Type IV Oil Drain Plug
Page: 1, 2, 3  Next
Manfreds78bay
Manfreds78bay is offline
PostPosted: Wed Apr 08, 2015 3:16 am    Post subject: Type IV Oil Drain Plug Reply with quote
Hello! My drain bolt helicoil insert broke. I want to replace with a Time-Sert insert. Does anyone know the drain hole thread length. I'm guessing I should order the 12.7 mm length.
Also, do I need to go one size bigger? It currently uses a 14 mm bolt. The bolt hole did not strip. The helicoil failed.
Thanks!
1985 VANAGON GL Digijet
There is no spoon.
lil-jinx
lil-jinx is offline
PostPosted: Wed Apr 08, 2015 5:10 am    Post subject: Reply with quote
Why not just get anorher cover plate for it?
1968 Dune Buggy sold dec 2024
1974 parts bus
Tcash
Tcash is offline
PostPosted: Wed Apr 08, 2015 5:51 am    Post subject: Re: 2.0L Type IV Oil Drain Hole Thread Length Reply with quote
Thanks!
Which part are you referring to.
thanks to mayor ratwell
Good luck
Tcash
poptop tom
poptop tom is offline
PostPosted: Wed Apr 08, 2015 6:19 am    Post subject: Reply with quote
I'm pretty sure he's talking about the completely separate oil drain bolt located on the case half opposite the cover plate.
Is it even on that diagram?
'76 Deluxe Campmobile
aerosurfer
aerosurfer is offline
PostPosted: Wed Apr 08, 2015 6:22 am    Post subject: Reply with quote
Drain plug.... for all us 'Merican bus owners is what he referring too. And no, it is not depicted on the above schematic
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
Manfreds78bay
PostPosted: Wed Apr 08, 2015 7:16 am    Post subject: Reply with quote
I'm guessing it's #44 plugs into it. I'm referring to the whole in the case. Not the plug/bolt.
There is no spoon.
poptop tom
PostPosted: Wed Apr 08, 2015 7:22 am    Post subject: Reply with quote
I'm guessing it's #44. There is only one oil drain plug folks. While you can drain from the strainer cover, that's not what it's called.
#44 looks like the oil pressure relief spring, bolt etc.
Manfreds78bay
PostPosted: Wed Apr 08, 2015 7:24 am    Post subject: Reply with quote
I'm talking about the hole in the case. I just need to figure out the length of the insert.
There is no spoon.
Amskeptic
Amskeptic is offline
PostPosted: Wed Apr 08, 2015 9:05 am    Post subject: Reply with quote
Because the Type 4 engine has a dedicated drain that has nothing to do with any cover plate. Way too many of these things are showing up all stripped out, what is with people?!? Just because some Jiffy Lube Horror Story crops up about a drain plug falling out, does not mean that they are prone to falling out. It means that someone didn't tighten the thing in the slightest.
17mm/19mm/6mm allen ... Drain plug 12 ft/lbs FINE
13mm ... Strainer Nut 9 ft/lbs FINE
10mm ... Taco Plate Bolts 5 ft/lbs FINE (really)
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
Manfreds78bay
PostPosted: Wed Apr 08, 2015 9:17 am    Post subject: Reply with quote
Colin, oh wise one, I know you must know the answer to my quest for knowledge. Is 12.7mm the correct length for the insert and should I get 16mm kit or stay with the 14mm kit? Remember the helicoil broke. Any suggestions would be great.
There is no spoon.
aeromech
aeromech is offline
PostPosted: Wed Apr 08, 2015 9:28 am    Post subject: Reply with quote
Why don't you stick something in the hole and measure it?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Manfreds78bay
PostPosted: Wed Apr 08, 2015 9:32 am    Post subject: Reply with quote
I was hoping someone had done this and could chime in that has done this before. Because I doubt the inserts and the available sizes are going to match up perfectly.
There is no spoon.
aeromech
aeromech is offline
PostPosted: Wed Apr 08, 2015 9:35 am    Post subject: Reply with quote
Try calling an engine builder like Headflow Masters or Suburban.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Manfreds78bay
PostPosted: Wed Apr 08, 2015 9:44 am    Post subject: Reply with quote
Okay thanks.
There is no spoon.
raygreenwood
raygreenwood is offline
PostPosted: Wed Apr 08, 2015 9:55 am    Post subject: Reply with quote
Okay thanks.
Give me an hour or so. I have a case open on my workbench at home.
If you are going to use a TimeSert....or EZLock...which you should because Helicoils have no business anywhere on this engine or in aluminum that is less than T6 hardness in my experience......then you need to make sure that the installed depth is spot on (with a timesert)...because if not, the expansion flange at the end of the bore that locks the insert into the bore....will stand proud of the case....and not let all of your oil drain. It will not be much...but will leave a layer of oil about .050" deep in there.
Personally if I had to replace that thread I would lock a bolt in there and leave it alone until its time to rebuild and split the case. Then I would use an oversized EZlock that is bottomed into its bore, peened in with lock tight so its a thick wall insert and flush inside the case.
Ray
Manfreds78bay
PostPosted: Wed Apr 08, 2015 10:13 am    Post subject: Reply with quote
Okay thanks.
Ray
Thanks, Ray. That is good advice. But the engine was recently rebuilt and they neglected to look at the drain plug. So she is going to be this way for a few miles. I would appreciate any advice as to the best way to get the time-sert installed correctly and I think it would be good for the site as well.
Thanks!
There is no spoon.
Manfreds78bay
PostPosted: Wed Apr 08, 2015 10:43 am    Post subject: Reply with quote
The EZ-LOK look like an easier install. I might go that route.
There is no spoon.
raygreenwood
PostPosted: Wed Apr 08, 2015 2:03 pm    Post subject: Reply with quote
I measured the thread depth on one of my cases at .518". Ray
Manfreds78bay
PostPosted: Wed Apr 08, 2015 2:28 pm    Post subject: Reply with quote
Perfect. 12.7mm it is.
There is no spoon.
Tcash
Tcash is offline
PostPosted: Wed Apr 08, 2015 2:59 pm    Post subject: Reply with quote
Tcash wrote:
Pictures would be cool.
How to post photos/How to post a photo in the Forums
Page: 1, 2, 3  Next
