sixer Samba Member
Joined: March 23, 2014 Posts: 88 Location: Charleston, SC
Posted: Thu Mar 12, 2015 4:47 am Post subject: Stumble when headlights on |
Good morning all,
I've got a bit of a low voltage/ground problem. 1976 bus, 2.0L with stock FI.
Problem: When the headlights are on, the bus stumbles and hiccups. This happens from 2-5 minutes of driving, then goes away, and will not return until the next cold start. Colder ambient temperatures mean it does it for a longer period. Turning the headlights off during this period smooths the engine out and it runs just fine. Turn the lights back on, and the stumbling returns.
Relevant info: Just replaced the battery last night to ensure I had all the power I needed, recently cleaned and reinstalled trans ground strap, added a direct battery-to-fan shroud ground cable. Cleaned FI grounds, ground for double relay, any other grounds I could find in the engine bay.
Any further ideas? Thanks in advance for your help.
Edited for clarity that lights on/off make a difference. _________________ 1976 Transporter, Stock 2.0L
http://instagram.com/sixer.bus/ |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53265 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 12, 2015 6:53 am Post subject: |
A volt meter of some sort you can see while driving would be the next logical step. First on the big red wire at the fuse box and if that checks out OK test the black wire. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
sixer Samba Member
Posted: Thu Mar 12, 2015 7:55 am Post subject: |
Thanks Bus Daddy. I set up my voltmeter and got this:
Testing setup: Voltmeter bridged from main + cable into fuse box (fuse #8 ) to ground.
Results:
Static voltage before start: 12.44V
Idle/running voltage (stays pretty consistent with increased RPM): 13.4
Headlights on: 12.7-13V, stumbling occurs.
High beams on: Engine dies
Pretty much any drop below 13V seems to make the engine stumble. Should I take my voltage measurements somewhere else? I looked for the big black wire but did not see such a beast. _________________ 1976 Transporter, Stock 2.0L
Posted: Thu Mar 12, 2015 8:08 am Post subject: |
| Repeat the test by reading the voltage on the #15 wire (fuse #11 or #12). I think you will find the ignition switch is on its last legs. |
sixer Samba Member
Posted: Thu Mar 12, 2015 8:29 am Post subject: |
Same setup, this time on Fuse #12 (repeated with 11, same results).
Results:
Static voltage key off: 0V
Static voltage key on, not running: 12.5V
Idle/running voltage: 13.04-13.2V
Headlights on: 12.3V (@ beginning of test) to 12.7V (@ end of test)
High beams on: 12.4-12.5V
Of course, during this round of testing the problem resolved itself. By the end of this test I could use the headlights, high beams and all without stumbling. I will repeat this afternoon/tonight when I know everything is cold. Or as cold as it gets here (71° ambient temp right now). _________________ 1976 Transporter, Stock 2.0L
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Thu Mar 12, 2015 8:39 am Post subject: |
| sixer wrote: |
Results:
Of course, during this round of testing the problem resolved itself. By the end of this test I could use the headlights, high beams and all without stumbling. I will repeat this afternoon/tonight when I know everything is cold. Or as cold as it gets here (71° ambient temp right now). |
I suspect your alternator. Absolutely no reason for the voltage to drop below 13 with the engine running and the high beams on.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
sixer Samba Member
Posted: Thu Mar 12, 2015 9:29 am Post subject: |
Thanks for the input Colin. Just because I can I ran the test again, this time taking my readings directly at the battery.
Results:
Static voltage: 12.57V
Idle/running voltage: 13.28V rising through test
Headlights on: 13.00V @ beginning of test, rising through test
High beams on: 13.00V @ beginning of test, rising through test
As of right now, the problem is not showing any symptoms. It idles and revs fine with the high beams on, and everything else I can turn on as well. I will run the last two tests again in the morning when the bus is cold again. The alternator is a remanufactured unit from Advance Auto, not sure how old it is though. I am going to go ahead and replace the cable from it as there is a splice, and the end treatment leaves a little to be desired. I looked at the splice a few weeks ago, but it looked fine so I left it in.
I am still collecting advice and building my list of things to test, so please weigh in! _________________ 1976 Transporter, Stock 2.0L
Posted: Thu Mar 12, 2015 9:37 am Post subject: |
| sixer wrote: |
I am going to replace the cable from it as there is a splice, and the end treatment leaves a little to be desired.
please weigh in! |
Remanufactured from Advance Auto means that you do not leave out the possibility that it can fail at any instant.
