Heated Front Windshield
NASkeet
NASkeet is online now
PostPosted: Tue Jun 02, 2015 7:23 am    Post subject: Electrically-heated front windshield Reply with quote
Sometime prior to September 2002, I learned from Bob Wallace (a fellow member of the VW Type 2 Owners' Club), that Beetles (UK) Ltd (later incorporated Danbury Motorcaravans), who imported Brazilian-built, post-1996 “bay-window” VW 1600 Type 2c vans, were marketing electrically-heated front windscreens, at what was described as an “introductory price”.
These electrically-heated front windscreens, were essential for the 1997~2005“bay-window” VW 1600 Type 2c vans, which had the VW Type 1 style air-cooled engine with Bosch Digifant fuel injection, but no exhaust heat exchangers or under-floor ducting, to provide front windscreen demisting & defrosting.
At that time, I contacted Jason Jones, technical director of Beetles (UK) Ltd, enquiring further about the technical specifications of these electrically-heated front windscreens, but received no response! Even at that time, more than 12½ years ago, the quoted price exceeded £200, so I didn’t pursue the enquiry any further.
I have since learned that electrically-heated front windscreens for the “bay-window” VW Type 2, have separate left-hand & right-hand heated zones, each rated at 19A (i.e. 228W @ 12V), which if operated simultaneously, would draw a total of 38A (i.e. 456W @12V). Noting that the 1968~79 VW 1600 Type 2’s dynamos & alternators are rated at a maximum of 38A & 50A respectively and the 1972~79 VW 17/18/2000 Type 2’s two available alternators are rated at a maximum of 55A & 70A respectively, simultaneous operation would not be practical.
In principle, one could use two accessory relays and two separate switches, such as those with a green-lensed warning light, which are employed for the 1968~79 VW Type 2’s electrically-heated rear window, but with these, there would be no fool-proof way of ensuring, that the separate left-hand & right-hand heated zones were not switched-on simultaneously. Hence, it would be appropriate, to operate these electrically-heated front windscreens, using a single-pole, double-throw switch and two accessory relays, so that the separate left-hand & right-hand heated zones are switched on alternately.
In general, there are two types of double-throw switch, which either switch-on two circuits alternately or switch-on one circuit and then both circuits. Most double-throw switches I have encountered are of the latter type, requiring the use of a change-over relay, to mimic the switching characteristics of the former type, which would be the preferred option for the electrically-heated front windscreens.
Former Type:
Switch Position | Circuit No. 1 | Circuit No. 2
0 | OFF | OFF
1 | ON | OFF
2 | OFF | ON
Latter Type:
0 | OFF | OFF
1 | ON | OFF
2 | ON | ON
Assuming one preferred to use a 1968~79 VW Type 2 pattern dashboard switch, with integral warning light, then the double-throw, pull-knob fog-lamp switch (VW part No. 111 959 631), would be most appropriate. These normally have an orange warning-light lens, with fog-lamp emblem, but I believe it would be possible to substitute a green warning-light lens, with heated-window emblem, originating from a 1968~79 VW Type 2’s heated rear window switch.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1165189
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1165190
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1165191
http://s300.photobucket.com/user/aquatopaz/media/nnkh131.jpg.html
http://s300.photobucket.com/user/aquatopaz/media/nnkh130.jpg.html
Although I have yet to confirm it, I suspect that the double-throw fog-lamp switch (VW part No. 111 959 631) is of the latter type, that would need to be used in conjunction with a changeover relay.
If a double-throw fog-lamp switch (VW part No. 111 959 631) is not readily available, one could alternatively use either a 1968~72 VW Type 2 front-windscreen wipers & washer rotary switch (VW part No. 141 955 517) or 1968~79 VW Type 2 two-speed, ventilation booster fan rotary switch (VW Part No. 211 959 511 A), but both lack an integral warning light.
For my own vehicle, I have mounted in a custom-made switch panel (substituted for the dashboard’s central ashtray), six Citroën Visa, 24 mm (i.e. 15/16 inch) square-section push-button switches; one of which is a double-throw switch with windscreen-demist emblem.
http://en.wikipedia.org/wiki/Citro%C3%ABn_Visa
http://www.bing.com/images/search?q=Citro%C3%ABn+V...ajaxhist=0
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
NASkeet
PostPosted: Fri Jun 05, 2015 6:53 am    Post subject: Electrically-heated front windshield Reply with quote
I have had some further ideas about the electrical switching circuit, for the following type of double-throw switch:
0 | OFF | OFF
1 | ON | OFF
2 | ON | ON
Provided one had a change-over relay of sufficiently high current rating (i.e. at least 25A, but preferably 30A, 35A or 40A), there is a circuit arrangement which would require just one accessory relay (terminals labelled 30, 85, 86 & 87) and one change-over relay (terminals labelled 30, 85, 86, 87 & 87A), but the windscreen's load current, would pass through both relays and involve two extra in-line connections.
