vanis13 Samba Member
Joined: August 15, 2010 Posts: 4593 Location: ABQ NM USA.... Except when not
Posted: Sun Aug 03, 2014 5:16 pm Post subject: Luggage Rack drain hole filters / screens EASY! |
Luggage Rack drain filter / screen
After cleaning out the gunk under the luggage rack I was inspired by these -
http://www.thesamba.com/vw/forum/viewtopic.php?t=600673&highlight=luggage+rack
http://www.thesamba.com/vw/forum/viewtopic.php?t=451036
I wanted to access the outside and remove easily if need be. I did not want to glue or rivet anything in so I found these at the True Value bins. Had to slightly enlarge hole to 5/8". If drilling keep in mind the front/center hole is only about 1/2" below the roof rack.
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Wellington Samba Member
Joined: September 21, 2004 Posts: 2020 Location: Montreal
Posted: Sun Aug 03, 2014 5:45 pm Post subject: |
Excellent, let's see how they hold out to UV rays.
Nice idea. |
Posted: Sun Aug 03, 2014 5:53 pm Post subject: |
Thanks! Did consider the UV and am curious too. Luckily the replacement cost is low. The specification pic cut off the price but they're $0.43 each or $2.50 w/tax for all 5 _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
campism Samba Member
Joined: September 07, 2007 Posts: 4716 Location: Richmond VA
Posted: Mon Aug 04, 2014 7:47 am Post subject: |
Nifty idea. Now all you need is some Penetrol on the luggage rack, and maybe on the rest of the poptop. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Mon Aug 04, 2014 1:42 pm Post subject: |
| campism wrote: |
| Nifty idea. Now all you need is some Penetrol on the luggage rack, and maybe on the rest of the poptop. |
Except... Penetrol is said to turn white tops to yellow. Works great on colored tops.
Op- if you're concerned about uv... spray some 303 on em. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Jamos Samba Member
Joined: July 08, 2005 Posts: 766 Location: Lake Tahoe, CA
Posted: Mon Aug 04, 2014 8:32 pm Post subject: |
| ThankYouJerry wrote: |
| campism wrote: |
Op- if you're concerned about uv... spray some 303 on em. |
I've used Penetrol on my white Westy top many times. Any yellow haze is extremely minimal.
Good idea with the drainage hole fillers. I wonder how easily they'll clog? _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
Posted: Mon Aug 04, 2014 9:05 pm Post subject: |
| Jamos wrote: |
| I've used Penetrol on my white Westy top many times. Any yellow haze is extremely minimal. |
Will you please post some photos of your white top with Penetrol in this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...;start=100
I've been looking to see how bad the yellowing is (or isn't). Thanks! _________________ 1990 Multivan - "Ohana"
Terry Kay Banned
Posted: Mon Aug 04, 2014 9:56 pm Post subject: |
As I've mentioned ever since I introduced the possibility of using the Penetrol years ago to brighten up the faded pop tops to almost new, I did mention that the stuff gives a slight yellowish haze to white.
I used it on a 22 ft. chaulked out cuddy cabin boat I acquired for just about nothing, and rubbed my ass of--to no avail.
The gelcoat would not stay bright at all over a weeks period of time.
I got tired of buffing & rubbing, and an old salt I knew introduced the stuff to me to restore the fiberglass finish & make it last.
This was back in 1978.
It was not at all terrible or really obvious---
But it did last the duration of the summer--
So for a once a year application on the deck & hull it was well worth the time , and the faint yellowish tinge.
If your pop top is really hairey & scanky--forget about the Penetrol.
It was not sent by Jesus to resurrect a dead porus fiberglass top--
Dulled out & chauky--yes it will work fine, and last for a long time.
If it's got hair growing--Petit , Awlgrip, or Interlux white deck & hull paint is going to be your only saviour.
Then you won't have to worry about the slight yellowish cast of the Penetrol.
Be adventerous--do something, it's all a learning experience. _________________ T.K. |
Posted: Tue Aug 05, 2014 4:24 am Post subject: |
| Jamos wrote: |
| Good idea with the drainage hole fillers. I wonder how easily they'll clog? |
Thanks. So far so good.
One of the things I was hoping for was since they are on the top rather than the bottom of the hole I could wipe off what ever was clogging them and what ever was small enough to go through would be small in size. Also, they could be removed easily from the top for cleaning or removal is the OEM holes turned out to be preferable. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
MrBuelterman Samba Member
Joined: February 12, 2014 Posts: 91 Location: Seattle WA
Posted: Wed Aug 06, 2014 11:32 am Post subject: |
| vanis13 wrote: |
| Thanks! Did consider the UV and am curious too. Luckily the replacement cost is low. The specification pic cut off the price but they're $0.43 each or $2.50 w/tax for all 5 |
McMaster Carr has 100 for 5.66 in black or white
http://www.mcmaster.com/#push-in-grommets/=t5xviv _________________ 86 2.4L 2WD Peloquin Westy |
Posted: Wed Aug 06, 2014 1:52 pm Post subject: |
| MrBuelterman wrote: |
| vanis13 wrote: |
http://www.mcmaster.com/#push-in-grommets/=t5xviv |
Nice! and there you can get them in white. still min hole dia is 5/8.
guess a 20-bus group buy is in order Figured I paid my shipping to the True Value.