Excellent idea. Solder the terminal end of the alternator wire before you install it on the starter post. Clean, rosin, quick heat, let solder wick into the strands, yer done and subsequent amperage will not heat the area up.
While you are there, if you see the heater blower power wire (simple red) check it carefully for damaged strands at the terminal end, hit it too.
sixer Samba Member
Posted: Thu Mar 12, 2015 10:02 am Post subject: |
| Amskeptic wrote: |
| Remanufactured from Advance Auto means that you do not leave out the possibility that it can fail at any instant. |
Exactly why I mentioned it.
| Amskeptic wrote: |
Colin |
I will do this. I've been meaning to replace the all the positive side cables of the battery and charging system, just haven't had the time yet to make it a priority.
The heater blower motor power wire: that's the one that goes through the fuse holder to the relay right? My blower motor is currently out (piecing together parts to build the heat system). Just to satisfy my curiosity: do you think this is related to the voltage issue, or is this just good practice to do while in the area of the starter post?
I'll knock this out over the next few days and report back. That being said, any further input on things to check is welcome since I've got some free hours lined up for this weekend. Thanks all! _________________ 1976 Transporter, Stock 2.0L
aeromech Samba Member
Joined: January 24, 2006 Posts: 17790 Location: San Diego, California
Posted: Thu Mar 12, 2015 10:06 am Post subject: |
The alternator sure would be suspect but I have to ask....
Even with the alternator putting out zero amps, the stored power from the battery should privide plenty of juice to keep the ignition system running for a long period of time. I think we've all heard stories of people driving their buses long distances just on battery power. Now if the alternator was somehow creating a dead short, then the battery power could drain quickly but I'm afraid you'd be seeing and smelling some smoke at that point. I'd also think that your system would operate fine down to about the 9-10 volt point and you report this is happening with battery voltage above 12 volts with the high beams on. I'm sorry I can't offer up an explanation of why you're seeing the stumble. You could try running a hot wire from your battery + straight to the coil to see if that solves it. If it does then I think you'd be looking at an ignition switch as was offered up earlier as a possible cause. Maybe you should reseat the connector at the resistor pack just for grins? You might also watch your fuel pressure during a stumble (if you can get it to repeat again). _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
sixer Samba Member
Posted: Thu Mar 12, 2015 10:22 am Post subject: |
Thanks for the ideas aeromech. Some quick questions/comments:
I agree, the voltage seems fine, but I've hear the FI system is fickle about voltages too. Hence why I'm still seeking out further troubleshooting ideas like the ones you mentioned.
Regarding running a wire from the battery to + side of coil: any issues about doing this with pertronix? My thought would be: start engine, see if stumble happens, if so connect wire and see if it stops. This would essentially guarantee full voltage to the coil instead of having to pass through the ignition switch correct?
Oh, and what is a resistor pack? Still learning here... _________________ 1976 Transporter, Stock 2.0L
Posted: Thu Mar 12, 2015 10:36 am Post subject: |
The resistor pack is the thing in the upper left attached to the firewall
The fuel injectors operate at around 5-6 volts so you need the resistor pack to drop the system voltage. You can see the connector in the picture. To your question about the coil wire. Yes, I think you should rig up a good source of battery power and when you get a stumble, connect that wire directly to the coil +. I don't think it will harm the Pertronix as long as you connect the wire to the RED pertronix wire on the coil. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sixer Samba Member
Posted: Sat Mar 21, 2015 3:15 pm Post subject: |
So after some testing, here's what I've learned: if I connect a cable from the positive straight to the battery to the + side of the coil (per aeromech's suggestion), the problem seems to go away completely. So I replaced the ignition switch, but the stumble remains. Doesn't last long after being warmed up, but it's there when cold. Colin, I still haven't tried replacing the alternator cable, although that is on my list for tomorrow. Any other ideas?
