Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Fri Jan 08, 2016 8:02 pm Post subject: |
vlad01 wrote: |
I seen these little beauties on fb the other week.
asked the guy if he was planing to make them for others. currently testing them for a year to see how they wear. |
So I have a piece of 3" 6061 Aluminum Round Bar Lathe Rod Stock on order with the goal of doing something like the pictures you posted. But in those pictures it looks more like bronze.
Wadayathink?
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Brent Samba Member
Joined: April 28, 2010 Posts: 1617 Location: San Tan Valley, AZ
Posted: Fri Jan 08, 2016 11:20 pm Post subject: Re: Beam disassembly / reassembly |
I think oil impregnated bronze for bearing use would be the better material choice. _________________ 69 Fastback Build
Berg5 Build |
Posted: Fri Jan 08, 2016 11:50 pm Post subject: Re: Beam disassembly / reassembly |
Actually I'm thinking a common 35x42x20 HK bearing inside an aluminum (or maybe bronze) shell to bring the OD out to 44mm.
I know the aluminum will only be 1mm thick, but I think if we start by boring the 42mm hole, then pressing the bearing into that before turning down the outside it might be doable.
PS: 1mm seems about tin-can thickness.
69sback Samba Member
Joined: March 06, 2010 Posts: 216 Location: Somewhere
Posted: Tue Feb 09, 2016 11:46 am Post subject: Re: Beam disassembly / reassembly |
Thanks Max for keeping this thread alive. To recap my story, I have worn out upper inner bushings which are ruining my upper control arms. I said in feb '15, I would do the job to replace the inner bushings with the ISPwest bushings, but I never got around to it. I have new arms and everything and the ISP white bushing kit, just didn't have the time. But now I do and I'd like to knock this out before I ruin the beam and before fishing season starts...
So you found some outer upper needle bearings...that's awesome. But why not use the ISP west "bushing"? I do like the idea of using the needle bearings tho...can I buy some off you? ))))
So.... the inner bushings you replaced with the ISP kit....did they hold up? Why are you replacing them with the oil-bronze bushings if they held up for 4 years?
Thanks
David |
Posted: Tue Feb 09, 2016 11:50 am Post subject: Re: Beam disassembly / reassembly |
also...Max, do you mind posting a photo of your makeshift tool you used to push out the outer needle bearings? |
Posted: Tue Feb 09, 2016 7:20 pm Post subject: Re: Beam disassembly / reassembly |
Thanks for the photos Max...is your car lowered? maybe that's putting undue stress on the inner bushings? |
Posted: Thu Feb 11, 2016 3:08 pm Post subject: Re: Beam disassembly / reassembly |
nice looking square...
are you not able to use your the steel rod with a hat to push out ISP west bushings? I'm really curious to see what they look like. I was about to put them in this weekend, but I might wait to see how bad yours look after 4 years of daily driving... |
Posted: Tue Feb 16, 2016 2:05 pm Post subject: Re: Beam disassembly / reassembly |
I did the job on my square this past Saturday...
The needle bearings came out easily which I re-used. The inner bakelite and metal bushings did not come out easily. One side I used a sharpened chisel, the other side I used a hacksaw blade. The chisel gouged the inside of the beam, which I later then sanded down. The hacksaw blade was the best option. On either side the bakelite came out in pieces. I don't think I ever got the metal bushings out, they fell inside the beam never to be seen again.
After removing bakelite pieces, I tried to clean as well as I could, but I'm sure there is still crap in there which will ruin my needle bearings.
As well as sanding down the regions I gouged with the metal chisel, I also had to sand down the region around the grease nipples.
Once the sanding was complete, pushing in the ISP west plastic bushing was easy. Re-installing the needle bearing was also super easy.
I was very liberal with the grease and immediately greased both sides.
After adjusting the tension bolt to about 10-15lbs the arms moved up and down with no lateral play! So happy. The car handles so much better.
Given the fact I could not clean it out as well as I should have, it probably won't last forever but I'm happy with it for now...
here you can see the three stops for the inner bushing...
on the right side you can see the material buildup from the grease nipple
Posted: Tue Feb 16, 2016 9:44 pm Post subject: Re: Beam disassembly / reassembly |
69sback wrote: |
Once the sanding was complete, pushing in the ISP west plastic bushing was easy. Re-installing the needle bearing was also super easy. |
I think this can be a problem. When I removed the ISP plastic bushings they literally just pushed out. The IDs were still a snug fit on the trailing link but I think the bushings themselves were moving in the beam. That is where my trailing link movement was coming from.
My OG bushings measured just about 43mm OD. The ISPs measured 42.35mm. I don't know what they were when they went in, but that is a pretty big difference when we're talking about something that needs to be an interference fit.
My new bronze bushings measured 42.85 OD and required some force to drive then into the beam. And it was then necessary to ream the IDs to restore a good fit with the trailing links.
Length was also an issue for me. The ISP bushings seemed noticeably shorter than the original bushings.
In a few days I'll have a bunch of pictures of my installation you might find interesting.
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Wed Feb 17, 2016 8:43 pm Post subject: Re: Beam disassembly / reassembly |
While I'd agree that the width of the ISP bushing isn't quite enough, the diameter could have been from whatever beam they used to get the ID...and that's where the problem may have started.
The assumption is that all of the beams have the same ID for a given production range but I'd be willing to believe that simply isn't true.
I had four beams, all early style with the stop welded to the beam, and had three different sets of dimensions...one of which is still without bushings now due to this lack of consistency. It also doesn't have internal stops for the inner bushings - which I found to be odd. I removed it from the car - original to that car - but it's an odd one. I'm either going to go back to OE parts or will just replace it with a different beam given its limitations.
So, if ISP used an odd beam or two for the ID, that might explain why the bushings didn't fit quite right...not fact, but a guess as to why it might be the case.
The quality control on these beams wasn't as good as people think - same reason the OE bakelite bushings had to be reamed after installation. |
Posted: Wed Feb 17, 2016 8:57 pm Post subject: Re: Beam disassembly / reassembly |
I'm not knocking what you did at all...just throwing out a couple of factors that likely lead up to the failure of the isp parts. |
