khalimadeath Samba Member
Posted: Tue Sep 02, 2014 8:53 pm Post subject: Trouble finding specifics on Carb..( I searched) |
I have a single port 1600 (70 Bay). I got it with a new carb, I am unaware of the brand. It is running rich so while the motor is out I want to re jet it.
My buddy is familiar with Carbs and will jet it for me but he is making me do the foot work.
First: I am having a very hard time finding JUST the jet kit for my carb on my motor.. all I can seem to find is whole carbs.
Second: Once I order said kit I'd like to know if there is a chart that exists that shows what jetting to do for my elevation (4400 feet).
Thanks for any help my eyes hurt from scrolling through numerous threads.
Here is a pic for good measure.
and here is what was inside my transmission bell housing..(TOB)
Brian Samba Moderator
Posted: Tue Sep 02, 2014 8:57 pm Post subject: |
T/O bearings are relatively cheap (I keep telling myself) so that's not a huge loss, but a bummer.
Are you sticking to a 1600 Single Port? That carb is either a bocar or solex, doesn't matter get a refurbished one. Not new, refurb. http://volkzbitz.com/ talk to him direct and ask for some jet advice, this guy does carbs so I would trust what he has to say. If you're looking to have a growing motor, choose wisely. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1418 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Tue Sep 02, 2014 9:05 pm Post subject: |
Check at ACN he has jets for most carbs :0)
http://vwparts.aircooled.net/Fuel-System-VW-Carburetors-s/169.htm _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
Posted: Tue Sep 02, 2014 10:47 pm Post subject: |
Ok so ive just discovered I have an aftermarket 009 distributor. I dont believe it was the one intended for my motor ( was swapped out at some point). My Carb has vacuum ports to be connected to a vacuum assist distributor.
Carb is a Solex H30 31PICT on a 1600 single port.
Should I change the distributor and to what?
This one
http://www.busdepot.com/186504
or maybe this one
http://www.busdepot.com/300908 |
Posted: Wed Sep 03, 2014 3:38 am Post subject: Re: Trouble finding specifics on Carb..( I searched) |
khalimadeath wrote: |
Thanks for any help my eyes hurt from scrolling through numerous threads. |
You need to know what jets are in your carb at present to know which ones you need to buy. |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4728 Location: Arizona Highways
Posted: Wed Sep 03, 2014 7:38 am Post subject: |
That is a part of the pressure plate, not the release bearing.
A common mix up on those carbs is the idle jets get switched.
The 50 should be in the "normal" spot and the 65 should be in the diagonal spot.
009s work well with the H30/31s.
I live and work on VWs @ 5500ft and don't normally re-jet Solex carbs on stock engines. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Sep 03, 2014 8:51 am Post subject: |
borninabus wrote: |
I live and work on VWs @ 5500ft and don't normally re-jet Solex carbs on stock engines. |
Good to know I will check this.. So you recommend keeping the 009 dizzy? There is a line coming off the carb I think you can see in the pic that is plugged. Im not sure why. |
wcfvw69 Samba Purist
Posted: Wed Sep 03, 2014 9:47 am Post subject: |
That carb you have is typically a good aftermarket one vs. say a EMPI carb. I'm running one w/my 70's bus that has a 1776 in it. I'm also running a German 009 and it works ok. I personally prefer original vacuum distributors so I bought a used 205T distributor that was on these bus's back in 1970. I have the shim kit, new fiber washers and a NOS vacuum can for it as well. I also bought a used German steel/copper vacuum line too. Both of my bone stock bugs are running their original, rebuilt distributors 205k in the 67 and 205T in the 69. They are ssoo smooth and responsive. Some love the 009 and have good luck with them as well.
As far as your jetting, most of those 30/31's have big main jets out of the box. I bet your's has a 127.5 in it. If you're running a 1600 at that elevation, you should try a 116 or 120 in it. When I lived in Denver, I had both of my main jets set to 116 and both engines like it. Now in PHX, I'm running 125's in them.
