1959 Single Cab Restoration Thread "Funky Truck"
Page: Previous  1, 2, 3 ... 23, 24, 25 ... 79, 80, 81  Next
coolerthanelvis
coolerthanelvis is offline
PostPosted: Wed Feb 18, 2015 4:17 pm    Post subject: Reply with quote
This tool looks handy. I don't know if there's enough room to use it on the SC, but it makes quick work of the door skin in the video.
https://www.youtube.com/watch?v=joJKFlziBg4
Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob
cdennisg
cdennisg is offline
PostPosted: Wed Feb 18, 2015 6:29 pm    Post subject: Reply with quote
that's pretty neat!
glideking
glideking is offline
PostPosted: Fri Feb 20, 2015 11:17 am    Post subject: Sealing Wax Red L53 formula paint code Reply with quote
Same two pieces indoor outdoor lighting.
I have been working on getting the color right for months. People from all over the planet have sent me samples and scraps of metal claimed to be correct. These samples are more than fifty years old and aged in various conditions. I sanded them down and polished them up. From all of this I have seen quite a lot of variation from magenta , orange to pink. I think the color varied over the years that it was produced as well. The original ingredients are no longer available or illegal and if they were modern manufacturing techniques would produce different colors anyway. I settled on a color that I liked somewhere in the middle of the range. We tried a computer match first and it was way off. It required a lot of adjustment from that and other colors not suggested by the computer were added. What we found is that this color is sensitive to very slight changes in the pigment added. Mixing small batches was futile. I don't understand why some people are keeping their recent paint mixes a secret. We can all benefit from sharing our findings. If you work with this mix and adjust it please share your results. I got two gallons today with catalyst that will produce 3 sprayable gallons. "Funky" has a lot of surface area! Temperature and humidity levels are getting better here in California so I can pick good days to spray in my unheated garage as spring weather approaches.
For completeness the years used were 1950-1965. VW paint code L53. PPG/Ditzler paint code 71025. SK1034 Due to chemistry differences over time these formulas do not work anymore.
Kurt
"The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639
glideking
PostPosted: Fri Feb 20, 2015 4:16 pm    Post subject: Reply with quote
100 more views and "Funky Truck" will be at 100,000 views. Who would have thought?
Kurt
BulliBill
BulliBill is offline
PostPosted: Fri Feb 20, 2015 4:30 pm    Post subject: Reply with quote
...and I just helped! Let's get there tonight!
Hi Kurt!
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
glideking
PostPosted: Fri Feb 20, 2015 4:37 pm    Post subject: Reply with quote
Thanks Bill. Looks like your topic will be there soon too!
Chad M
Chad M is offline
PostPosted: Fri Feb 20, 2015 7:24 pm    Post subject: Reply with quote
Is it just coincidence that you guys started your topics on the same day 2 years and 4 days ago? Very Happy
glideking
PostPosted: Sat Feb 21, 2015 11:49 pm    Post subject: Seam Sealer Reply with quote
Before I can apply any of this beautiful paint I have to do a lot of seam sealing.
This is a urethane seam sealer that comes in a "burrito" bag. It is intended to be used with a funnel taped on to one end like a pastry bag. I think I'll pass on that. I chose not to use one of those epoxy guns with a mixing tip because there is no room in my truck to use it and the tip is too large.
I was also looking for a way to dispense a small controlled amount instead of the usual smeary blobs that require masking on both sides of the seam. My woodworking shop is next door so I nabbed these.
This stuff is quite runny so it is easy to pour into the glue syringes.
The hole in the end is very small and the applicator is easy to maneuver in small spaces unlike a caulking gun.
I do not have to use 100s of feet of masking tape.
Kurt
Huetti_1989
Huetti_1989 is offline
PostPosted: Sun Feb 22, 2015 8:42 am    Post subject: Reply with quote
Applause Applause Applause Applause Applause
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
Da TOW'D
Da TOW'D is offline
PostPosted: Sun Feb 22, 2015 10:38 am    Post subject: Reply with quote
lots of good ideas here
thanks Kurt
hank
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
glideking
PostPosted: Sun Feb 22, 2015 7:01 pm    Post subject: Reply with quote
How do you trim a 2mm taper off of a 1mm thick sheet metal and keep a line perfectly straight?
I don't know but here is what I did. I clamp a 1/4" bar stock with one edge colored black with a sharpie. Grind until the black gets some scratches.
Sand with a flap disk until all of the black is gone.
File a radius on both sides.
Got all the plug weld holes drilled and the center seam has weld through primer. I am thinking I will weld the seam first before going on the truck.