Wouldn't be surprised to see these on GoWesty in the future  _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
backyard_cnc Samba Member
Joined: July 20, 2012 Posts: 385 Location: MANITOBA CANADA
Posted: Wed Aug 06, 2014 7:46 pm Post subject: |
great idea, in fact I have dozens of those in my radio install box for work so a no cost install for me. Gotta like that as it doesn't happen too often with westy's
thanks for sharing |
Jamos Samba Member
Posted: Sat May 06, 2017 8:22 pm Post subject: |
| vanis13 wrote: |
| Jamos wrote: |
One of the things I was hoping for was since they are on the top rather than the bottom of the hole I could wipe off what ever was clogging them and what ever was small enough to go through would be small in size. Also, they could be removed easily from the top for cleaning or removal is the OEM holes turned out to be preferable. |
its 2017 and originls still working and holding together just fine _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sun May 07, 2017 8:36 am Post subject: Re: Luggage Rack drain hole filters / screens EASY! |
When I had my luggage compartment off, I siliconed some screen t of the bottom the holes. They clogged up horribly and the luggage compartment didn't drain so a lot of dirt and grime stayed in the luggage rack after the water evaporated.
I'm not sure if anything is different in the way I did it, but I would not recommend this "upgrade". But it was easy enough to poke out the screens to put it back to normal. It might work with a different type of screen, more of a mesh than a screen. It just clogs too easily. |
bluebus86 Banned
Posted: Sun May 07, 2017 10:27 am Post subject: Re: Luggage Rack drain hole filters / screens EASY! |
| davevickery wrote: |
My thpughts too, why make the drain less effective, higher risk of clogging?
how about a screen or other cover over the luggage well to exclude clogging debris, or better still a solid water tight cover?
now if debris is a problem of clogging the stock drains, a rather large screen one that stands high, and larger diameter than the drain hole could serve to keep the drain clear for a longer period between periodic cleaning, as the surface area of that filter would be much larger than a tiny drain insert Seams one leaf could block this insert filter, Go for a larger filter if frequent blockages to the stock system are a problem.
good luck, may all your problems drain away _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10305 Location: Mt Lemmon, AZ
Posted: Sun May 07, 2017 12:08 pm Post subject: Re: Luggage Rack drain hole filters / screens EASY! |
Of course the traditional item for those holes are washing machine hose filters:
Most things that stop the stuff will also clog - but these are easy to pop out and back in. |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4624 Location: East Kootenay, British Columbia
Posted: Sun May 07, 2017 1:44 pm Post subject: Re: Luggage Rack drain hole filters / screens EASY! |
| bluebus86 wrote: |
| My thpughts too, why make the drain less effective, higher risk of clogging? |
If you owned a Westy you would know that the drain holes let dirt, small leaves, etc. to collect under the luggage rack where, if left unchecked, will cause rust. It's a bit of a pain the remove the luggage rack to clean so the screens help.
I just use a garden hose to clean the screens I installed on mine whenever I wash the van. We have very fine Tamarack needles around here in the fall and only the fine metal screens from faucets/washing machines work to keep them out. (I just bought the stainless screens only from Ace and epoxied them on) The rest of the year they don't really clog. I guess it's gonna matter where you live and what kind of debris you get. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
bluebus86 Banned
Posted: Sun May 07, 2017 4:02 pm Post subject: Re: Luggage Rack drain hole filters / screens EASY! |
| MsTaboo wrote: |
| bluebus86 wrote: |
I just use a garden hose to clean the screens I installed on mine whenever I wash the van. We have very fine Tamarack needles around here in the fall and only the fine metal screens from faucets/washing machines work to keep them out. (I just bought the stainless screens only from Ace and epoxied them on) The rest of the year they don't really clog. I guess it's gonna matter where you live and what kind of debris you get. |
if you knew about filters, you'd know a larger one is less likely to clog as fast as a small one. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon May 08, 2017 7:06 am Post subject: Re: Luggage Rack drain hole filters / screens EASY! |
the purpose of this screes solution:
screen is on top so easily manually wiped clear unlike screen on bottom gluing mesh underneath where it created a well for debis to collect in
easily removable of it doesn't suit needs
mesh is not too big or not too small for what neds to get filtered in my climate. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
