aeromech Samba Member
Joined: January 24, 2006 Posts: 17784 Location: San Diego, California
Posted: Thu May 07, 2015 8:29 pm Post subject: 1972 battery ground cable strap connection location |
Guys, I swear... I can't figure out where the battery ground strap attaches to the frame on this bus. It appears to not be the same as a 1971 and not the same as a 1976. So was 1972 some special location?
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Ian Samba Moderator
Posted: Thu May 07, 2015 9:11 pm Post subject: |
All the ones I've seen have it going to the engine block. 72 is a weird year.
_________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53249 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu May 07, 2015 9:35 pm Post subject: |
72 bolts to the wheel well just below where the ECU would go if it had FI.
I think I can almost see the hole just below the kink in the bodyline in this pic:
If that single dangly wire swung to the right a few inches it'd be over it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Ian Samba Moderator
Posted: Thu May 07, 2015 10:26 pm Post subject: |
| busdaddy wrote: |
| 72 bolts to the wheel well just below where the ECU would go if it had FI. |
No, it doesn't. Maybe late 72 ie. 73 model year.
Posted: Fri May 08, 2015 6:03 am Post subject: |
Mark, I can't believe this. I think Ian is right. I know the hole you're thinking about and this bus doesn't have it. I'd sure like to see an original picture of how VW did it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Ian Samba Moderator
Posted: Fri May 08, 2015 8:57 am Post subject: |
Not many all original 1972 Buses out there anymore.
Posted: Fri May 08, 2015 9:01 am Post subject: |
Ian, I can't tell shit from that picture. Can you? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Ian Samba Moderator
Posted: Fri May 08, 2015 9:04 am Post subject: |
Nope! That's all we get this many years later for "perfect original example" _________________ All your Buses are belong to us.
Posted: Fri May 08, 2015 9:05 am Post subject: |
I just cannot accept that VW grounded the battery to the engine like that. It just looks too bush league. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Fri May 08, 2015 9:37 am Post subject: |
| aeromech wrote: |
| I just cannot accept that VW grounded the battery to the engine like that. It just looks too bush league. |
They did it in the Karmann Ghia so, you never know:
Xevin  Samba Member
Posted: Fri May 08, 2015 10:05 am Post subject: |
Gary, my 72 ground is attached to the block like Ian's picture. But I have a mystery cable with a battery terminal clamp on one end and the other is bolted to the battery tray near the side marker. Always thought that was the orginal ground. I don't use it because the tray is cRusty. Thought the PO added the current strap. _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
Posted: Fri May 08, 2015 10:26 am Post subject: |
Well, I think I'm just gunna fabricate some kind of ground location. I have a rivnut puller. Maybe I'll install a rivnut somewhere solid like VW did with the later buses. They come in large sizes like 8mm
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Xevin  Samba Member
Posted: Fri May 08, 2015 10:30 am Post subject: |
I've seen people to something like that near the right side of the cover plate in your photo. _________________ Keep on Busin'
| Clatter wrote: |
| SGKent wrote: |
Xevin  Samba Member
Posted: Fri May 08, 2015 10:32 am Post subject: |
| Xevin wrote: |
| I've seen people to something like that near the right side of the cover plate in your photo. |
"AWOL" Stuart suggested that to me as well. _________________ Keep on Busin'
| Clatter wrote: |
| SGKent wrote: |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Fri May 08, 2015 11:13 am Post subject: |
Thanks Tim _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat May 09, 2015 4:26 am Post subject: |
| aeromech wrote: |
Grounding to the engine is a much better set up in my opinion. With it grounded to the engine you will not get starter current running through the clutch cable even if the ground strap is missing. The reason VW grounded it to the body was to save a few pennies, not because it was a better way to do things. |
Posted: Sat May 09, 2015 5:27 am Post subject: |
| Wildthings wrote: |
| aeromech wrote: |
WT,
Respectfully I need to disagree. By installing the "battery return" ground strap to the engine, you'd be sending ALL the electrical loads through the transmission strap, the engine, and fan case. The clutch would flow as well as soon as it became the path of least resistance to the battery. Things like stereos, wipers, headlights, etc would all need to flow through the engine. A much better path for those is through the frame. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1790 Location: Mouth of the Columbia
Posted: Sat May 09, 2015 6:01 am Post subject: |
My second 72 and they were both grounded like this:
_________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Posted: Sat May 09, 2015 9:08 am Post subject: |
| aeromech wrote: |
| Wildthings wrote: |
| aeromech wrote: |
WT,
Respectfully I need to disagree. By installing the "battery return" ground strap to the engine, you'd be sending ALL the electrical loads through the transmission strap, the engine, and fan case. The clutch would flow as well as soon as it became the path of least resistance to the battery. Things like stereos, wipers, headlights, etc would all need to flow through the engine. A much better path for those is through the frame. |
Per the original system all the loads you mention are already flowing through the tranny ground strap when the alternator is charging as the strap is the return path to the alternator. If they also flow through the ground strap at those times the engine is off or the alternator is not putting out sufficient amps then such a load is minimal compared to the starting load.
With the engine running and the alternator putting out a large amount of extra amps to charge the battery then the load on the tranny ground strap will be less than as per the original system and not more. |
