Identify this Part.
Page: Previous  1, 2, 3  Next
xflyer
xflyer is offline
PostPosted: Tue Jun 16, 2015 7:23 am    Post subject: Reply with quote
That is a 12V power socket. Some call it a "power point". Works with most anything 12VDC. Earlier Bay window vans were sometimes supplied with a 'compact' spare tire and an air compressor to inflate it. Those should have been replaced long ago (the spare tire) as there was a recall due to the tire failing after being inflated and driven on. They sometimes blew out during inflation.
Some Vanagons came with a 12V cooler. It would plug in that socket.
BTW you need the correct plug.
1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C
Campton Slow
Campton Slow is offline
PostPosted: Tue Jun 16, 2015 7:37 am    Post subject: Reply with quote
Aha! THANK YOU.
That was driving my crazy. Now that you've given me that info, I was able to find this (for anyone else wondering).
Now I need to find some original accessories!
Thanks again!
1980 Vanagon, 1976 Standard Bug
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Jun 16, 2015 9:25 am    Post subject: Reply with quote
That's the fabled "Silver Socket"! Old school accessory power. Smile
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
ZsZ
ZsZ is offline
PostPosted: Tue Jun 16, 2015 12:13 pm    Post subject: Reply with quote
DIN (German Industrial Standard) power socket. You can buy various adaptors to connect the more common cig. lighter accessories.
https://www.google.com/search?q=Din+socket+adaptor...mp;bih=937
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
jimf909
jimf909 is offline
PostPosted: Tue Jun 16, 2015 12:35 pm    Post subject: Reply with quote
Interestingly, John Deere tractors used this plug as well. It was a good replacement for BMW motorcycle owners who didn't want to pay BMW prices for the plug (you know, they say the only cheap thing on a BMW is the rider Very Happy ).
- Jim
Butcher wrote:
Guilty as charged.
bstein
bstein is offline
PostPosted: Thu Aug 06, 2015 3:17 pm    Post subject: Reply with quote
During some routine maintenance and cleaning out of the van, I found this thing buried under the bench seat. Is this an accessory part to anything? TIA!
Brian
1987 Syncro Wolfsburg Weekender | Triple Knob | SAH 1.8T
Forthwithtx
Forthwithtx is offline
PostPosted: Sun Aug 09, 2015 10:57 am    Post subject: Reply with quote
What are these? They came with my parts van and I have no idea what they are.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sun Aug 09, 2015 11:50 am    Post subject: Reply with quote
Those look like pieces from the "doghouse" cooler tin from a Beetle
djkeev
djkeev is offline
PostPosted: Sun Oct 18, 2015 7:48 am    Post subject: Reply with quote
86 Vanagon, disassembled by another and put into coffee cans and boxes....... Now mine.
What is this????
Basically a square rubber cube with some ribbing and cuts from sheetmetal......
Yes, it has a part number but makes it too easy!
Dave
Ghia
Vanagon
Beetle
ZsZ
ZsZ is offline
PostPosted: Sun Oct 18, 2015 8:23 am    Post subject: Reply with quote
What is this????
[pic]
Dave
sliding door upper bumpstop?
Zoltan
imikeh
imikeh is offline
PostPosted: Tue Nov 08, 2016 9:23 am    Post subject: Re: Identify this Part. Reply with quote
Part is from driver door. 1991. Holds handle on pictured is bottom part. Top part broke
WannaDriveFar
WannaDriveFar is offline
PostPosted: Wed Feb 21, 2018 11:56 am    Post subject: Re: Identify this Part. Reply with quote
I'm very new to my Vanagon, and trying to work on my own vehicles in general. What should I be Googling to help me learn more about this frayed hose?
shagginwagon83
shagginwagon83 is offline
PostPosted: Wed Feb 21, 2018 2:14 pm    Post subject: Re: Identify this Part. Reply with quote
It's just a vacuum hose that goes to the aux air regulator. You can take it to FLAPs and get a new one.
AZ Landshaper
AZ Landshaper is offline
PostPosted: Sun May 27, 2018 11:29 am    Post subject: Re: Identify this Part. Reply with quote
Trying to put my purchase back together after the PO disassembled nearly everything.
What are these parts?
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun May 27, 2018 11:41 am    Post subject: Re: Identify this Part. Reply with quote
I see supports for the exhaust system (you'll have fun finding where they each go), engine tins (left & right) and tie rod boots.
I do not recognize the subject of the last photo.
BillM
BillM is offline
PostPosted: Mon May 28, 2018 4:53 am    Post subject: Re: Identify this Part. Reply with quote
The last photo is of a seat organizer. The piece in top of photo belongs on the bottom of the other piece.
Also supposed to be two hooks to go over seat top.
It’s made for police but we use to get them at phone company for our trucks.
It’s molded to hold a baton,3-cell plus maglite.
Two spots for hand cuffs.
It’s broken..toss it.
Bill M
87 Westy
VicVan
VicVan is offline
PostPosted: Thu May 31, 2018 10:36 am    Post subject: Re: Identify this Part. Reply with quote
Hi
Removed the glovebox yesterday to work on the new stereo. What's this, and specifically what is this 4-thing connector with three wires in it?
Where should I plug it so I can hopefully gain 30 horsepower?
After a bit of research, the grey box is a Cruise Control ECU? But I don't have Cruise Control on the van... Is it some sort of prewiring?
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
T3 Pilot
T3 Pilot is offline
PostPosted: Thu May 31, 2018 11:12 am    Post subject: Re: Identify this Part. Reply with quote
Unused connector on my Manual ‘90
Maybe it was for a dash light in other cars using the same computer
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
VicVan
VicVan is offline
PostPosted: Thu May 31, 2018 12:22 pm    Post subject: Re: Identify this Part. Reply with quote
Does yours have cruise control though ?
T3 Pilot
T3 Pilot is offline
PostPosted: Thu May 31, 2018 1:55 pm    Post subject: Re: Identify this Part. Reply with quote
Ahyup.
1988 Vanagon
Page 2 of 3
