Tough shifting 77 Bus [Fixed]
SurfaceRust
SurfaceRust is offline
PostPosted: Thu Feb 04, 2016 4:24 pm    Post subject: Tough shifting 77 Bus [Fixed] Reply with quote
I bought a 77 bus recently and after having it for about a week the shifting has become extremely tough. When it is off and cold it is much much easier to shift. I am able to get it into gear when running but it have to use way too much force. I don't think it's the clutch because if i have it in gear i can depress the clutch pedal and rev the engine. Do you guys have any thoughts?
kkjellquist
kkjellquist is offline
PostPosted: Thu Feb 04, 2016 4:34 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
If you have a Bentley manual you can read the procedure to make sure the shifter is properly adjusted. After that you can start looking at replacing the bushings if needed. Make sure your transmission fluid is properly topped off and you might want to change it if you don't know the history.
My bus shifts well, but not by modern standards. Always remember the vehicle is almost 40 years old. It's never going to shift like 2016 vehicle...or even a 2006 vehicle!
1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/
SGKent Premium Member
SGKent is offline
PostPosted: Thu Feb 04, 2016 4:51 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
check the gear fluid level. Most likely it is the pilot bearing. Also check the bolts holding the engine and trans together.
George Carlin:
Skills@EuroCarsPlus:
Wildthings
Wildthings is offline
PostPosted: Thu Feb 04, 2016 5:57 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
2x on the pilot bearing, they are way undersized and are known for failing frequently. Once you have the engine and tranny split you are going to want to check that the slinger in the bellhousing of the tranny has not come loose.
Amskeptic
Amskeptic is offline
PostPosted: Thu Feb 04, 2016 6:09 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
Do NOT drive it until you have this one fixed.
It is very much the clutch whether or not you can rev it freely in a gear with the pedal depressed, the little brass synchronizers (about the size of a plastic coffee cup lid) can get killed if you start getting tough on the gear shifter.
What is the free play at the top of the pedal travel (in inches)?
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
Tcash
Tcash is offline
PostPosted: Thu Feb 04, 2016 6:14 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
Shifter Parts ID
First thing to inspect is the shift coupler and front shift rod bushing.
Good luck
Tcash
Amskeptic
PostPosted: Thu Feb 04, 2016 6:21 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
Tcash wrote:
Shifter Parts ID
Good luck
Tcash
I am assuming he does not get a release as he states:
"When it is off and cold it is much much easier to shift."
Colin
SurfaceRust
PostPosted: Thu Feb 04, 2016 9:49 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
The clutch can almost fully depress without catching. It only catches with about 1-2 inches left. Its not free play in the clutch though.. its still hard to press down all the way through.
Also when running i can shift into 3rd and 4th fine, its just 1st and 2nd which are tough. If its in reverse I can get it into first easier. if its in neutral i cant get 1st at all. if im coming from 1st i can get 2nd, but if im coming from 3rd i cant get 2nd
Ill change out the gear oil
I was thinking it could be some of the bushings in the linkage
Ill look into the pilot bearing
SurfaceRust
PostPosted: Sun Feb 07, 2016 12:17 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
Colin
WINNER...
It was in fact the clutch. I just had to tighten the wingnut on the cable and now its good to go. Not before buying a new bushing kit for the linkage though.
Wildthings
PostPosted: Sun Feb 07, 2016 12:39 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
SurfaceRust wrote:
WINNER...
If your clutch adjustment change all at once the cable is probably beginning to fray or the pin in the front is wearing through. I would suggest that if you don't want to get stuck out on the road within the next few hundred miles you change out the cable and pin while verifying that the front lever arm isn't hogged out to badly. You might buy a complete kit that included the bowden tube and change that out as well.
Tcash
Tcash is offline
PostPosted: Sun Feb 07, 2016 7:27 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
^^^We loosen the wingnut as the clutch disc wear out. As posted if you had to tighten it, you will want to check the cable and clutch cable lever.
Wildthings
PostPosted: Sun Feb 07, 2016 9:16 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
I carry very few parts with me when I travel as I try to keep things in good enough shape that they will not let me down without giving lots of notice. I do carry both a spare throttle cable and a spare clutch cable. They are both cheap, light in weight and don't take up much room. They just get stashed in with the spare tire.
SurfaceRust
PostPosted: Thu Feb 11, 2016 9:57 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
Well I installed my shift linkage bushing kit today. it shifts even more smooth now, but just as a precaution I have ordered 2 Clutch cable kits and an accel cable. i also ordered the clutch pin thing, because it was cheap. Thanks for the advice. Would rather have the parts for if/when it does break.
udidwht
udidwht is offline
PostPosted: Thu Feb 11, 2016 10:32 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
Be certain the clutch lever (pedal end) is oriented correctly. Otherwise it will break the cable in short order near the pedal end. Also when tightening the wing nut end use vice grips to hold the cable in place.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
NoBudgetVWGarage
NoBudgetVWGarage is offline
PostPosted: Mon May 02, 2016 12:39 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
In the middle of changing my bushings as well. My shifting is sloppy as all hell!
I just pulled my shift rod but all my bushing look fine. Any ideas? Working on a 72.
1969 Transporter - 1600 s/p
1966 Ghia - 1776 w/turbo
udidwht
udidwht is offline
PostPosted: Mon May 02, 2016 2:44 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
While you have the bushing tube out clean it very well inside. Once certain the bushings are good give the a shot of Teflon spray lubricant. Spray the interior of the tube as well. See if you can source the boots that also go over each end of the tube when putting everything back together.
Look for slop in the shifter at the stick end or the trans coupler end.
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
ivwshane
ivwshane is offline
PostPosted: Mon May 02, 2016 4:10 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
Can you elaborate on that? The only bus I have ever driven is my own so I have no idea what "normal" is on a bus.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
udidwht
udidwht is offline
PostPosted: Mon May 02, 2016 4:49 pm    Post subject: Re: Tough shifting 77 Bus Reply with quote
I believe he is referring to the overall feel of the stick when shifting. It is notably different in terms of comparison to modern manual shift vehicle. The shift stroke is longer and not as stiff (side play) on a bus.
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon May 02, 2016 8:51 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
If you can't accurately shift through the four forward gears without the base of your hand leaving your knee, you can make some improvements in your shift mechanism.
Robbie
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
anthonyhernandez99
anthonyhernandez99 is offline
PostPosted: Tue Aug 30, 2016 5:44 pm    Post subject: Re: Tough shifting 77 Bus [Fixed] Reply with quote
I'm pretty sure this thread describes my issue pretty well.
I'm not able to get at the wingnut at the moment, but I had my lady press on the clutch and release so I can get an idea of how much movement I'm getting.
Does this look normal? Or should I get after that wingnut?
https://youtu.be/Jy3jJDV_kUY
Thanks in advance!