Regards.
Nigel A. Skeet
vwwestyman
vwwestyman is offline
PostPosted: Wed Jan 20, 2016 12:28 pm    Post subject: Re: Heated Front Windshield Reply with quote
It seems that this just died out.
Too bad, I need a windshield and will probably just have to get a used one.
Dave Cook
1973 Wild Westerner
My Thing
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed Jan 20, 2016 2:34 pm    Post subject: Re: Electrically-heated front windshield Reply with quote
NASkeet wrote:
...I have since learned that electrically-heated front windscreens for the “bay-window” VW Type 2, have separate left-hand & right-hand heated zones, each rated at 19A (i.e. 228W @ 12V), which if operated simultaneously, would draw a total of 38A (i.e. 456W @12V).
Noting that the 1968~79 VW 1600 Type 2’s dynamos & alternators are rated at a maximum of 38A & 50A respectively and the 1972~79 VW 17/18/2000 Type 2’s two available alternators are rated at a maximum of 55A & 70A respectively, simultaneous operation would not be practical...
In practical terms I believe a simple 555-chip based timer with two on board relays would be a reliable and (relatively) simple alternative to switching zones manually. I see that sort of operation on aircraft ice and rain protection pretty regularly
Robert in Memphis
Engine rebuild thread
vwwestyman
PostPosted: Wed Jan 20, 2016 3:30 pm    Post subject: Re: Heated Front Windshield Reply with quote
Skills posted a link to this company in my rear defroster thread.
Perhaps their low windshield kit might be good, if not quite as good as a fully heated windshield. They say it prevents wiper blades from freezing up.
http://www.frostfighter.com/clear-view-bus-front-windshield-defrosters.htm
Dave Cook
1973 Wild Westerner
My Thing
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jan 20, 2016 4:32 pm    Post subject: Re: Heated Front Windshield Reply with quote
https://www.vwheritage.com/shop/bay-bus/211845101H...tartRow=51
raygreenwood
raygreenwood is offline
PostPosted: Wed Jan 20, 2016 4:35 pm    Post subject: Re: Heated Front Windshield Reply with quote
WOW! considering the significance of what that part is...that price is actually pretty fair!...sadly they dont ship it. You have to pick it up. Ray
tristessa
tristessa is offline
PostPosted: Wed Jan 20, 2016 10:10 pm    Post subject: Re: Heated Front Windshield Reply with quote
BD carries it here in the USA, but I can't tell if it's OE or reproduction: http://www.busdepot.com/j13431
.. still, compared to a non-functional window, even repop is an improvement.
vwwestyman
PostPosted: Thu Jan 21, 2016 6:16 am    Post subject: Re: Heated Front Windshield Reply with quote
You got me all excited for a minute there. But that is a rear window! We're discussing the front window in this thread.
Dave Cook
1973 Wild Westerner
My Thing
tristessa
PostPosted: Thu Jan 21, 2016 6:08 pm    Post subject: Re: Heated Front Windshield Reply with quote
My bad -- I confused the vwheritage.com link posted in this thread with the one in the rear window defroster thread. Had 'em both open at the same time.
Aside from the issue of potential breakage in shipping, the other problem I could see with the heated windshields is they may not have the appropriate markings to make them DOT legal in the US...
raygreenwood
PostPosted: Thu Jan 21, 2016 8:51 pm    Post subject: Re: Heated Front Windshield Reply with quote
The markings mean little. The actual detail of the specification does. There are no issues with DOT, TUV and MOT glass interchange....and likely no one policing it if there was. Its a new build issue more than a classic car issue. Ray
SGKent is offline
PostPosted: Fri Jan 22, 2016 8:45 am    Post subject: Re: Heated Front Windshield Reply with quote
The cars are 40 - 50 years old almost. You get new parts where you can find them, or make due with what you have used. A working heater system combined with an open vent window will help keep the windshield dry. On a wet cold day the other windows will fog up even with a working rear window defogger. The only way to avoid that is add air conditioning and freeze your butt off as you dry the car with the AC. Modern cars usually use both AC and Heat combined to dry the air then reheat it.
