Source for original tar boards
Page: Previous  1, 2, 3
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Tue Feb 11, 2014 1:11 pm    Post subject: Reply with quote
I'm searching some og ones .... can someone help me please ?
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
TimmyH79
TimmyH79 is offline
PostPosted: Mon Jun 02, 2014 10:24 am    Post subject: Reply with quote
Hey everyone, just wanted to post here for others who might be considering options that I ended up deciding on using 1/4" Dynaliner (can buy from amazon). The below pictures used two of the 32"x54" boxes and there was enough left over to do some of the nose area also - the total material cost was right around $100.
Obviously the logo is not ideal but overall I think it looks clean. My bus had to have a full resto as it had been a bit hacked so my thought was putting in some salvaged tar paper wouldn't look right and this seemed like a good alternative from a looks and functionality perspective:
'66 SO-42
Previous:
'67 21-Window Dual-Slider
'79 Westfalia
kirbyland
kirbyland is offline
PostPosted: Thu Oct 16, 2014 9:15 pm    Post subject: Reply with quote
Anyone have close up pics of the OG material? I have an idea of how I could possibly reproduce the strips- but need a good pic of the fibers/grain?
Clara Premium Member
Clara is offline
PostPosted: Thu Oct 16, 2014 10:19 pm    Post subject: Reply with quote
just some tar strips pics for reference.
my 61 flipseat:
kirbyland
PostPosted: Fri Oct 17, 2014 6:00 am    Post subject: Reply with quote
thanks Clara- I have an idea. Once I get materials together, and figure a couple things out, I'll try and get pics up. I think I can come damn close-
Touch Nicks Thing
Touch Nicks Thing is offline
PostPosted: Wed Aug 03, 2016 4:05 pm    Post subject: Re: Source for original tar boards Reply with quote
Anyone sitting on a pile of strips they want to get rid of? I need some for my SO-33.
Peter_N
Peter_N is offline
PostPosted: Fri Feb 02, 2018 4:46 am    Post subject: Re: Source for original tar boards Reply with quote
Could anyone please provide the width of the OG tar strips?
I’m about to order some sheets of comparable material and cut it in strips.
Thanks Very Happy
My 1958 PGSG project topic
bullethead
bullethead is offline
PostPosted: Mon Nov 26, 2018 1:10 pm    Post subject: Re: Source for original tar boards Reply with quote
Glad to know I'm not alone in wanting to get this detail right! Have searched for every potential analog to the original material and believe the old-style asphaltum/natural fiber concrete joint is the closest. Will shortly order some of this:
https://www.cmcconstructionservices.com/w-r-meadows-of-texas-expansion-joint-type
Although I was able to save a few pieces, most tore when trying to remove with a razor scraper. Anyway, I've got something to compare with the new stuff. My bus is fresh from paint and I really want something that looks correct... will post results ASAP.
Russ
Vintage Driven... Oil Cooled
'62 Porsche 356 Notchback Hotrod
'63 VW Type 34 Karmann Ghia
'64 VW Bus 21 Deluxe Samba
'67 Porsche 911 S
'68 Porsche 911 T Targa
'68 Porsche 911 L Soft Window Targa
'70 Porsche 914/6 GT
mastorna
mastorna is offline
PostPosted: Wed Jul 31, 2019 6:45 pm    Post subject: Re: Source for original tar boards Reply with quote
a quick bump on this thread. Anyone know of any better tar insulation \ board to use for restoration that is faithful to the original?
1959 Type II Mango SO-23
1962 Type II Kombi Light Gray
1963 Type II Standard Sunroof SWR\BG
1963 Type II Deluxe MG\PW
missmybus
missmybus is offline
PostPosted: Sun Dec 29, 2019 9:04 am    Post subject: Re: Source for original tar boards Reply with quote
Here’s what I used to replicate the tar paper strips for the rear luggage platform in my 64 deluxe. Bought two rolls of the traction/safety paper tape that’s used on stairs. It’s 6” wide and 20’ long. All my cuts were either 2 1/2” or 2 1/4”. It has an adhesive back and all for under $40! I know it’s not the purest original source, but it works for me. Hope this helps!
