Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10226 Location: Mt Lemmon, AZ
Posted: Tue Sep 02, 2014 3:49 pm Post subject: |
Right forward on a Digijet. This puts it very close to the starter.
BTW - That relay is non-stock, my version of a hot-start relay. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
porterbrown Samba Member
Joined: February 25, 2005 Posts: 718 Location: Bentonville, AR
Posted: Sun May 24, 2015 8:16 pm Post subject: |
djkeev wrote: |
Plus one more ground connection.
LF cross member, on the body just inside of the Left Fuel Vapor tank.....
A single screw holding the ground wire for the fuel level sensor
AND
If an Automatic, the ground for the shift indicator lights....
[pic]
Dave |
Either you already read this other thread or you have some serious ESP!
http://www.thesamba.com/vw/forum/viewtopic.php?t=627891
About midway down the 1st page, you'll see where we were talking about the same ground, though it's also supposed to somehow serve ECU as well. Thoughts? _________________ '90 Westfalia GL Automatic |
kamzcab86 Samba Moderator
Posted: Mon May 25, 2015 5:58 pm Post subject: |
djkeev wrote: |
AND
If an Automatic, the ground for the shift indicator lights.... |
If there are only 2 wires grounded there, the level sender and A/T lights, then the ECU ground is elsewhere (edit: the VW diagram in Bentley shows the ECU grounding "near the fuel gauge sender"). I took a look at my '90 today: the ECU ground wire disappears under the water tank cabinet... where it goes after that, I've no clue. I'm not removing the cabinetry just to find a ground point; if it comes to it, I'll snip that wire and reroute it to a much more convenient spot. _________________ ~Kamz
2016 Golf GTI S
Posted: Mon May 25, 2015 6:54 pm Post subject: |
djkeev wrote: |
I have an 86 "Weekender" full width rear bench.
ECU is mounted well to the left of center with the ground screw next to it. |
The point in my prior post is that the 1990-1991 wiring diagram shows the ECU being grounded "near the fuel gauge sending unit" (edited to reflect this info), as discussed in porterbrown's linked topic.
To elaborate on this mess, the Digifant ECU pin 19 ground is the same for all years: on left side of engine. On the other hand, pin 13 ground points by year, as shown in the diagrams:
1986: under rear bench seat (ground point #17)
1987-1989: near Digifant control unit (ground point #29)
1990-1991: near fuel gauge sending unit (ground point #29)
Ground point #12 is "left front crossmember" for 1986, and is "left engine compartment" for 1987-1991.
So, it appears that the 1990-1991 ground point label should have read "near Digifant control unit" and the fuel gauge sender should have been given its own location number. In the full-campers, the ECU ground is a bitch to get to... German engineering. _________________ ~Kamz
2016 Golf GTI S
vegpedlr Samba Member
Posted: Tue May 26, 2015 7:12 am Post subject: |
Is there similar info available for the 1.9? I read over and over about the importance of checking/cleaning grounds, but I'm a mystified noob. |
Posted: Wed May 27, 2015 6:44 pm Post subject: |
djkeev wrote: |
vegpedlr wrote: |
Yes, Bentley page 97.54 and following......
Dave |
Got it, thanks. I was hoping for pretty pictures like elsewhere in this thread, but it's OK because I love curling up with my Bentley and a glass of wine... |
Merian Samba Member
Posted: Mon Aug 31, 2015 10:50 am Post subject: |
maybe it would be wise to replace this gnd point with one inside the vehicle - there is already a penetration in the body for the signal wire, so why didn't VW run the gnd wire up inside too? |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5711 Location: Bemidji, MN
Posted: Wed Sep 06, 2017 12:06 pm Post subject: Re: Ground Locations - 2.1L |
don't forget the main battery > starter cable. just replaced mine and the starter end of the cable was crispy with corrosion for about a foot up the cable. here's a photo of the end, right behind the ring terminal for the starter. top cut is right behind the battery clamp, bottom at the starter.
i'd purposely wiggled it to feel the strands break but you can see what little of the main cable was left attached to the starter lug. the new OEM cable from Van-Cafe is extremely nice quality, i don't think you could buy welding cable, ends, grommets, for much less. it is larger than 2/0 with high strand count in a rope configuration. very flexible. totally worth $50.
my tank is out for grommets and with the cable attachments, there is no way one could pull another cable thru the exact path as the fastening points are secure.
-dan |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Fri Mar 23, 2018 9:26 am Post subject: Re: Ground Locations - 2.1L |
Good photo Dan. That wire is half-size at the break, and one can assume that due to the corrosion (strand to strand) it's not employing the wire size even where it's NOT broken. Also the strands you see "not broken" here, may be broken at other locations.
I've been driving my van Seattle to California and back, and having NO problems. Then last week it wasn't charging the battery (400 miles from home). The engine temp gauge was high too, blinking its red warning light, while my scangauge showed normal engine temp @ 188*F.
Grounding with this jumper cable produced a spark. I measured voltage across it and found 2+ volts lost by the bad ground. I took apart the ground at the front of the trans and found it to be clean. As expected cuz I looked it over within the last 2 years. So, this 2 volt loss was in the engine-to-transmission boltup. Confirming why my engine-to-bellhousing dowels were so rusted stuck. When I saw that (2 years ago) I made a mental note to check my engine grounds, and forgot.
Anyway fast forward to March 2018.... there was no engine ground. Smallcar install relied on the transmission ground ONLY. This was a 2009 install, so any of you who have SmallCar installs from that era, you might verify (or add) an engine to chassis ground. _________________
....KTMs, GasGas, SPOT mtb |
urquattro Samba Member
Posted: Wed Jul 04, 2018 11:31 am Post subject: Re: Ground Locations - 2.1L |
Does anybody know where is the windscreen washer pump ground,? In the Bentley says that is behind the dashboard but not behind the relays, I can't find any other ground wires apart of the ones on the relays box. I'm having problems with that, my Vanagon has headlights washer as well and as soon as I dissconect one of the pumps the other is working but not with both of them connected. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Jul 04, 2018 12:11 pm Post subject: Re: Ground Locations - 2.1L |
Ground locations are shown in your Bentley manual. Quicker that asking someone else to do it. |
Posted: Wed Jul 04, 2018 12:43 pm Post subject: Re: Ground Locations - 2.1L |
dgbeatty wrote: |
I've been checking the Bentley, as I said it does not specify where, just behind dashboard but not where, must be a single brown cable. There is no information about the single grounds location in the Bentley manual. |