NASkeet
PostPosted: Fri Jan 22, 2016 9:17 am    Post subject: Re: Heated Front Windshield Reply with quote
Note the following topic thread and link therein, pertaining to Ricky Evans Motorsport, who stocks electrically-heated front windscreens for quite a few air-cooled & water-cooled VWs:
Forum Index > Bay Window Bus > windshield fogging bad. Ideas? Questions.
http://www.thesamba.com/vw/forum/viewtopic.php?t=210187
http://www.heatedwindscreen.com/acatalog/vw-t2-combi-van-clear-heated-windscreen.html
« This heated windscreen for the VW T2 is a dual circuit laminated screen. It is fully E-Marked for Europe, 43R and AS-Marked for America and Canada and is legal on the road and track in all parts of the world. »
Air conditioning was never an option for British specification, 1968~79 VW 1600 Type 2s or 1972~79 VW 17/18/2000 Type 2s! Sad The Eberspacher BA6 pertol-fired auxiliary heater wasn't an option either. Sad Neither did they having opening quarter-light cab-door windows.
Regards.
Nigel A. Skeet
tristessa
PostPosted: Fri Jan 22, 2016 11:02 am    Post subject: Re: Heated Front Windshield Reply with quote
I was just raising what I could see being a potential issue, never looked into the heated windshields myself. I don't care one way or another, I've got great heat & windshield defrost, and I've been daily-driving these things long enough in the COOL WET areas of PNW -- and prior to that in the COOL WET areas of NorCal -- to know how to keep the windshield and the rest of the windows de-fogged this time of year. Rolling Eyes
NASkeet
PostPosted: Sat Jan 23, 2016 9:41 am    Post subject: Re: Heated Front Windshield Reply with quote
My 1973 VW 1600 Type 2 Westfalia Continental's heating & demisting system, was always rather pathetic even with genuine VW exhaust heat exchangers, in the temperate climate of Great Britain. Perhaps it might be better with VW Type 4 style engine and associated exhaust heat exchangers!?! Confused Whatever the case, I shall probably need to upgrade it further, with additional duct insulation, booster fans, etc.
Regards.
Nigel A. Skeet
tootype2crazy
tootype2crazy is offline
PostPosted: Sat Jan 23, 2016 12:48 pm    Post subject: Re: Heated Front Windshield Reply with quote
BA6 for the win! A better alternative to this would be to get a gas or diesel heater and install it under the belly into the existing heat pipe. Believe me, your window will steam in the winter time, side windows will clear too.
air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
tristessa
PostPosted: Sat Jan 23, 2016 2:53 pm    Post subject: Re: Heated Front Windshield Reply with quote
The Type IV heat and defrost in my '75 Westfalia was decent for the area and climate here, but it doesn't get as cold in Portland, Oregon as can in the UK and northern Europe.
That said, after a catastrophic lifter failure five years ago I re-powered my Bus with a 1997 Jetta 2.0L engine, adding a front heater matrix connected to the dashtop defroster vents and footwell vents, and a rear heater matrix warming the main cabin. I'll be adding an Eberspacher B5WSC Hydronic heater as a preheat/parking heat source, but the controller board is on it's way to Poland for repair and probably won't be back before springtime.
Coolant heat makes it much warmer inside. Laughing
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Jan 23, 2016 4:05 pm    Post subject: Re: Heated Front Windshield Reply with quote
sure does Laughing
Jesus Christ...get cold do ya? Laughing
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
tristessa
PostPosted: Sat Jan 23, 2016 4:24 pm    Post subject: Re: Heated Front Windshield Reply with quote
It's to keep the wife happy when we're camping in the "cold", which for her is anything below about 70 degrees. Rolling Eyes
NASkeet
PostPosted: Mon Jan 25, 2016 9:21 am    Post subject: Re: Heated Front Windshield Reply with quote
During the 1987/88 & 1990/91 winters in southern England (Scotland where I lived during mid-1956 to mid-1965, is much colder!), when I had to use the 1973 VW 1600 Type 2, because my 1974 Triumph Toledo 1300, four-door saloon car (water-cooled engine with a nice cabin-interior heater) was off the road, I needed to wear two pairs of woolen gloves, so that my hands didn't become numb with cold, as a consequence of gripping the steering wheel. My feet and calves also used to get quite cold, but I managed to avoid frostbite.
Cross-section of pattern-part (left) & genuine-VW (right) exhaust heat exchangers, for VW Type 1 style air-cooled engines, as used in the 1968~79 VW 1600 Type 2
Regards.
Nigel A. Skeet
Page 3 of 9