Brian
64 Deluxe
PostPosted: Sun Dec 29, 2019 9:30 am    Post subject: Re: Source for original tar boards Reply with quote
Do you feel like it quieted things down a lot?
It looks good but they appear a lot thinner than the original tar boards.
Modern materials are often more efficient so maybe they are just as effective?
missmybus
PostPosted: Sun Dec 29, 2019 9:41 am    Post subject: Re: Source for original tar boards Reply with quote
I don’t have anything to compare it with since I never drove the bus as an original owner. Still need to buy the carpet to install and upholster the bus too. I know it’s not close to the original, but it was easy to install the price was right👍🏼
64 Deluxe
Clara is offline
PostPosted: Sun Dec 29, 2019 6:25 pm    Post subject: Re: Source for original tar boards Reply with quote
x2. Part of the reason for these is to make the area the carpet or rear board goes on flat/ level.
With carpet you can really see the corrugations if the tar strips or something else of the same thickness isn't there.
missmybus
PostPosted: Mon Dec 30, 2019 6:59 pm    Post subject: Re: Source for original tar boards Reply with quote
Good point👍🏼
64 Deluxe
Tizian
Tizian is offline
PostPosted: Tue Dec 31, 2019 5:43 am    Post subject: Re: Source for original tar boards Reply with quote
Google Antidröhnstreifen Wink
There must be something similar in the US. Those are used for noise dampening under windowsills...
Vintage Auto Werks1
Vintage Auto Werks1 is offline
PostPosted: Tue Dec 31, 2019 7:23 am    Post subject: Re: Source for original tar boards Reply with quote
If anyone wanted to try the MB insulation again the price went down.
https://www.mboemparts.com/oem-parts/mercedes-benz-water-shield-2046820108
bullethead
PostPosted: Thu Apr 16, 2020 11:11 am    Post subject: Re: Source for original tar boards Reply with quote
So the roofing materials were way too stiff... and realizing the OG material was probably a lot more flexible when it was installed way back when, decided to look into automotive insulation suppliers. I got this stuff from Sutherland Felt, correct thickness (4mm) cut to size and adhesive backed. Thought about spraying a light coat of rubberized undercoating on it to get as close to the feel of the original, but decided against it. A breeze to install, ordered in different widths as needed, just cut to length.
Total cost was about $160 (I over ordered)... not bad and results look and feel right, at least to me. Very Happy
Russ
'67 Porsche 911 S
bullethead
PostPosted: Sun Jun 07, 2020 11:35 am    Post subject: Re: Source for original tar boards Reply with quote
Here's an OG piece and the new felt for comparison... I used a thicker material for the bulkhead.
Russ
'67 Porsche 911 S
RockStock
RockStock is offline
PostPosted: Mon Jan 10, 2022 11:40 am    Post subject: Re: Source for original tar boards Reply with quote
I am at the point where I could really do with some original looking material here for my ‘55
Doesn’t feel right to use a modern alternative…
I think it would really let the bus down
Very htf original remnants…plus you need plenty of it
Anyone on the verge of reproducing it?
Know a very close match?
Linked thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=763578
-StockRocks-
thom
thom is offline
PostPosted: Wed Jun 25, 2025 10:12 am    Post subject: Re: Source for original tar boards Reply with quote
bullethead wrote:
[...]I got this stuff from Sutherland Felt, correct thickness (4mm) cut to size and adhesive backed. Thought about spraying a light coat of rubberized undercoating on it to get as close to the feel of the original, but decided against it. A breeze to install, ordered in different widths as needed, just cut to length.
What was the actual product you bought?
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Page 3 of 3
