List of Parts worth saving and Rebuilding
1vw4x4
Banned
1vw4x4 is offline
PostPosted: Mon Feb 09, 2015 7:02 pm    Post subject: List of Parts worth saving and Rebuilding Reply with quote
IT would be helpful if we had a posted list of parts that are rebuild-able, or can be stripped for use as parts donors.
I've seen too many people throw away parts that have value. I personally have installed many new parts available today only to find the old removed part is actually better than the new installed piece.
Many parts with a minimum of work can be given a second life and serve effectively for a long long time.
A good example of this is the Syncro fuel sending unit.
I've rebuild many of these.
Let's consider the wiring harness as well. Many of the connectors can be harvested and reused for repair work.
Many obvious things like starters, and fuel injectors, can also be reused after an easy refurbishment.
I've welded many parts back together from two that were rusted away.
We already have a thread on here that encourages people to pass along good used parts to other members rather than simply throw them away.
http://www.thesamba.com/vw/forum/viewtopic.php?t=478468
If we had a list of parts worth saving and passing along, it would be very helpful to the hobby as a whole.
campism
campism is offline
PostPosted: Tue Feb 10, 2015 9:32 am    Post subject: Reply with quote
Alternator. I had the bearings start making noise during a trip and swapped in my spare. The original still makes electricity and I've read these can be rebuilt by civilians, so it sounds like it would be worth a try.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue Feb 10, 2015 9:53 am    Post subject: Reply with quote
Way back when--and probably way prior to most of you even being around yet, fuel pumps, starter's, generators, alternators, brake cylinder's, brake shoes, most everything was rebuilt on a vehicle excluding obvious wear items.
Now--nobody has the time to be doing such things--
Buy somebodies else's problem that was expressline, half assed remanned South of the border--
T.K.
djkeev
djkeev is offline
PostPosted: Tue Feb 10, 2015 9:54 am    Post subject: Reply with quote
I think that we as a society .....have moved/are moving ...... away from being thrifty and fixing items.
"We" so prefer the fast clean easy take out the old, bolt in the new repair technique.
Case in point, I did a whole build thread on my siezed Blower motor..... Comments were essentially "thanks for the write up but good God, I'm just going to buy a new one!"
What do you do with that?
Same on my Brown Dash recover thread..... "Why? ..... just pick up a black one used" ........
I do support offering items to others who may want/need them.... I'm just not sure how much this will be embraced.
Dave
Ghia
Vanagon
Beetle
PDXWesty
PDXWesty is offline
PostPosted: Tue Feb 10, 2015 9:59 am    Post subject: Reply with quote
It's really a simple equation for some of us: Time = Money
If you value your time and have money, it sometimes makes more sense to buy a new $40 part rather than taking 4 hours to recondition it. There's always a tipping point for me though and I do enjoy the process or rebuilding, but I have to pick and choose my projects these days based on limited free time. Sad but true.
89 Westy 2.1 Auto
Terry Kay
Banned
PostPosted: Tue Feb 10, 2015 10:03 am    Post subject: Reply with quote
I have never seen of or heard of a blower motor rebuilding kit available anywhere including Warshawski's--and if they didn't have it--you didn't need it.
There IS a BIG difference of being sensable, and Frugal Dave.
Your two feet deep into squeaky Frugal.
That dash job took & sucked up more time than was reasonable.
And here is the key--being reasonable in your time managment.
If you were on commission you'd be starvin' Marvin.
Then there was the heater re-configuration mambo.
How much time did you kill on that--and for what?
Your not even sure on that caper--
Hobby--sure-- kill all the time you want.
If you got somewhere to be, something to do besides screwing around re-engineering a Vanagon forget about it--
Rebuilding & re-engineering for your own pleasure is two different animals--
T.K.
61Scout
61Scout is offline
PostPosted: Tue Feb 10, 2015 10:37 am    Post subject: Reply with quote
Time isn't money. Time is life. What one does with their life is their own business.
-Kevin
1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu
Terry Kay
Banned
PostPosted: Tue Feb 10, 2015 10:42 am    Post subject: Reply with quote
No, Life is time, time is money.
Unless you have nothing else better to do--go ahead and kill it at whatever rate you want.
T.K.
djkeev
djkeev is offline
PostPosted: Tue Feb 10, 2015 10:49 am    Post subject: Reply with quote
I do what I enjoy.
I enjoy salvaging and fixing that which has been declared unfixable by others.
Its not profitable I know, in another time period I would have been Dave's Fixit Shop.
I completely understand the financial impractabilities of repairing some things.
Honestly......Some hunt, some boat, some drink and some golf to relax.
I tinker and bring worn inanimate things back to life. I'm not working on a profit /loss statement here. To spend three hours and $10 to fix a $12 something rather than buying a new or used one is completely worth it to me.
