My attempt at a transaxle cooler (manual trans)
Page: Previous  1, 2, 3, 4, 5, 6
nmerrill
nmerrill is offline
PostPosted: Fri Jan 23, 2015 4:33 pm    Post subject: Reply with quote
I thought that was a great idea too, except, I'm not sure I want to be pumping potentially thick gear oil through a whole cooler system when cold.
Now, set that PS pump up with an electric clutch from a AC pump...
vwwestyman
vwwestyman is offline
PostPosted: Fri Jan 23, 2015 5:41 pm    Post subject: Reply with quote
I just liked the idea because I have a stock pump sitting on the shelf as a leftover.
It seems like at least one of the participants in this thread has the pump running anytime the engine is running vs switched by a thermostat. Maybe I am wrong on that.
If for some reason it would be bad to pump cold oil through the cooler, perhaps the stock PS pump could still be used...
What about a solenoid switched by a thermostat that simply closed the line between the pump and transaxle? So the vanes or whatever of the pump would be spinning in the oil that was in the pump, but they wouldn't actually push it anywhere until the solenoid opened.
If that was bad, then instead the solenoid switches between a recirculating loop and the loop containing the cooler could work.
Dave Cook
1973 Wild Westerner
My Thing
newfisher
newfisher is offline
PostPosted: Fri Jan 23, 2015 8:17 pm    Post subject: Reply with quote
Or a tee'd return just before the thermostat/solonoid.
dkoesyncro
dkoesyncro is offline
PostPosted: Mon Jul 06, 2015 5:03 pm    Post subject: Reply with quote
I was just wondering how this trans cooler is holding up? With the recent post of trans failure, this seems like cheap insurance until the rebuilding is needed!
garryv84
garryv84 is offline
PostPosted: Mon Jul 06, 2015 8:18 pm    Post subject: Reply with quote
Mine works great!
Heat not a problem anymore.
But the parts inside can be weak.
Should not go more than 125hp
Sodo
Sodo is online now
PostPosted: Mon Jul 06, 2015 11:46 pm    Post subject: Reply with quote
vwwestyman wrote:
Is there any reason any of you can think of that reinstalling the PS Pump, and using it for gear oil as described here, wouldn't be a good idea?
Is there any reason to pump oil cooler than 160F? A belt pump that runs all the time might cost fuel mileage.
An electric pump that only runs while temps exceed 160F sounds like a better idea. I wonder how much the electric pump would run. Only when climbing a mountain pass? Or do they run all the time you're on the freeway?
....KTMs, GasGas, SPOT mtb
insyncro
Banned
insyncro is offline
PostPosted: Tue Jul 07, 2015 4:07 am    Post subject: Reply with quote
This is why you need a temp sender in your case.
You will see exactly how often your box heats up.
I use an electric fluid pump.
Weddle offers the complete kit.
Yes, it is big dollars and worth every penny.
Make sure your rebuilder is up to speed on the internal mods that go along with the auxiliary cooling.
Sodo
Sodo is online now
PostPosted: Tue Jul 07, 2015 11:30 am    Post subject: Reply with quote
I agree on the temp sender. A guy could parallel a switch ontop of the sender, for 'control'. Certainly an LED that tells when pump is running, and I like the guage too. Do they still make those guages that operate a switch too?
I don't see why it needs to be big dollars. A pump is $140 and the rest is just fittings and hoses and electric parts. If it only runs when overheated this should not be full time. But the question remains for a normal Van with a normal EJ25 Cool and normal tires.
The next questions. Are there a few simple mods (oil holes etc?) that you can ask a tranny rebuilder to do, that will prepare a tranny for a shadetree mechanic's oil cooler setup?
Such as
- Drill ESSENTIAL passageways (if they are essential for a cooling function)
- Where to Drill & tap "in & out" holes
- Where to Drill & tap sensor hole
I personally would not worry much about magnesium chunks from drilling into the case. Drill carefully, and with grease on the bit & grease on the tap. I've been running my tranny for (up to) 9,000 miles with flakes of hardened bearing surface in the oil and a LOT of it. IMHO a few chunks of magnesium is an insignificant downside to adding a cooler.
