Air Cooled Vanagon's FaceBook Group:
www.facebook.com/groups/AirCooledVanagon/ |
fiftytakedowns Samba Member
Posted: Tue Aug 20, 2019 9:53 pm Post subject: Re: Make Air-cooled Engine Compartment Air-tight |
What type of temperature drops could I expect after performing all these sealing tips.
My van doesn't run too hot, but I haven't climbed the mountain yet... Whats the CHT danger zone? _________________ TEAM USA Greco Roman Wrestling 67KG
www.mogotraining.com |
Posted: Wed Aug 21, 2019 4:54 am Post subject: Re: Make Air-cooled Engine Compartment Air-tight |
Temps you want should be under 400f.
At 430, is when aluminum starts to warp, and it's especially important on how you bring the temperatures back down again. At 450+ it is critical, slowly bring the temperatures back down otherwise if you bring it down too quickly the engine may definitely Warp. You may cause other damage like blowing out seals, damaging rings, Pistons, recessing valves, or worse.
Typical temperatures are about 290 Fahrenheit to 400. This also brings into the equation just how accurate a cylinder head temperature gauge is as well. O have a vdo that I've had a few years now, it shows me about 48f hotter on the gauge. I used an ir thermometer and check it now and then and idle, warm and hot. _________________ 1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
