D Clymer Samba Member
Joined: December 22, 2005 Posts: 2986 Location: Issaquah, WA
Posted: Sun Oct 26, 2014 10:06 pm Post subject: GoWesty 2700cc Wasserboxer is on the horizon. |
I was on the GoWesty website tonight and I happened to notice they have streamlined their Wasserboxer engine lineup. The 2200 and 2300 engines are the same as before. But the trouble-prone 2500 has been replaced by a 2450 engine which has the same stroke as the defunct 2500, but the pistons have been reduced 1mm in diameter to 96mm. The engine is about $1000 cheaper. Incidentally, the 2400 engine is now discontinued.
On a hunch, I checked in their library and found some intriguing new information in their piston article. http://www.gowesty.com/library_article.php?id=105 It mentions a new 2700 (2693cc) engine with 100.75mm pistons and custom made billet steel oversized cylinders. It uses the same 84.5mm stroke as the 2450 and previous 2500 engines did. I think the oversized cylinders will make all the difference here because stock cylinder wall thickness will be retained, so oil consumption shouldn't be an issue. This is the way Oettinger did it with their 2474cc Wasserboxer way back in 1987. The Oettinger 2500 engine used 98mm pistons with custom cylinders. It was done right, and it looks like GoWesty has followed the same path this time around.
The new 2700 engine has a high 10:1 compression ratio, so it is obviously designed to run with their new knock sensor equipped fuel injection system.
I'm generally not a fan of throwing huge money into the Wasserboxer. For 10K, I'd much rather have a Stephan's Autohaus 1.8T or a Subaru 2.5 from Vanaru, but I admire and respect continued evolution and refinement, and it looks like GoWesty has done a nice job of that with these new advances to the WBX platform. And it's nice to have choices.
Dave |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sun Oct 26, 2014 10:18 pm Post subject: Re: GoWesty 2700cc Wasserboxer is on the horizon. |
D Clymer wrote: |
Dave |
"For 10K" you are only about 50% of the way to Stephan's 1.8T. If I was sticking with a WBX I'd be thinking about a 10cent or RJE. There are a lot of great folks at GW but 10cent and RJE have the WBX reputations on TS. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Posted: Sun Oct 26, 2014 10:42 pm Post subject: Re: GoWesty 2700cc Wasserboxer is on the horizon. |
ThankYouJerry wrote: |
D Clymer wrote: |
Dave |
"For 10K" you are only about 50% of the way to Stephan's 1.8T. If I was sticking with a WBX I'd be thinking about a 10cent or RJE. There are a lot of great folks at GW but 10cent and RJE have the WBX reputations on TS. |
The 10K figure is a general one. My guess is the GoWesty 2700 will be around $7000 and their EFI system is $1995. That comes to about $9000 with a DIY install. The SAW 1.8T conversion package is $6480 plus another $1200-1500 for a decent AWD 1.8T engine, so about $8000. Once again, a DIY installation. The Vanaru turnkey 2.5 package is $10,800, installed. The DIY package from them is about $9800. If you look at it that way, all three options are comparable.
I know, and correspond from time to time with both Rocky Jennings and Tencentlife, so obviously I like their work. But I also like the progress GoWesty has made here by having larger cylinders made and going to a 10:1 compression ratio.
Dave |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Sun Oct 26, 2014 10:46 pm Post subject: |
With an NA engine, the added displacement really makes a lot of sense...assuming they can keep the reliability in the mix. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun Oct 26, 2014 11:22 pm Post subject: |
Zeitgeist 13 wrote: |
With an NA engine, the added displacement really makes a lot of sense...assuming they can keep the reliability in the mix. |
Yes, exactly. The added displacement and 10:1 compression ratio should be very good for low end torque.
Dave |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1046 Location: Oceans Edge
Posted: Mon Oct 27, 2014 7:13 am Post subject: |
I look forward to seeing who goes first. I know where there are some rod knocking and oil puking 2.4 and 2.5 GW cores. Owners finally gave up. I hope they come up with a decent hydraulic lifter too. I hate waiting for lifters to bleed after sitting only a week or two. Oettinger seemed to have a lot of this figured out. It always seemed crazy to me to hear all the failed 2.4 and 2.5 stories. It is not like the wheel is being reinvented? There are huge air cooled engines running hard in dune buggies, with many seasons on one build. My question is, was it tuning and maintenance that was blowing up the 2.4 and 2.5 GW engines? Not having a knock sensor? Poor fuel quality? Poor design and build quality? The history of the 2.4 and 2.5 have done Rocky Jennings and tencent well. |
Posted: Mon Oct 27, 2014 8:22 am Post subject: Re: GoWesty 2700cc Wasserboxer is on the horizon. |
D Clymer wrote: |
The 10K figure is a general one. My guess is the GoWesty 2700 will be around $7000 and their EFI system is $1995. That comes to about $9000 with a DIY install. The SAW 1.8T conversion package is $6480 plus another $1200-1500 for a decent AWD 1.8T engine, so about $8000. Once again, a DIY installation. The Vanaru turnkey 2.5 package is $10,800, installed. The DIY package from them is about $9800. If you look at it that way, all three options are comparable. |
"Vanaru turnkey 2.5 package installed for $10,800"? If you look at it that way, you are actually ahead about $10K on the SAH 1.8T installed. However, I'm sure each of those engines has it's pros and cons . _________________ 1990 Multivan - "Ohana"
Last edited by ThankYouJerry on Mon Oct 27, 2014 8:27 am; edited 1 time in total |
insyncro Banned
Posted: Mon Oct 27, 2014 8:26 am Post subject: |
I am currently testing and experimenting with a new GW 2.2.
