Shifter differences
Page: Previous  1, 2, 3  Next
PostPosted: Sun Sep 27, 2015 4:15 pm    Post subject: Reply with quote
I think they are interchangeable in that you can use a later spring on an earlier shifter but I have seen people selling "early" springs in the past.
I found this quote from an old ad for a "50-59" NOS shifter spring on the site:
Here is an NOS 1950-59 bus shifter spring,the coiling diameter at the top is about 3/16" smaller [7/8"] than the 1960 up [1 1/16"] because the 50-59 straight shifter had the small diameter ball. 1960 up curved shifter had the larger diameter ball with the pin.
CaLiBus
CaLiBus is offline
PostPosted: Mon Feb 20, 2017 5:47 pm    Post subject: Reply with quote
So does Wolfsburg West have this Wrong??? they told me at the counter that this is correct for my 61 but the inside diameter hole is smaller than the shifter ball.. my old one on the right out of my bus
zuggbug
zuggbug is offline
PostPosted: Mon Feb 20, 2017 6:32 pm    Post subject: Re: Shifter differences Reply with quote
Yes they made a mistake, hard to believe
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
BarryL Premium Member
BarryL is offline
PostPosted: Mon Feb 20, 2017 7:28 pm    Post subject: Re: Shifter differences Reply with quote
Weird part number. Your part should be 214 711 155. The part that is pictured is '66-'67 and should be numbered 211 711 155 C. However Wolfsburg West may have made a universal one that goes from '62-'67. It's still not the '61 correct one for you.
CaLiBus
CaLiBus is offline
PostPosted: Mon Feb 20, 2017 8:33 pm    Post subject: Re: Shifter differences Reply with quote
Appreciate the info but if it were a 66-67 shift rod then why does it have the early style end for the 62 and earlier coupler?
Anyhow, after we debated back and forth at the counter he went and got a second opinion from an "expert" and came back. "yup, its correct for a 61" Confused
By the way.. much props to WW. Just trying to clear this up.
BarryL is offline
PostPosted: Tue Feb 21, 2017 10:11 am    Post subject: Re: Shifter differences Reply with quote
I could easily be wrong but I got the info from the parts book website. I assume your bus vin falls into the '61 year model.
I can't see the other end in the photo but that hole on the front is for the '66-'67 style pivot as those years didn't use a bracket with tensioned plastic guide/anti-rattle.
The acid test to me is that your ball won't fit his hole. Did you take your shaft with you?
CaLiBus
CaLiBus is offline
PostPosted: Tue Feb 21, 2017 11:49 am    Post subject: Re: Shifter differences Reply with quote
Thanks Baryl. No did not have the old parts in hand the first time assuming they would have the correct parts. Lesson learned..
The descrition itself on the label 59-62 seems to be wrong as well? Crossing over into different years?
BarryL is offline
PostPosted: Tue Feb 21, 2017 1:15 pm    Post subject: Re: Shifter differences Reply with quote
I've never had to deal with early rods but something is awry. See for yourself. Parts #11 or #12: http://oacdp.org/5867part/359.png
You bus vin/year: http://www.thesamba.com/vw/archives/info/chassisdating.php
CaLiBus
CaLiBus is offline
PostPosted: Tue Feb 21, 2017 3:15 pm    Post subject: Re: Shifter differences Reply with quote
Now Look at #3
Shouldn't the lever change the same time with No 11 ?
BarryL is offline
PostPosted: Tue Feb 21, 2017 7:32 pm    Post subject: Re: Shifter differences Reply with quote
CaLiBus wrote:
Now Look at #3
Seems that way but I don't know for sure when the ball size changed. There is that rod after the shifter change but before the next one (not counting the '66-'67]. Someone else needs to cut into this dance. I know the early shifter was closer to the seat pedestal then moved forward so maybe that is when the ball changed as the shift rod had to be longer and maybe all the forward ones have the smaller ball.
ToolBox
ToolBox is offline
PostPosted: Wed Feb 22, 2017 10:05 am    Post subject: Re: Shifter differences Reply with quote
BarryL wrote:
CaLiBus wrote:
Now Look at #3
There are 3 gear shift levers
Early close straight 211 711 121
Mid further bent 211 711 121A
Late further bent 211 711 121B
There are also 4 different fron shift rods listed.
BarryL is offline
PostPosted: Wed Feb 22, 2017 10:55 am    Post subject: Re: Shifter differences Reply with quote
Excellent.
Can someone list the ball size (big/little) to associate with these levers?
Everett wrote:
Early straight shifter ends:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=533921
Shifter from my '55:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=518622
'61 Kombi shifter with ruler:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=233441
Everett posted this on the page before but I can't tell ball size.
easy e
easy e is offline
PostPosted: Wed Feb 22, 2017 11:45 am    Post subject: Re: Shifter differences Reply with quote
Berg site sez:
Pre-60: 15.7mm ball and approx 22" tall.
60-mid 1966: 21.50mm ball and approx 7/8" from bottom of base to bottom of ball. Total length approx 25" floor to top of handle.
mid 1966-79: Length approx 25" from floor to top of handle.
aka: Evan
sandtrooper747
sandtrooper747 is offline
PostPosted: Sat Jun 17, 2017 5:12 pm    Post subject: Re: Shifter differences Reply with quote
Did the shift rod bracket change in 67? WW has it up to 66: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701255B
BarryL is offline
PostPosted: Sat Jun 17, 2017 6:58 pm    Post subject: Re: Shifter differences Reply with quote
'66 and '67 don't use that but you can if you want to change your '66 or '67 to that older style. Cut off the front pin that '66 and '67 front shift rods use if you use that earlier one but '66 and '67 style work better.
missmybus
missmybus is offline
PostPosted: Sun Jul 30, 2017 3:51 pm    Post subject: Re: Shifter differences Reply with quote
Do I have the right shifter base on my early 64 bus? I'm thinking I don't based on a gallery pic from @RareAir. Accordingly to the gallery pic, I have a type 1 base, not a type 2. Can anyone chime in? Thanks,
Brian
64 Deluxe
sgellis
sgellis is offline
PostPosted: Mon Jul 31, 2017 8:47 am    Post subject: Re: Shifter differences Reply with quote
My early 64 has the higher base. What you have may work but your reverse lockout will not so finding first will be a pain. Also it may damage your linkage if it is putting too much force down.
If that came with your bus you may also have a modified shifting lever or linkage.
edit: You could space the base up off the floor the difference in height to get by until you find the correct one.
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
missmybus
PostPosted: Mon Jul 31, 2017 12:21 pm    Post subject: Re: Shifter differences Reply with quote
OK, thanks. Think I should get the taller one. I've been restoring this bus for almost 3 years, why not have the right base? Thanks for the response!
64 Deluxe
PostPosted: Fri Sep 18, 2020 8:55 am    Post subject: Re: Shifter differences Reply with quote
Someone asked me today how to tell a Bay Window shifter from a 66-67 shifter.
Anyone have both on hand to post any photos of differences and/or measurements?
Humberto lapa
Humberto lapa is offline
PostPosted: Sat Sep 26, 2020 2:31 pm    Post subject: Re: Shifter differences Reply with quote
On 66 and 67 bus shifter bottom pin shown in this pic, is it suppose to have that spring exposed?
Page 2 of 3
