chabanais Samba Member
Posted: Fri Dec 18, 2015 8:10 pm Post subject: An interesting electrical issue |
I first noticed this a few days ago.
If the parking lights/headlights are OFF the rear side lights and interior lights illuminate when I press the brake pedal (brake lights operate normally).
When I have the parking lights/headlights on things get really funky. The brake lights are stuck on and when I remove the key the motor continues to run unless I either turn the parking lights/headlights OFF or remove my foot from the brake pedal.
I can't understand how the ignition would be involved in this... trying to think where the wires would be near one another.
Any ideas? _________________ "I spud therefore I yam." |
Joined: January 01, 2007 Posts: 17889 Location: sticksville, ct.
Posted: Fri Dec 18, 2015 8:56 pm Post subject: Re: An interesting electrical issue |
if you posted what year bus, that would be awesome for us that wanted to peruse a wire diagram.
if it's an early bus, the first stop for the main feed from the battery is to the headlight switch iirc. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4115 Location: Seattle, WA
Posted: Fri Dec 18, 2015 9:14 pm Post subject: Re: An interesting electrical issue |
chabanais wrote: |
I can't understand how the ignition would be involved ... |
The ignition wire is like any other, if you misconnect it to something hot, it will be hot ...
That wire has connections at ig. switch and fuse box, powers several things up front, any of which could make ig wire hot if
miswired, and then a few more back at the engine ... _________________ '67 bug: seized by the authorities
Posted: Fri Dec 18, 2015 9:37 pm Post subject: Re: An interesting electrical issue |
71.
I can trace the wires just wondering if someone has experienced this before I assume something is accidentally touching someting else.
Really odd.
Thank you. _________________ "I spud therefore I yam." |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3627 Location: San Diego (Encinitas)
Posted: Fri Dec 18, 2015 10:19 pm Post subject: Re: An interesting electrical issue |
Any ideas? |
The turn and taillight wires run in the same harness as the ignition power, from the front to the rear of the bus. The scary scenario involves the unfused ignition wire to the coil being shorted to ground somehow, getting hot, and attaching itself to the light wires, or some such. Usually, damage like this can be seen as ripply insulation on the black coil wire.
Bad grounds on the rear lamp fixtures could explain the weird side marker light actions (unless someone rewired them to do this). but it wouldn't explain the engine running thing.
I'd be tempted to disconnect both ends of that front-to-rear harness, do some inspection with the ohmmeter, and see if any wire-to-wire shorts, exist. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4852 Location: Kaneohe
Posted: Sat Dec 19, 2015 1:11 pm Post subject: Re: An interesting electrical issue |
Don't know the wiring for your '71, but in my '69 camper a disintegrating rheostat in the light switch was a breeding place for gremlins. The engine would start and run only when the parking lights were on.
Aloha
tp |
Posted: Sat Dec 19, 2015 4:07 pm Post subject: Re: An interesting electrical issue |
I think it is up at the front where the wiring harness from the back goes into a plastic coupler into the front.
The ignition wire runs through there so I'm thinking that might have something to do with it. That plastic is thin and old and might have worn out in places.
The ignition wire runs there but also the headlight switch power cable. These must fail in other Buses, too.
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Sat Dec 19, 2015 5:26 pm Post subject: Re: An interesting electrical issue |
I would suspect the headlight switch. looking at the diagram, remove fuse 9 (16a) and see if anything changes. that is the feed to the headlight switch _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Dec 19, 2015 7:14 pm Post subject: Re: An interesting electrical issue |
I read that thread but nobody could explain how the headlights we affected.
I will try pulling the fuse, too.
I still suspect that coupler, however.
The only thing I've done is to add three LED lights under the dash. But I unplugged them and the same thing happened.
The rear side marker lights have never come on when I hit the brake pedal. _________________ "I spud therefore I yam." |
Posted: Sat Dec 19, 2015 7:19 pm Post subject: Re: An interesting electrical issue |
the lights coming on is a pretty good indicator of something back feeding the system and/or looking for a ground _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Dec 20, 2015 5:12 pm Post subject: Re: An interesting electrical issue |
It was suggested to me that perhaps there is a grounding issue in the tail lights.
I removed the fuse up front... nothing. Removed the hot cable to the light switch... nothing.
Tomorrow I'm going to do thru the tail lights and see.
I just can't see how it affects the motor. _________________ "I spud therefore I yam." |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53052 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Dec 20, 2015 5:29 pm Post subject: Re: An interesting electrical issue |
chabanais wrote: |
Any ideas? |
OK, here's my stab at it.......
One of the combination tail/brake bulbs is shorted internally (filaments somehow combined) and is backfeeding parking light power through the brake warning system and/or brake light power to the parking lights. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42820 Location: at the beach
Posted: Sun Dec 20, 2015 5:35 pm Post subject: Re: An interesting electrical issue |
remove both brake light bulbs temporarily and try it again. If the issue still happens then it is something upstream electrically ahead of the bulbs. If the issue goes away, the brake light bulbs simply have a bad ground, or are as BusDaddy described them.
A good way to handle this would be to replace the bulbs with new ones when they are out. I've actually had both situations happen before troubleshooting the problem you describe. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Sun Dec 20, 2015 6:48 pm Post subject: Re: An interesting electrical issue |
I tracked it to the passenger tail light. The prongs were touching one another which was causing the issue.
So freaking weird!
I can't believe how easily that one was solved considering the issues it was causing.
Thank you! _________________ "I spud therefore I yam." |
SGKent  Samba Member
Posted: Sun Dec 20, 2015 10:15 pm Post subject: Re: An interesting electrical issue |
awesome. _________________ George Carlin:
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1603 Location: Indianapolis, IN
Posted: Mon Dec 21, 2015 7:03 am Post subject: Re: An interesting electrical issue |
chabanais wrote: |
So freaking weird!
Thank you! |
I trouble shot a similar issue. I had replaced the tail lights and side marker lights. Had dimming-issues and reverse lights would go off on one side when I pressed the brake. I was initially very careful crimping new (proper open barrel)ends to all the wires di-electric grease on everything and clean dremmeled ground posts.
I thought it was a back up light switch or wiring issue or something up front but turned out once I removed and reinstalled all the connections something at the tail light buckets was flowing the wrong way or causing current to run amok on me. Now brighter than ever and no flashing. Moral of the story, check and recheck those ground spots all over. _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Mon Dec 21, 2015 10:12 pm Post subject: Re: An interesting electrical issue |