What Alaric did, RULES! I could live with that (thru filler and drain holes), and even using push-on fittings & band-clamps. Many, many of us did it in the old days on Bug motors. I NEVER had a problem with oil pressures that far exceed what this cooler will see.
insyncro
Banned
insyncro is offline
PostPosted: Tue Jul 07, 2015 3:13 pm    Post subject: Reply with quote
Two words.....scavenger filter
Before you ask...an Oberg, pick the micron level you wish to filter.
Running with metal suspended in the fluid is not a good idea.
Sodo
Sodo is online now
PostPosted: Tue Jul 07, 2015 3:38 pm    Post subject: Reply with quote
Absolutely NOT! A grinding paste of steel bearing hardsurface flakes kinda gives me the willies just thinking about it.
Saw the oberg, its a nice unit. But any filter is better than none. Remember Type1s (no filter!).
I should have drained a little off the bottom (cold, settled) just as a routine measure. It was quite easy to check. Just pull the plug and poke a finger in the hole. Then put it back.
FrankenSubySyncro
FrankenSubySyncro is offline
PostPosted: Tue Jul 07, 2015 5:29 pm    Post subject: Reply with quote
Sodo, in case you haven't seen this thread http://www.thesamba.com/vw/forum/viewtopic.php?t=5...;start=160
Also check out page 10. Just cooling the oil and returning it back through the fill hole does not solve the oil delivery problem to 4th gear and the main shaft bearing. I saw temps as high as 165 (with pump and fan on) last weekend from Ellensburg to Hood river. The average temp was about 150.
Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/
dobryan
dobryan is offline
PostPosted: Tue Jul 07, 2015 8:50 pm    Post subject: Reply with quote
And to answer your other question, yes, Matt at AA can set up the tranny for a future cooler addition, plumbed with fittings ready to go. That's what I had him do to mine. I've yet to install the actual cooler and pump, just monitoring temps for now. That's one project that I ran out of time on before I left for the summer....
Dave O
The Western Syncro build
Sodo
Sodo is online now
PostPosted: Tue Jul 07, 2015 9:13 pm    Post subject: Reply with quote
Estimating what the temp might be without a system (and a fan!) is kind of scary.
Wow this whole thing about adding an entire "SYSTEM" has me a little worried. Sounds easy at first, but the devil is in the details and the priming/drainback, and temp thresholds…..man its getting complicated.
Temp guage to evaluate the driving stresses sounds easy.
The oiling mods, and plumbing outlets at rebuild time sounds like a good way to go. And then when the pioneers figure out the cooling system, you'll have the ports ready for it.
flomulgator
flomulgator is offline
PostPosted: Fri Feb 05, 2016 6:46 pm    Post subject: Re: My attempt at a transaxle cooler (manual trans) Reply with quote
Anyone here end up running the Tilton pump on their van? I'm interested in hearing reports on how loud it is.
Also, anyone ever try the overflow tank?
She's built like a steakhouse, but she handles like a bistro!
insyncro
Banned
insyncro is offline
PostPosted: Sat Feb 06, 2016 7:30 am    Post subject: Re: My attempt at a transaxle cooler (manual trans) Reply with quote
I have years of using Tilton pumps on many different differentials.
There is plenty of information about them in Porsche forums as most racers cool the diff.
I have replaced the cost effective/eBay pump that Gears and I discussed a while back with a Tilton.
The only reason, I have a stack of donated Tiltons and want all of my systems built from the same parts.
Long story short...I only recommend using a fluid pump that has been designed for use with gear oil.
flomulgator
PostPosted: Sat Feb 06, 2016 9:03 am    Post subject: Re: My attempt at a transaxle cooler (manual trans) Reply with quote
Yeah it's either a Tilton, Weddle, or RB Racing gear oil pump for me, that became quickly apparent during research. Can you comment on how loud the Tilton is when installed on a Vanagon? I've read on other forums that it can be atrociously loud, but those were much older posts (and thus pumps) on entirely different vehicles.
Page 6 of 6