http://www.vw-resource.com/mihov_index.html
This VW site I linked to has some great information on most of the carbs and distributors we use. They also have some jetting recommendations as well. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Sep 03, 2014 10:22 am Post subject: |
wcfvw69 wrote: |
This VW site I linked to has some great information on most of the carbs and distributors we use. They also have some jetting recommendations as well. |
Ok great info. I stumbled across that site during my searches late last night. I started to get some estimated sizes for my jets but got hung up once i found that I didnt have the vacuum assist dizzy since it can vary on some of the jetting if you have it or not. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17641 Location: San Diego, California
Posted: Wed Sep 03, 2014 10:39 am Post subject: |
Take a close look at the side of that carb and let us know who makes it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Sep 03, 2014 1:31 pm Post subject: |
aeromech wrote: |
Take a close look at the side of that carb and let us know who makes it. |
brazilian solex |
Posted: Wed Sep 03, 2014 1:34 pm Post subject: |
That sounds good. Have you taken it off and pulled it apart? Blow it out and make sure it's all good before you start jetting. I'd figure out what it's supposed to have and see what it does have. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed Sep 03, 2014 7:05 pm Post subject: |
aeromech wrote: |
That sounds good. Have you taken it off and pulled it apart? Blow it out and make sure it's all good before you start jetting. I'd figure out what it's supposed to have and see what it does have. |
yea thats what im doing ATM. Im thinking I may have the correct numbers for the jets I will need. |
Posted: Wed Sep 03, 2014 9:06 pm Post subject: |
Ok so Current Jets installed on Carb
Idle fuel Jet - 65
Auxiliary Fuel jet- 50
Main -120
Air correction- 125
So again I am running rich, I would rather be a little rich then too lean. So where to go from here to get a good mixture as well as pass smog. Thanks!! |
Posted: Wed Sep 03, 2014 9:42 pm Post subject: |
Idle fuel Jet - 65
Main -120
Air correction- 125
Those are all stock jets but I'm surprised it had only a 120 main.
Question, how do you know it's running rich? Smell? Soot on the exhaust tips? Was the carb adjusted correctly when it was running? What's the compression like? Where the valves adjusted? How are the spark plugs, cap, rotor, points, etc? If you're not sure of any of these things, I'd start there. Adjust the valves. Check the compression. If the compression is good, replace all the tune up stuff if you're not sure how old it is. Cap, rotor, points, Condenser, spark plug wires, etc.. Then adjust the carb to spec.
Is it a 1600 engine? If it is, I'd be leery to go lower than a 120 main with a 1600 in a heavy bus. As you stated, you don't want to be lean in that situation. _________________ Contact me at [email protected]
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13485 Location: West Coast, USA
Posted: Wed Sep 03, 2014 9:58 pm Post subject: |
Where in the "United States" are you. Depending on how the smog tests are done, we will recommend different setups. I loved my 009 and 30/31 combo. But if I was testing in California, I would go with the vacuum-only distributor (which plays well with your carb) and gives you a slightly more retarded idle than an SVDA or 009-style unit. That will heat up your idle combustions and give a more complete burn. It will also give you a little more complete burn at partial throttle cruise where the other test is done. Same with Arizona, except I don't think they do the idle portion.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Thu Sep 04, 2014 8:16 am Post subject: |
wcfvw69 wrote: |
Idle fuel Jet - 65
Main -120
Air correction- 125
Is it a 1600 engine? If it is, I'd be leery to go lower than a 120 main with a 1600 in a heavy bus. As you stated, you don't want to be lean in that situation. |
Well 3 of the 4 plugs were fouled pretty bad. Black as hell. All of the above mentioned items are being replaced. The smell combined with reoccurring backfire made me believe that it was running rich however since the jets are stock I may just run them until I adjust the valves ect and see where I am at. I am in Reno NV so frequent weather changes and varying temperature here. Im not too worried about smog. |
Randy in Maine Samba Member
Posted: Thu Sep 04, 2014 10:03 am Post subject: |
What plugs are you running? |
Posted: Thu Sep 04, 2014 12:23 pm Post subject: |
Randy in Maine wrote: |
there was some old Bosch ones in there. I will post pics of them later.. However I decided to go with some NGK copper's for the new ones, and gap e'm at .024 |
Posted: Thu Oct 22, 2015 8:16 am Post subject: |
Reviving this thread to avoid starting a new one.
I am finally getting my bus going after a long suspension overhaul, I started it up after it sat for a while. I need to time it because it was running like crap. Upon initial startup it was loading up at idle then idling back down. Once it warmed up it stopped that, I messed with the choke to keep it alive, then turned down the idle. Once I tried to drive it kept dying, I think its flooding cause I can smell the fuel. I am now pretty sure the timing is off. I set the points in my 009 distributor and now I have to time it.
I am using this link for info
http://www.oldvolkshome.com/ignition.htm#A5560
What is the recommended timing based on my set up? |
