cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Mon Mar 30, 2015 10:30 pm Post subject: My project Doom Buggy |
So i aquired a buggy from a friend of mine a few years ago. i was all ready to get it on the road and have my fun with it. upon tearing down the motor i found ou that it was worn out. so 2 years later i have got a couple of motors to rebuild and so now it is time to get this project going
back when i got it i started the tear down but ended at the boat anchor engine so i will post the pics that i have to date and will update when i have new ones
this is what it looked like upon getting it
Posted: Mon Mar 30, 2015 10:31 pm Post subject: |
and a shot of the dash
and the start of the tear down
Posted: Mon Mar 30, 2015 10:32 pm Post subject: |
and the pan stripped of the body
Posted: Mon Mar 30, 2015 10:34 pm Post subject: |
and the removal of the floors
which was done tonight, the rest of the pictures where from 2 years ago
i am planning on using some 1"x2" tubing to build the outer frame and then use some 1/8th or 1/16th sheet for the floor |
joescoolcustoms Samba Member
Posted: Mon Mar 30, 2015 11:40 pm Post subject: |
Cool Buggy! Except for the dash, it is a close Manx clone.
I suggest the 1/16 inch thick floor. 1/8 is way overkill and adds a lot of un-necessary weight. I use 14 Gauge metal for floors and it is a touch overkill, but works nicely. The 1 X 2 tubing does make a nice outside rail. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Mar 31, 2015 11:40 am Post subject: |
thanks for the info
but now i am wondering if i should go 1" up or 2" up
i am going to do some more research before i start making it |
Posted: Tue Mar 31, 2015 2:04 pm Post subject: |
cdnltded wrote: |
thanks for the info
2 X 2 boxed tubing makes a nice 1 inch lift on buggy. If you use the 0.120 wall, or 1/8 wall tubing, you do not need to sleeve the inside to keep from crushing the tubing.
A 1 inch lift is subtle and nice that it raises the windshield a touch and gets your eyes looking through the center of the windshield. And effectively sits you lower in the body. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Mar 31, 2015 4:26 pm Post subject: |
thanks Joe |
Posted: Wed Apr 08, 2015 9:05 pm Post subject: |
so i am preparing to fab up my floor pan and frame. i noticed on my body where it attaches to the there is a lip i am using 2x3 with the 2 being vertical and the 3 flat. do i just cut that little lip off? |
Posted: Thu Apr 09, 2015 6:27 am Post subject: |
I only use the 2 inch portion on the horizontal part so I can leave the factory lip. Plus, less sticking inside to interfere with seat tracks.
Posted: Sun Apr 12, 2015 9:53 pm Post subject: |
well i started my floors tonight. got both the outer rails done, now i have to grind the up and cut them to length. way easier then i thought it would be
impaleale Samba Member
Posted: Mon Apr 13, 2015 3:40 pm Post subject: |
Nice work! |
Posted: Mon Apr 13, 2015 5:09 pm Post subject: |
impaleale wrote: |
Nice work! |
thanks |
Posted: Thu Apr 16, 2015 9:57 pm Post subject: |
so
a hot, sharp piece of steel = one cut that hurts like hell but does not bleed
Posted: Thu Apr 16, 2015 9:59 pm Post subject: |
anyway got some progress done tonight
got the outer frame smoothened out and tacked into place
i am really happy with the results, some fine tuning of course but a welder is only as good as his grinder
Posted: Fri Apr 17, 2015 3:24 am Post subject: |
Looks good! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Fri Apr 17, 2015 7:41 pm Post subject: |
joescoolcustoms wrote: |
Looks good! |
thank you Joe |
Posted: Sat Apr 18, 2015 6:34 am Post subject: |
so i have a question to those who have the knowledge
i have 2 different pedal assemblies
one is from the early 60's and one from the late 60s to early 70s
the second has the gas pedal on the assembly.
which one would be better to use.
and where do i locate the pedal stop with either
thanks in advance |
EVfun  Samba Member
Posted: Sat Apr 18, 2015 7:59 am Post subject: |
The older cast pedals look nicer and would be appropriate for your frame. I know the clutch cable location was moved inside the tunnel at least once. How far in from the edge the tube is located is the only critical dimension. If it is the same as both of your pedal assemblies then the one to use is up to you. I can say from experience that using a roller pedal in the early pedal assembly is a bit uncomfortable on long drives. _________________
Wildthings wrote: |
