How much do you torque your lugs?
pushkick
pushkick is offline
PostPosted: Sat May 23, 2015 3:32 pm    Post subject: How much do you torque your lugs? Reply with quote
on standard steel rims how much do you torque your wheel lugs?
the reason i am asking i am thinking about buying cordless impact tool.
want to make sure it will work.
i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper
djkeev
djkeev is offline
PostPosted: Sat May 23, 2015 3:38 pm    Post subject: Reply with quote
Non lubricated Nuts/lugs 100 lbs though I'm anal and always gi a tad tighter..... Not sure why.
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat May 23, 2015 3:42 pm    Post subject: Reply with quote
Just looked at Bentley.... Up to 1984 125 ft lbs
After... 135 ft lbs.
Now I know why I go tighter!!!!
Dave
Ghia
Vanagon
Beetle
Steve M.
Steve M. is offline
PostPosted: Sat May 23, 2015 3:43 pm    Post subject: Reply with quote
Why would you use/trust an impact tool to torque your lugs?
I remember Bentley as saying 123 ft.lbs., dry.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat May 23, 2015 3:48 pm    Post subject: Reply with quote
Goldilocks tight
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
Wildthings
Wildthings is offline
PostPosted: Sat May 23, 2015 3:56 pm    Post subject: Re: how much do you torque your lugs Reply with quote
A torque wrench is what will work. Wink
Steve M.
Steve M. is offline
PostPosted: Sat May 23, 2015 4:19 pm    Post subject: Reply with quote
This raises a good question.
If you follow Bentley's 123 ft.lbs. on original steel,
what torque do you use on aluminum wheels?
insyncro
Banned
insyncro is offline
PostPosted: Sat May 23, 2015 4:23 pm    Post subject: Reply with quote
Going tighter is not better.
Ask your brake rotors/drums.
Ahwahnee
Ahwahnee is offline
PostPosted: Sat May 23, 2015 5:41 pm    Post subject: Reply with quote
Steve M. wrote:
Why would you use/trust an impact tool to torque your lugs?...
Perhaps the OP is wondering if the cordless impact wrench will be stout enough to undo a properly torqued lug.
To the OP - in my experience the torque claims made by electric impact wrenches are wildly optimistic. They certainly have their uses but don't expect miracles.
Pondo
Pondo is offline
PostPosted: Sat May 23, 2015 6:01 pm    Post subject: Reply with quote
This may be useful....
http://t3technique.com/media/pdf/Lug_torque.pdf
85 Weekender WBX
ThankYouJerry
ThankYouJerry is offline
PostPosted: Sat May 23, 2015 6:13 pm    Post subject: Reply with quote
Peter at Van Cafe advised me 123# on my 15" Carrot Wheels (alloy).
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
shadetreetim
shadetreetim is offline
PostPosted: Sat May 23, 2015 7:30 pm    Post subject: Reply with quote
My thought would be to use the impact to spin the lugs on and off quickly, but use a torque wrench to finish tightening.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
rubbachicken
rubbachicken is offline
PostPosted: Sat May 23, 2015 7:37 pm    Post subject: Reply with quote
i always go to 120 ftlbs and go around twice.
i met a van who had new wheels put on, who ever put them on, only went around once Rolling Eyes 2 of 5 were tight, the rest were loose Shocked
same on all the wheels.
the center of the wheel was tight on the rotor, too tight, so they got to torque, but they were not seated on the rotor as the should have been.
lucy our westy
lucy's BIG adventure
meet 'burni'
Wildthings
PostPosted: Sat May 23, 2015 7:44 pm    Post subject: Reply with quote
That is about as good an article as I have seen. What it doesn't mention though is that under torquing the lugs can cause the lugs to seize/gall to the wheels from the tiny bit of movement they get from the lug nut working against the seat. When I first took my '91 into my local tire place in a town with lots of Vanagons, they flat out refused to tighten the lugs any tighter than 90ft*lbs because they were having too much trouble removing them at that torque and they believed that if they tightened them tighter they would not be able to get them off at all. Well I stood my ground and forced them to tighten them to 123ft*lbs. They eventually consented to doing so and also tried the higher torque out on some other Vanagons. What they found was that the lugs were easier to remove months or years later when torqued to the proper specs and not harder.
These days and for probably the last decade I have not had to tell them to use the 123ft*lbs spec, they just do it, though I do still routinely quiz them on the specs.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun May 24, 2015 7:21 am    Post subject: Reply with quote
Three hammer's on your 1/2" impact will do just fine.
Perfect--
T.K.
Gauche1968
Gauche1968 is offline
PostPosted: Sun May 24, 2015 8:20 am    Post subject: Reply with quote
Stock steel wheels: 133 ft/lbs front, 123 ft/lbs rear, right?
1984 Vanagon GL
1984 Vanagon Westy
Wildthings
PostPosted: Sun May 24, 2015 9:08 am    Post subject: Reply with quote