The quality, smoothness and power are all much better than previous rebuilds I have seen from GW.
This one is a runner and the minute it starts you can tell that it has been built properly.
2.7??? No clue about how well it will perform, but with all the bolt on management upgrades GW has been working on they should provide the electronics to run a juiced WBX fairly well.
Looking forward to seeing and hearing more about it. |
imtb Samba Member
Posted: Mon Oct 27, 2014 9:23 am Post subject: |
I am trying to decide what to do myself. I really like the van but 60mph tops on the higway at close to 4000rpms is too much.
What kind of cuirsing speed do you do yo get the GW 2.2 and what kind of rpms. Do you change 4th gear? |
insyncro Banned
Posted: Mon Oct 27, 2014 9:27 am Post subject: |
imtb wrote: |
Bone stock Syncro trans.
It drives identically to stock but with about 15% more power and easily turns 215/75/15 wheels/tires.
Top speed for me in a WBX powered van is 75mph to pass on the highway.
Other than that mostly third gear on dirt roads at 3500rpms. |
Jon_slider Samba Member
Posted: Mon Oct 27, 2014 10:27 am Post subject: |
imtb wrote: |
If youre talking about a gas powered, water cooled, manual transaxle Vanagon...
A stock Vanagon goes 71mph@4000rpm.
and it is not bad for the motor to turn 4000rpm all day long, but 71mph is bad for gas mileage. I suggest you go 65mph, which should be no more than 3700rpm.
changing Motors does NOT change gearing speed and rpm. The Cursing speed is the same
I suggest you recalibrate your expectations.
No, you should not lower RPM by changing to a taller 4th.
IF you insist on lowering RPM, the simplest way to do it, is to go to a larger than stock tire.
but be forewarned, there is no free lunch. IF you lower the rpm, you will use 3rd more. And NO you will not get better fuel mileage.
Many, Many, Many people assume 4000rpm is bad for the motor. This is not true. Get used to it. Its GOOD for the motor.
btw, your speedo and tachometer are probably not accurate. Start with GPS speed, then verify if your speedo and tachometer is accurate. At 71mph GPS speed, your tach should read 4000rpm, IF you have stock 25.3" diameter tires.
What size tire do you have? _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Franklinstower Samba Member
Posted: Mon Oct 27, 2014 10:43 am Post subject: |
Jon_slider wrote: |
imtb wrote: |
btw, your speedo and tachometer are probably not accurate. Start with GPS speed, then verify if your speedo and tachometer is accurate. At 71mph GPS speed, your tach should read 4000rpm, IF you have stock 25.3" diameter tires. |
Hmm, i wonder how fast I was really going when my speedo hit 100 going down Stevens Pass with my 215/70/16 tires....Don't know what the tach said either, I was too scared to take my eyes off the road except for that split second when I saw needle at 100!  _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Mon Oct 27, 2014 10:59 am Post subject: |
I have an 89 Westy w/ a GW2.5 (and 5spd trans). We just picked up an 84 Westy (for our son) with a Vanistan 2.2 (4spd trans).
The 2.5/trans (among many other replacements/upgrades) was installed in 2009 at 170K miles. In June 2013, we had an engine failure - just passed our warranty date/miles. One of the pistons failed. Luckily we were on Hwy 101 heading home and we were only 10mi from GW when it happened!
Since our initial install, GW had redesigned (2 other revs) and changed piston manufacturers. Even though we were outside the warranty period, GW fixed it all...only charging me 50% on parts.
I had GW install their new EFI system back then. I am now on rev 2.4. The latest rev fixes the idle problem when you're running the AC. Still some fine tuning to be done --- but it's pretty good now. I think we're seeing a 1mpg improvement - but if you think that's something you want (significant mpg improvement), I would caution you not to expect that.
I think the 2.5 piston experience for GW has had a huge influence on their 2.7 project/design. I know that they have a 2.7 out on the road right now. I'll be interested in learning about HP, torque, etc. when the numbers come out. Would also like to know what (if any) adjustments will be required so that the trans can accept the additional power.
I've posted in other threads - but just to review...with the 2.5 and 5spd, we can travel at 70mph at 3Krpm. I cannot tell you what my top speed can be, but I can easily travel faster than 85mph on the open (and mostly flat) road.
