Front door vent
djkeev
djkeev is offline
PostPosted: Thu Feb 25, 2016 7:29 pm    Post subject: Front door vent Reply with quote
Maybe you guys know this, but it was a new discovery for me today.
I had always assumed the air that came out of the front door vents came from the channel through the doors.
That's not the case at all!
Air for those vents comes from slots in the front of each door, a ram air ventilation. The front doors are pressurized as you drive. I imagine this helps dry them out after rain storms, air is forced out the drain vents in the door bottom..... Or into the Van if you open the vent.
This photo shows light from a flashlight placed in the rear of the door illuminating the air intake slots at the front of the door.
Anyway..........
Life's little moments of excitement and discovery.......
Dave
Ghia
Vanagon
Beetle
DwarfVader
DwarfVader is offline
PostPosted: Thu Feb 25, 2016 8:05 pm    Post subject: Re: Front door vent Reply with quote
Learn something new every day and your life will be full...
Which is partly why The Samba is one of my favorite places... because I learn something new every day here, usually two or three things.
- oderint dum metuant -
I'll find my van someday, or it will find me.
kamzcab86
kamzcab86 is offline
PostPosted: Thu Feb 25, 2016 9:59 pm    Post subject: Re: Front door vent Reply with quote
GoWesty's more thorough explanation:
So far we have only discussed how air ENTERS the vehicle. Of course, no air can come IN unless air goes OUT. This is called “flow-through ventilation,” which all vehicles have to some degree. Prior to 1988, if all windows were closed, the only way air could get out was through little exit vents located on the rear lower corner of the front door interior panels. These are the plastic vent assemblies with the little blue slide lever.
These vents allowed air to exit the interior. Sliding the lever toward the front of the vehicle opens the vent, rearward closes it. On the leading edge of the doors, in the door jam, there are three oval holes that open into this hollow space of the door itself. As a Vanagon plows through the air, air flows around the vehicle creating low-pressure zones near the front door jam areas. VW engineers realized this and used this low pressure to suck air out of the interior of the vehicle. Air flows from the inside of the vehicle through the little vent at the rear end of the front doors, through the hollow door itself, into the door jam area, and out of the body gap between the front door and front quarter panel. Genius, you say. But what about the rear passengers, you say? And why, in 1988, did VW put a rubber seal at this body gap, thus blocking all airflow through it?
The flow through ventilation scheme completely changed and improved in 1988. This change coincided with the introduction of the switch from chrome (or black) steel bumpers to the fiberglass "big bumpers" and the accompanying front spoiler. In 1988 the rear-most side windows have an added vent along the rear edge. It was necessary to shorten the glass in order to make room for this vent as the opening in the body stayed the same. These vents are air EXIT vents.
Interestingly, the little grills on the front door panels remained, but if you remove them you will see the passageway behind them is sealed, and there is no blue slide lever. The seal at the door gap area was put there probably for reduced noise. I installed these seals on my 1987 Vanagon, and added the rear vents too. It actually lowered the wind noise a little, and the rear vents improved air flow inside the vehicle, especially for the rear passengers. And now I have the best of both worlds: improved flow-through ventilation and cool air from the dash vents! You can say you knew me when I was nobody…
http://www.gowesty.com/tech-article-details.php?id=83
Wink
2016 Golf GTI S
djkeev
djkeev is offline
PostPosted: Fri Feb 26, 2016 4:22 am    Post subject: Re: Front door vent Reply with quote
So...... It's an exit vent for an air exchange feature!
So cabin air flows thourgh the doors in a direction that one would not ever think...... Interesting!
My day is complete! I already learned something new and it's only 6:20 am!!! I can go back to bed now........ Laughing
Thanks Kam!
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Fri Feb 26, 2016 4:31 am    Post subject: Re: Front door vent Reply with quote
Ha!
Typical guy thing..... "If all else fails...... Read the directions!" Embarassed
Lower right corner........
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Tue Mar 01, 2016 11:50 pm    Post subject: Re: Front door vent Reply with quote
Kam,
Adding to you information about VW moving the vent to the rear and closing the vent in the front door....... I stumbled upon this photo of the seals installed when they did this.
Top outer door edge, inner front door edge seal and air channel seals......
Dave
Ghia
Vanagon
Beetle
avernon82
avernon82 is offline
PostPosted: Mon Mar 14, 2016 10:27 am    Post subject: Re: Front door vent Reply with quote
I added the rear window vents, but would really like to get the inner door seals. I'm guessing you need to remove the door to add them? any leads on where to get a pair?
slightly off topic, any way to remove the doors without cutting the cabling?
macjack
macjack is offline
PostPosted: Mon Mar 14, 2016 10:49 am    Post subject: Re: Front door vent Reply with quote
djkeev wrote:
Ha!
Dave
Doesn't this manual mistakenly identify the outside air vent as "B" when it should be "D" under "outside air ventilation", third column?