Why file a radius? (begin rant) Paint does not adhere well to sharp corners. Sharp corners are easily abraded or bumped into by anything. When paint is chipped easily at sharp corners the rust will begin. A soft edge will last longer. (end of rant)
Now go file some VW parts!
Kurt
Chris'58SC
Chris'58SC is offline
PostPosted: Mon Feb 23, 2015 12:57 pm    Post subject: Reply with quote
Fantstic job!
Schmidts
Schmidts is offline
PostPosted: Thu Feb 26, 2015 2:00 am    Post subject: Reply with quote
Kurt you are clever well skilled craftsman
I love your old school skills and ability to adapt to any trade
As a shipwright and a fellow SC owner and having done quite a few resto's with the help of my Dad, who was exactly like you old school tradesman who seem to know all trades
I have spent the last few hours reading and watching your videos, the best part my 4 and 6 year old sat either side of me also glued to the progress.
You topic and build was better then a bed time book
Thanks for the hours of fun and reading
Your a dead set legend mate
We are glued to the screen waiting on the colour and updates
Oh my kids give a big thumbs up to sealing wax red, its one of there favourite VW colours (behind Pearl White)
Here is our SC just finished our resto
Thanks
Scott, Isabella and Sam from Australia
View user's profile Send private message AIM Address Facebook Gallery Classifieds Feedback
glideking
PostPosted: Thu Feb 26, 2015 8:39 am    Post subject: Reply with quote
You made my day! I am very enthusiastic about VW's and hoped to share that with others. I am glad to know this is making it around the world and to all ages too. Thank you.
Kurt
Beautiful # 53!
glideking
PostPosted: Tue Mar 03, 2015 11:44 pm    Post subject: Making a spare tire mount in treasure chest Reply with quote
Spare tire space behind the seat in a single cab is minimal. Modern radials do not fit without pushing my knees into the steering column. I am adding a treasure chest spare tire mount in my 1959. This feature was not standard until 1963. Others said they need to do this so I am including details.
I stole this photo from the net. I need to make all of these parts:
I don't have a working milling machine so I cut the slots by drilling holes and grinding out the rest.
Now the holes for plug welding.
Now separated.
I love to grind! Don't you?
I am so glad I can weld this with the truck upside down.
Perhaps I should leave my plug welds not ground so future archeologists can see this was added to an early VW and not standard equipment?...
No
Now for the threaded rod. I don't know how VW did it as I have never taken one apart. I ran the threaded rod all the way through and welded to the top side for stiffness.
Now for the plate. Found some tubing.
Cut in half.
Cut some more.
Bend the ends in a vice.
The giant wing nut was an experiment that worked out. Surprised me! Started with a large hex coupling nut and some bar stock.
Ground and sanded.
Good enough to hold up a spare tire.
I have been planning to do this upgrade to my truck for many, many years. This seemed like as good a time as any.
Now there is room behind my seat for that subwoofer!!!!!!!!
Kurt
PeteSC
PeteSC is offline
PostPosted: Wed Mar 04, 2015 6:01 am    Post subject: Reply with quote
This thread is full of awesome and win. One of my favorites on TS.
Nice job fab'ing that spare tire mount!
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Wed Mar 04, 2015 8:04 am    Post subject: Reply with quote
I think you missed your calling Kurt. Auto body metal repair might have been it..
I absolutely love your attention to detail, creativeness and ability to execute your ideas. Your welding is rally top notch now as well.
I'm glad to see you working on the VW again. Keep chipping away at the tasks and it will be done before you know it.
The Samba member since 2004.
cdennisg
cdennisg is offline
PostPosted: Wed Mar 04, 2015 10:18 am    Post subject: Re: Making a spare tire mount in treasure chest Reply with quote
Kurt
You win. Without a doubt, you win. Very well done. Applause
1967250s
1967250s is offline
PostPosted: Wed Mar 04, 2015 10:52 am    Post subject: Reply with quote
Awesome fix, Kurt! I would suggest making a plate that goes the width of the top of the beam and weld thru to the threaded rod. This would spread out the weight some and help prevent the rod pulling through. Maybe not original, but that is a fair amount of weight on 1 square inch of 20 ga sheetmetal. You're work is a real inspiration, Thanks.
'72 Elm Green Deluxe
glideking
PostPosted: Wed Mar 04, 2015 12:49 pm    Post subject: Reply with quote
"a plate that goes the width of the top of the beam and weld thru to the threaded rod."
That is a good idea. I will do that!
Kurt
Page 24 of 81