When I drove it today (after replacing the ignition switch), here's what happened: started fine, idled fine. Made it a block, then hiccup'd once, so I turned down a side street to do some further testing. If I turn the headlights on when cruising, the bus bucks badly. If I turn the lights on when idling, it wants to die. The symptoms lessen as the driving time increases, and eventually go away completely. Tomorrow I will be replacing the alternator cable and re-cleaning all grounds and connections. _________________ 1976 Transporter, Stock 2.0L
LouFilia Samba Member
Posted: Sat Mar 21, 2015 4:21 pm Post subject: |
I had a similiar problem on a different Bosch injection unit. I think your looking on the wrong side of the power distribution network. I started by cleaning all my FI connections and the cleaning of the FI grounds solved the problem for a while (got the most results cleaning the grounds directly from the computer), but it came slowly back. It turned out my resistor pack was old and not suppling the enough voltage to what we call the double relay. For reasons that only a electrical engineering teacher could probably only explain to us correctly, as I drove the car, the voltage output would slowly go up. Thus the problem went away as the car 'warmed up'. It may be different on a L-series injection, but that's my first thought. _________________ '78 Westy (P22), 2.0FI (GE), 4speed (CP), thought I was buying a VW, ended up with a Bentley. |
Posted: Sat Mar 21, 2015 5:29 pm Post subject: |
Let's go back to what you just said. Per my instructions, you connected a hot wire directly from the battery to the coil + side. You said the problem went away.
I know you've replaced the ignition switch but I'm curious if you go back and hook that wire back up if the bus will ever stumble? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent  Samba Member
Joined: October 30, 2007 Posts: 43002 Location: at the beach in Northern Wokistan
Posted: Sat Mar 21, 2015 5:39 pm Post subject: |
| Quote: |
| So after some testing, here's what I've learned: if I connect a cable from the positive straight to the battery to the + side of the coil (per aeromech's suggestion), the problem seems to go away completely. So I replaced the ignition switch, but the stumble remains |
When the arteries get plugged from all the junk food we ate when young, a restriction develops. To fix it the surgeon puts an artery around the blockage - by passing it. When you added that wire from the battery to 15 on the coil you created a bypass so that the electricity did not have to go forward and come back. In a nutshell there is a bad connection somewhere. When you turn the headlights on you increase electrical demand, and the voltage across that bad connection drops. You replaced the switch which is where the logical place it would be is. Is it possible you put the old one back in accidentally? Have you checked the connector at the bottom of the column? What about the connections at the fuse? Did you spin, brush or replace the fuse in case it has corrosion on the ends? Did you check that big red wire where it connects to the starter to be sure that it hasn't cracked over time? Are there any places where a repair was done to it?
Is your battery ground strap to the bus engine or the bus chassis? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Sat Mar 21, 2015 5:43 pm Post subject: |
This makes me think maybe you could try running a special ground wire from the battery - to the engine case and see what happens. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent  Samba Member
Posted: Sat Mar 21, 2015 6:03 pm Post subject: |
| aeromech wrote: |
This makes me think maybe you could try running a special ground wire from the battery - to the engine case and see what happens. |
I would make 100% sure that the battery to chassis AND chassis to transmission straps are all good. The problem is either a bad connection / switch between the starter and coil, or the chassis is acting as a floating ground due to a bad ground.
Example of a bad ground - say car has a poor ground. Driver pushes the clutch in and turns the key. Engine starts cause the clutch cable acts as an extra ground. Turn the headlights on when driving and the chassis floating ground voltage increases so the ignition farts.
Example of a bad connection - ring connector at starter has hardened and the wires broken. Usually enough power to make things work but when the headlights are turned on they pull the voltage down across the bad connection and the system has a voltage drop. Or - fuse connector has gotten corroded and needs to be wire brushed. I pulled each connector off out fuse box while restoring the bus, cleaned each one and put it back making sure it was tight. Fuses were all heavily oxidized so I replaced them all and wire brushed the tabs that hold them.
Example of a bad switch - two switches are sitting on the work bench that look alike. Kids pick it up and set it back down confusing the two so the old switch goes back in. Owner thinks switch was changed but it was not. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Sat Mar 21, 2015 8:53 pm Post subject: |
Rig up a jumper to go from hot side of the #8 or #9 fuse to the hot side of the #11 or 12 fuse. If this fixes your problem it is either the ignition switch or the wiring to and from the switch. Note that you will not be able to shut the engine off with the jumper thus installed.
You need to work your way through the #30 and #15 circuits and find out what the voltage is at each point along the way. If the voltage drops substantially at any point, you likely have found your problem. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3632 Location: San Diego (Encinitas)
Posted: Sat Mar 21, 2015 11:36 pm Post subject: |
Agreed. Note on the schematic that the power from the starter goes to the fuse block, across a busbar, out of another fuse block terminal, to the ignition switch, out of the ignition switch back to the fuse block, across another busbar, out of the fuse block, then to the rear of the bus to the coil.
That's four connections at the fuse block, any of which could be intermittent. Search, clean, tighten, reinstall. See if the problem goes away permanently. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