-macjack
87 TDI Syncro Westy
81 Westy (sold)
80 Rabbit Wolfsburg (rolled)
Bike as primary transportation
dobryan Premium Member
dobryan is offline
PostPosted: Mon Mar 14, 2016 11:03 am    Post subject: Re: Front door vent Reply with quote
Lever D is for the outlets in the rear area above the sliding door, not the dash, AFAIK, at least it is on my '87. Very Happy
Dave O
The Western Syncro build
macjack
macjack is offline
PostPosted: Mon Mar 14, 2016 11:45 am    Post subject: Re: Front door vent Reply with quote
wow. I just had one of "life's little moments of excitement and discovery"! For me it is 12:44 pm, so not quite the early bird as djkeev. Very Happy
87 TDI Syncro Westy
81 Westy (sold)
djkeev
djkeev is offline
PostPosted: Mon Mar 14, 2016 11:50 am    Post subject: Re: Front door vent Reply with quote
Except on my Van....... After some air box reworking......
http://www.thesamba.com/vw/forum/viewtopic.php?t=605822&highlight=
Lever D now controls whether I recirculate cabin air or draw ouside air..... Smile
As a trade off..... I Haven't any rear ram air ventilation..... But I never ride back there and my dog (who does) is happy with the cold AC falling on him.
I've left it as an option to reenergize the flap lever with a simple old choke type cable but I haven't seen the need to do so. The lever for the rear air flap is simply zip tied in the closed position.
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Mon Mar 14, 2016 11:54 am    Post subject: Re: Front door vent Reply with quote
I know the upper door edge seals are available from GoWesty.
Don't cut wires that feed the door, remove the door panel and disconnect them and pull them out of the door.
Most often no good comes from cutting wires.......
Dave
Ghia
Vanagon
Beetle
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Mon Mar 14, 2016 1:06 pm    Post subject: Re: Front door vent Reply with quote
Unfortunately the only way to get those inner door/body seals (the middle pair w/metal shown in Dave's photo above) is to get some from a wrecked van. Which is too bad, as they reduce airflow noise significantly!
And yes you need to remove the doors to get at them. (they actually mount to the body, not the door)
Would be really nice if VW Classic were to make these available!
Currently:
avernon82
PostPosted: Thu Apr 14, 2016 7:37 pm    Post subject: Re: Front door vent Reply with quote
Ok, got the seals from someone on thesamba classified. Not cheap, i think I paid $60.
Now how to mount them up? I've looked through the Bentley and didn't find anything
Do I have to drill holes?
[email protected]
ahmed.aboudan@gmail.com is offline
PostPosted: Fri Apr 15, 2016 7:02 am    Post subject: Re: Front door vent Reply with quote
Me too, any pictures of them mounted? Thanks in advance.
spitsnrovers
spitsnrovers is offline
PostPosted: Fri Apr 15, 2016 8:31 am    Post subject: Re: Front door vent Reply with quote
On my '88 Westfalia which had those seals originally - when I replaced them after a paint job, there were holes in the A pillar to put the screws into.
Therefore, I assume if your van did not originally have these seals, you will have to drill holes. Unless of course VW had the foresight to predrill them for you Razz
'88 VW Westfalia
'75 Triumph Spitfire 1500
narendra.vw
narendra.vw is offline
As said above, is not in my case. The door vents has metal duct in line with the door(door inside) & connects to the pillar. Through the Pillar air goes up & enters the top inside side channel which have few vents on each side.
The air comes from the Dash blower. The air temp is as selected (hot or room temp).
This is done to circulate air through out the van.
Tom Powell
Tom Powell is offline
PostPosted: Fri Apr 15, 2016 11:55 am    Post subject: Re: Front door vent Reply with quote
Some questions:
After reading this I will now assume that I can get the maximum flow of fresh air to my face in my '87 Vanagon by opening both the Dashboard vents and the door panel vents. If I open lever #3 to get fresh air to my feet will I lose some volume of fresh air to my face? If I open lever#4 will I get air for the rear, but lose a volume of air to the front? Or, will I get the maximum possible volume of fresh with the dashboard vents, the door panel vents, and levers #3 and #4 open? I assume that the answer to these will depend on the design, plumbing, and volume of the air distribution box.
Aloha
tp
What2do
What2do is offline
PostPosted: Fri Apr 15, 2016 2:05 pm    Post subject: Re: Front door vent Reply with quote
Hope this helps.
http://i42.photobucket.com/albums/e308/mentalmick/Trukkvagon/DSCF0722.jpg
What2do
What2do is offline
PostPosted: Fri Apr 15, 2016 2:09 pm    Post subject: Re: Front door vent Reply with quote
And this.
http://forum.club8090.co.uk/viewtopic.php?f=38&t=150796&p=8131429&hilit=Whistle#p8131429