Dave
Ghia
Vanagon
Beetle
Terry Kay
Banned
PostPosted: Tue Feb 10, 2015 11:15 am    Post subject: Reply with quote
It's a hobby as I mentioned.
Some guys will spend years building a radio controlled quarter scale model of the Enola Gay, just to stuff it into the ground on it's maiden flight.
It's a hobby.
Time has more value here than taking the long road around the block approach, but I will rebuild what normally is considered rebuildable, I wouldn't enter into the abiss and kill a week or two re-engineering the impossible.
T.K.
wcdennis
wcdennis is offline
PostPosted: Tue Feb 10, 2015 11:58 am    Post subject: Reply with quote
If time is really money, who is getting paid to hang out on Samba? Who would even own a Vanagon or any antique vehicle, for that matter? No question, most of us do this stuff for fun, those who are trying to make a living at it, who are calculating the rate of return, are in the minority, by a long shot.
Gruppe B
Gruppe B is offline
PostPosted: Tue Feb 10, 2015 12:03 pm    Post subject: Reply with quote
I have a Champion Spark Plug Cleaner for sale if anyone is interested.
"Guaranteed to give your sparkplugs another 5000 miles or your money back"
MarkWard
MarkWard is offline
PostPosted: Tue Feb 10, 2015 12:07 pm    Post subject: Reply with quote
I have figured out how to replace a blown tungsten bulb filament with one made from bamboo. I got the idea from Thomas Edison. These rebuilt bulbs last forever.
campism
campism is offline
PostPosted: Tue Feb 10, 2015 12:23 pm    Post subject: Reply with quote
Power steering rack. I bought a seal kit from Bus Depot and gave it a try, but I had the luxury of the Westy being our third vehicle (fourth if you count the motorcycle) so the downtime and "wasted hours" were educational. I could have ordered a new rack and had the job done in a day but that is not how I approached it. Incidentally, without input and a pre-blazed path from fellow Sambanistas I might not even have attempted that fix.
Now that I'm retired I can devote even more time to pursuits others might call useless or, as some might say, inverted on a cost/benefit basis. Of course, if it were 60 and not sleeting outside and I wanted to go camping I might just buy that steering rack, or whatever. It's all in what you value.
insyncro
Banned
insyncro is offline
PostPosted: Tue Feb 10, 2015 1:06 pm    Post subject: Reply with quote
Every single part that was on a Vanagon when it rolled off the assembly line is worth rebuilding...except the plastic parts.
Heck, I'm opting to cut up vans for replacement panels now as what you can get from vendors is not worth even trying to make work.
The quality of remanufactured today is bunk compared to the parts originally on the vehicle.
Most of these parts lastest 200,000 miles compared to rebuilt today ....about 30k-50k miles, if you are lucky.
The main issue I have with rebuilding, is that the rebuild parts from FLAPs are just as poor as the rebuilt units they sell.
Most of my seals and replaceable parts I use are not from US distribution.
The Euro vendors have some far superior products and rebuild kits available.
Yes shipping is high and the wait...but the rebuilt part you than have actually works.
My stash of good cores is HUGE and none to date have failed me or the van I have put them on after properly rebuilding them and coating the exterior of the part to keep the elements at bay.
rlevans
rlevans is offline
PostPosted: Tue Feb 10, 2015 1:30 pm    Post subject: Reply with quote
Wow Gruppe I have one of those spark plug cleaner / testers also. I live a ways out of town so its not always feasable to run in for a $3 plug so the Champion unit sees alot of action (and it works great to bring a fouled plug back into aciton)
ha ha Terry, I've been there with the 1/4 scale RC airplane but the EBOLA gay probably should be buried.
(snicker). Did you do that on purpose? Hope theres no vets on here Shocked
Terry Kay
Banned
PostPosted: Tue Feb 10, 2015 1:51 pm    Post subject: Reply with quote
Boy,
I've done some typos in my day.
The Ebloa Gay was just that, but a pretty funny and an on time error--
If a guy is retarded, I mean retired, he has nothing but all kinds of time to kill.
Rebuilding lug nuts would be a fine way to eat up all kinds of hours .
Bamboo light bulb replacement filiments is a good way to eat up some time--
Me?
Got more important things to do.
T.K.
EL31415
EL31415 is offline
PostPosted: Tue Feb 10, 2015 3:03 pm    Post subject: Reply with quote
How do you preserve those parts ?
Dry ? Wet in oil or gaz or ....?
1985 Westy
Terry Kay
Banned
PostPosted: Tue Feb 10, 2015 3:08 pm    Post subject: Reply with quote
Cosmoline.
T.K.
Sir Sam
Sir Sam is offline
PostPosted: Tue Feb 10, 2015 6:04 pm    Post subject: Reply with quote
I am, I spending many hours on the samba reading and posting while I'm getting paid.
Of course then when I'm not on the samba I'm not getting paid to work on a van.
'91 Carat Westy
87' Syncro + '87 Westy conversion coming soon
