Type IV (4) Engine Tin installation
barefootwestie
barefootwestie is offline
PostPosted: Mon Jun 01, 2015 9:22 am    Post subject: Type IV (4) Engine Tin installation Reply with quote
Does anyone know the sequence of order for the engine tins on a '73? Removed mine to paint and didnt take notes, ugh. I think the cylinder covers go back in first.
My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia
white74westy
white74westy is offline
PostPosted: Mon Jun 01, 2015 10:35 am    Post subject: Re: Engine Tin installation order Reply with quote
When all else fails, go to Ratwell:
http://www.ratwell.com/dotmac/Sites/Type4/PhotoAlbum81.html
Start here about 2/3rds of the way down the page and go from there. Hope this helps! Let us know how it turns out!!! Cool
Wildthings
Wildthings is offline
PostPosted: Mon Jun 01, 2015 10:36 am    Post subject: Re: Engine Tin installation order Reply with quote
The left rear tin needs to go on before the fan shroud, IIRC and then the other fore and aft tins go on after the shroud but before the two large cylinder tins. The under cylinder tins need to go on prior to inserting the pushrods and tubes.
The rear support bar goes on before the heat exchangers.
barefootwestie
PostPosted: Mon Jun 01, 2015 10:38 am    Post subject: Reply with quote
Thanks. I searched throughh the index but must have overlooked it.
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia
Tcash
Tcash is offline
PostPosted: Mon Jun 01, 2015 10:42 am    Post subject: Reply with quote
Type 4 engine tin search
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
Good Luck
Tcash
Tcash
Tcash is offline
PostPosted: Wed Jul 22, 2015 8:36 am    Post subject: Type IV (4) engine tin installation Reply with quote
To link to this post
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?p=7758607#7758607]Type IV (4) engine tin installation[/url]
Please do not take the fan apart. You would need to realign and balance it.
Complete series playlist Part 1-6
https://www.youtube.com/watch?v=CB4soH8Wolk&list=PL5l9C9G7d1xnQvVwQeFtSE7DZuJfF_sOJ
1967250s
1967250s is offline
PostPosted: Wed Jul 22, 2015 10:36 am    Post subject: Reply with quote
That video series needs to be a Sticky! Especially the one about the lower tin over the thermostat.
'72 Elm Green Deluxe
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 22, 2015 10:36 am    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
Tcash wrote:
awesome powdercoat type iv engine tin install part 1
OMG don't take the fan apart. I did that and it took Mark (BusDaddy) close to a year to get it balanced again. They get terrible run out in them unless they go on a lathe and are adjusted a tiny bit at a time. REALLY
captincanuck
captincanuck is offline
PostPosted: Wed Jul 22, 2015 5:45 pm    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
Really? Wow I was literally days away from taking mine apart to paint it. One of the last pieces left. Won't be doing that now. Thanks for the heads up
1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0
Tcash
Tcash is offline
PostPosted: Wed Jul 22, 2015 7:09 pm    Post subject: Reply with quote
Youtube Videos
Tcash
busdaddy
busdaddy is offline
PostPosted: Wed Jul 22, 2015 7:57 pm    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
Слава Україні!
a-marshal
a-marshal is offline
PostPosted: Thu Jul 23, 2015 5:04 am    Post subject: Reply with quote
Tcash wrote:
Youtube Videos
Tcash
Wow... that is an impressive list ... why didn't I see that before?
Not only should it be a sticky but it should be the first stidky..
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu Jul 23, 2015 8:06 am    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
What if you marked exactly the position of the fan relative to the pulley, and each nut and bolt? Would it preserve its balance?
And, I wonder how much influence on throwing off the balance from paint or powdercoat?
I suppose it is not worth the risk. It's not like this demands fresh paint.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
busdaddy
busdaddy is offline
PostPosted: Thu Jul 23, 2015 8:36 am    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
It's less about the balance and more about the pulley running true, it's very challenging to get the ring positioned, just aligning the outer ring with the edge of the fan doesn't do it.
Слава Україні!
raygreenwood
raygreenwood is offline
PostPosted: Thu Jul 23, 2015 8:40 am    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
NO.....On these fans....the balance as SGKent noted...is delicate. Not only do the main parts have to be put back together correctly....but each bolt and washer needs to go back in the same place it came from...and in the same exact position it was in.
There is a small amount of slack in the bolt holes and washers. It makes just enough of an alignment issue that even though the actual balance may not be off when you get it back together....it can run rough. They parts were assembled with schnoor type lock washers and balanced as a complete assembly.
If the fan is really crappy....you need to score around each washer, make some assembly scribe lines....and put the parts in a dedicated numbered holder so you can reassemble it. Its a lot of work.
A year or so ago...I bought a spare fan from someone in the classifieds....this person crammed it into a box that was not correctly sized and disassembled it to make it fit Rolling Eyes ....and didnt get it when I told him it was now useless without considerable work and some expense. Ray
Xevin Premium Member
Xevin is offline
PostPosted: Thu Jul 23, 2015 9:04 am    Post subject: Reply with quote
That's some crazy mechanical info you all know. I will keep saying this. The information I learn from you guys on what not to do has saved me more then once. I wasn't planing on doing that. But I now know, not to do it. So big thanks to all those above, Aeromech, Colin, and more.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
BUSBOSS
BUSBOSS is offline
PostPosted: Tue May 10, 2016 10:35 pm    Post subject: Re: Type IV (4) Engine Tin installation Reply with quote
Any tips on painting the pulley while the fan is attached?
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
ivwshane
ivwshane is offline
PostPosted: Thu Mar 29, 2018 2:02 pm    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
First off, thanks for posting the awesome powder coat videos! They should help me immensely.
Sgkent, when you say, "don't take the fan apart" are you saying not to remove it at all? Or are you saying not to remove the fan pulley from the fan?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
raygreenwood
PostPosted: Thu Mar 29, 2018 2:29 pm    Post subject: Re: awesome powdercoat type IV (4) engine tin installation Reply with quote
Do NOT remove the black steel alternator belt pulley from the cast aluminum section with the fins.
That being said....after recently going through my stack of spare fans....I have found at least three that....you would swear looking at them that they have "probably" never been apart...so they "should" be straight and true..........but after measuring I found that its painfully obvious that whoever the previous owner was....either took them apart or diddled with them.
Also...if they are dropped hard enough it can move the pulley ring. If they get corroded enough between the pulley and fin section...they can get loose.
This thread below may help to understand a little about what is entailed to get one straight. This is just one way to do it. While a lathe can help make it simpler...its not necessary at all...and it just does not take that long.....but it IS tedious.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8681745#8681745
You can use some of the information in that thread...to at least measure yours to see what condition its in....while its mounted to the crank. Ray
ivwshane
ivwshane is offline
PostPosted: Thu Mar 29, 2018 3:21 pm    Post subject: Re: Type IV (4) Engine Tin installation Reply with quote
Thanks but I'd rather be safe and not take my chances, my skill level is limited and even just removing all the tin ware is intimidating.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