If you're familiar with either the Bay Area (Hwy 17 to Santa Cruz) or traveling to Southern California via I-5, then you'll know what kind of grades you can face on those roads. On Hwy 17, I can drop down into 4th gear and go as fast as I want/safe up the hill. On I-5, on the steepest southern segments I can run 65-70mph in 4th gear. The revs are about 4200 when running that fast in 4th - but that is the sweet spot for the WBX.
In comparison, I drove our son's Westy over to Van Cafe for some preventative maintenance before we ship to him at his college. Taking Hwy 17, there is a definite drop-off in performance when it comes to hill climbing. I had to drop into 3rd gear several times in order to keep from bogging down. And if you're familiar with 4spd gearing, then you know that 3-4Krpm in 3rd gear is not going to get you up to highway speed.
That being said - the Vanistan 2.2 is a wonderful engine. Super quiet and super smooth. This particular engine has about 2K miles on it so far - but it looks to be a beauty and will do well by our son. On a flat road surface - I would say it has the same get up and go as the GW2.5.
If you don't think you'll be facing too many hills in your Westy/Vanagon (or you don't care about slowing down below 50mph), then your WBX options are wide open.
Lastly, I met a Westy owner at the last Burning Van who has a 1.8T. Loves it. And he can run up to Lake Tahoe without any issues (occasionally gearing down into 4th - but that happens with just about any vehicle).
Hope this helps... _________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Posted: Mon Oct 27, 2014 11:19 am Post subject: |
Try this
Go 70mph on your speedo. Compare that number to a GPS speed. For example, if the GPS says 65, then your speedo is optimistic by 8%. (not 6mph at other speeds)
that means If your speedo says 54mph, your GPS will say 50mph. 8%, not 4mph at other speeds.
fwiw, my speedo reads 10% lower than my actual GPS speed. When my speedo says 50mph, my actual GPS speed is 55mph. I had my speedometer calibrated at Palo Alto Speedometer. They got it wrong. It used to read 5% LOWER than GPS. They adjusted it to read another 5% LOWER. I hate that place.
my odometer reads 5% lower than actual GPS distance. When my odometer says Ive gone 100 miles, my actual GPS distance is 105 miles.
My tires are 20% larger than stock, and my ring and pinion is 12% shorter than stock, a difference of 8%, but Van speedos are notoriously inaccurate, usually optimistic, meaning actual speed is lower than indicated speed, even stock.
And as you can see, Odometer error can be totally different than speedometer error.
The speedo error is a percentage, not a fixed number. The odometer error is NOT necessarily the same as the speedometer error.
IF an Odometer is not accurate, MPG calculations are also not accurate. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3409 Location: Vancouver, B.C.
Posted: Mon Oct 27, 2014 11:28 am Post subject: |
I read with interest some years ago the GoWesty 2.5 litre engine story, including their narrative on piston failures in the initial designing and testing. What struck me all along was the resistance GoWesty appeared to have to investing in proper knock control. Telling buyers to always buy premium gas, by the way, is not a knock control system, in my opinion.
The version one 2.5 had a larger bore and the pistons had smaller cross-sections in some critical areas of the piston. It does not take many knock events at all to crack a piston. In a robust piston design, the main failure point for knocking is the piston ring lands. In the GW design, the cross-section, due to the deep dish in the WBX "Heron" design, features a very small cross-section in some critical areas which appears to be the main failure point.
Add to this the larger bore (meaning the flame front has to travel further) and a mystery deck height, and you have a recipe for knock.
Tight deck height (at or under 0.040") really helps the squish and quench available in the Heron design to resist knock. I have no idea what deck heights GW were running on these first edition 2.5 engines.
Regardless, with knock control now part of the GW package, I would be willing to bet that piston failures will decline considerably. _________________ '86 Syncro Westy SVX |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10064 Location: Where?
Posted: Mon Oct 27, 2014 11:34 am Post subject: |
I'd much rather see forced induction than larger displacement. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
imtb Samba Member
Posted: Mon Oct 27, 2014 12:28 pm Post subject: |
Mine is 86 syncro with 4speed and 2.1 water boxer. I have 15" wheels. I can feel the sweet spot is around 59 60mph, I installed some 1.25 rockers and it perfomred better on the higway, but suffered around town so, I put the stock rockers back in. I would like to try 1.25 rockers on exhaust and stock on intake. I also have RMW exhaust. I want to check my speedo to GPS.
I like the water boxer being the orginal engine and 2.5 or 2.7 would porbably move it down the road pretty good.
What about a turbo on the water boxer low boost work with the stock FI? |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Outback Kampers Samba Member
Joined: December 29, 2004 Posts: 2343 Location: Oregon Outback
Posted: Mon Oct 27, 2014 5:39 pm Post subject: |
Andrew A. Libby wrote: |
I'd much rather see forced induction than larger displacement. |
Exactly! Does the name Marco Mansi ring any bells for folks here? Search youtube for videos of his monster-power turbo waterboxers in drag Beetles. Stock displacement. https://www.youtube.com/watch?v=KBJsxwRKVIE
Turbos will almost always achieve better torque with less fuel. _________________ Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI |
Posted: Mon Oct 27, 2014 6:06 pm Post subject: |
That's awesome. 638hp from a WBX. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
