tlbranth Samba Member
Joined: May 24, 2014 Posts: 209 Location: Carnation, Wa
Posted: Sat Feb 21, 2015 4:40 pm Post subject: four speed manual - oil level etc. |
Can anyone tell me how to check the oil level? Owner's manual says go to your VW dealer. Bentley says check and refill if necessary but I can't find where it says how. _________________ Terry
1991 Westfailure. 2004 Forester 2.5 engine. 4speed Standard transmission. |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
Posted: Sat Feb 21, 2015 4:43 pm Post subject: |
open the pour bolt, stick your finger in..  _________________ Learn to ride. Ride to learn. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10226 Location: Mt Lemmon, AZ
Posted: Sat Feb 21, 2015 5:12 pm Post subject: |
Without looking I seem to recall that the specified level was somewhere below the fill plug. Not very handy when refilling (like being told to 'turn left 5 blocks before Main Street').
But I believe that instruction was later revised to fill to the bottom of the fill plug - so easy to refill (until it comes out) and check (then mentioned finger).
You will need something to undo the 17mm socket head plug. Either a tool for that purpose or a substitute made from a bolt & nut.
Posted: Sat Feb 21, 2015 5:22 pm Post subject: |
What I figured. I looked around and am not seeing the filler bolt though. _________________ Terry
Posted: Sat Feb 21, 2015 6:19 pm Post subject: |
Right (passenger) side of case, near the linkage.
May be wicked tight if it hasn't moved in a while. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Sat Feb 21, 2015 11:21 pm Post subject: |
Aaaaaaaaannnnnnndddddd wait for it - the piece of advice you will never need to be reminded of if you disobey it..........
Loosen the FILL bolt before you remove the drain bolt. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17147 Location: Brookeville, MD
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6930 Location: Fort Lauderdale, Fl.
Posted: Sun Feb 22, 2015 8:02 am Post subject: |
IdahoDoug wrote: |
Loosen the FILL bolt before you remove the drain bolt. |
Oh...you mean IF you can get it loose!  |
Posted: Sun Feb 22, 2015 8:43 am Post subject: |
Thanks fellas. _________________ Terry
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Sun Feb 22, 2015 8:45 am Post subject: |
Sometimes, only the tool that Ahwahnee shows will remove the dang thing, because it allows more loosening torque to be applied. Shops should know better, but they tend to tighten these plugs to 100+ lbs, when the manual states 15. Personally, I use teflon tape to avoid any future knuckle bashing. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Sun Feb 22, 2015 11:14 am Post subject: |
In the field once, I used a truck's jack to get the fill plug open, so tight was it on. I put whatever wrench I had on it, and used the jack's lifting power under the wrench to rotate it. It let go with a bang that told me there was no way I would have gotten it. The owner of the truck later called the shop and gave them an earful about overtightening things. He'd also had major trouble with the lugnuts. Anyhow, with few resources at hand remember the power of the car's factory jack to move a wrench even when in the middle of nowhere. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23890 Location: NYC/Upstate/ROW
Posted: Sun Feb 22, 2015 1:52 pm Post subject: |
You can debate this kind of stuff all day.
Ridiculous. Gears are lubed by splash, and 3mm difference in level won't matter. It should be 3mm of course, not 1/8. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
