New Zealand T34 Ghia project
Page: Previous  1, 2, 3 ... , 54, 55, 56  Next
racoguy
racoguy is offline
PostPosted: Sat Aug 22, 2015 3:56 am    Post subject: Reply with quote
Since I'm fitting a tach I moved the clock over to the passenger side and left it as 6v never even bothering to see if it worked or not when I restored the gauges....why I didn't just doesn't make any sense right now but in any case I ended up with a 12v T3 clock for parts to make my tach and decided to see if the movement worked but no potatoe. bummer.
Looked on the samba and came across the clock repair guide and sure enough mine had the "blown" fuse deal going on and I thought A HA! that's it! Re soldered the link but still no joy. Closed the contact manually and re connected 12v to see it energise and wind up the mechanism but no tickety tick......closed the contacts again and sprayed the gears and moving parts with spray oil manually operating the gears back and forth, tried again and wadda ya know, success!
Quite neat to watch it work and wind up every minute or so, seems to keep accurate time as well so far.
With the 12v movement working I took the clock apart and swapped out the 6v movement converting the clock to 12v.
Not overly useful or productive but quite neat for it too work.
https://www.facebook.com/pages/West-Worx/460154187360186
bobnorman
Samba Newfoundlander
bobnorman is offline
PostPosted: Sat Aug 22, 2015 7:38 am    Post subject: Reply with quote
reay wrote:
t3kg wrote:
Anco and Trico seem to be the two companies that still make refills. Not sure if they will fit the Bosch blade holders or not.
These actually say they are not for Anco holders.
I've got some SWF rubber refills for T-3s if you still have your original blades... Would a couple of these help John?
Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
racoguy
racoguy is offline
PostPosted: Sat Aug 22, 2015 3:13 pm    Post subject: Reply with quote
Thanks for the offer Bob, I think the new SWF blades I got and painted silver are going to work just fine so I'll stick with those.
What I do need is a 12V wiper motor......
In saying that I removed both the push button dash and the wiper motor yesterday in order to bench test things to help understand what the f*&k is going on, here's what I think. The voltage dropper will not allow enough current to pass through it to satisfy the motor.
I ended up wiring in series a 6V 45W bulb (should be around 7.5amps draw) with the wiper motor and with that it runs at about the right speed, could be a little faster so a higher wattage bulb will allow more current.
I also tried a 6v 21W bulb which made it run slower confirming what I thought.
Now a 45w bulb glowing under the dash isn't all that appealing so some sort of current limiter would be needed.
racoguy
racoguy is offline
PostPosted: Sun Oct 18, 2015 3:17 pm    Post subject: Reply with quote
Stainless..........fresh off the plane.
notchboy
notchboy is offline
PostPosted: Sun Oct 18, 2015 4:46 pm    Post subject: Reply with quote
Seat knob went out early last week.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Bobnotch
Bobnotch is offline
PostPosted: Sun Oct 18, 2015 6:40 pm    Post subject: Reply with quote
Beautiful. Cool Are they from PTT?
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
TheFop
TheFop is offline
PostPosted: Mon Oct 19, 2015 12:47 am    Post subject: Reply with quote
I was getting worried you'd forgotten the project there for a while with all your other goings on Smile
Hoped to grab a chat yesterday but you left before I caught up with you.
Love the shiny new bumpers, fingers crossed they fit better than the Type 14 ones Kiwighia and I have.
Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car
racoguy
racoguy is offline
PostPosted: Mon Oct 19, 2015 1:29 am    Post subject: Reply with quote
No these are made by Harrington
TheFop
TheFop is offline
PostPosted: Mon Oct 19, 2015 2:26 am    Post subject: Reply with quote
Great choice
simppa
simppa is offline
PostPosted: Mon Oct 19, 2015 8:06 pm    Post subject: Reply with quote
I couldn't find those bumpers from their website, are those custom made to you?
tanhis
tanhis is offline
PostPosted: Wed Feb 10, 2016 3:25 am    Post subject: Reply with quote
http://www.groupharrington.com/en/part/929/vw-karmann-ghia-t34-bumpers.html
-58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton
Walter64
Walter64 is offline
PostPosted: Wed Apr 06, 2016 3:25 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
Hi John, how is the progress on your resto, have seen any posts for a while.
I have started restoring my T34, unfortunately mine was in an bad accident previously with shoddy repairs and it affected the structural integrity and door openings amongst other things.
I have a 5mm difference between one side to the other. Do you have any measuremnts for your door openings, from the front door pillar to the striker?
I don't know which side is correct because both sides of the car were hit.
VW fan & Real Estate Agent at www.argyproperty.com.au
66 RHD teak T34 karmann
Disc
Disc is offline
PostPosted: Thu Jul 07, 2016 3:07 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
Long time, no see. Any updates>?
The glory never gets old, just need new paint.
Nick
Disc
Disc is offline
PostPosted: Wed Jul 05, 2017 5:14 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
An year later... racoguy, are you OK buddy? Any news here?
Nick
camit34
camit34 is offline
PostPosted: Wed Jul 05, 2017 8:14 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
WOW! Great work! Really like the look of these T34s and this one is super nice!
In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
1965 Bug (SOLD)
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 05, 2017 8:37 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
I believe he's got it up and running, but don't know any more than that.
Tram wrote:
Tram wrote:
Clatter
Clatter is offline
PostPosted: Wed Jul 05, 2017 10:01 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
Yeah, what the hey?? Very Happy
This picture was posted to another thread a couple of days ago..
Bus Motor Build
It does not exist!
ALLWAGONS
ALLWAGONS is offline
PostPosted: Wed Jul 05, 2017 3:49 pm    Post subject: Re: New Zealand T34 Ghia project Reply with quote
Yeah! He's enjoying his type 34.
racoguy
racoguy is offline
PostPosted: Thu Jul 06, 2017 2:46 am    Post subject: Re: New Zealand T34 Ghia project Reply with quote
Indeed it runs and drives, still tuning to do on the ecu but so far runs ok on a stock standard Golf GTI ecu which is pretty encouraging.
Have a bunch of things I'm not happy with but will remove those parts and rectify those.
One of them is the windshield seals, the trim does not sit in the middle of the Simon Kelley seals but so far have not found a better solution.
Clatter
Clatter is offline
PostPosted: Thu Jul 06, 2017 7:04 am    Post subject: Reply with quote
racoguy wrote:
Do not fear friend, lots of engine related posts to come.....I have a vast plethora of ideas to carry out Laughing
Popcorn
Razz
Bus Motor Build
It does not exist!
Page 55 of 56
