JCockrill Samba Member
Joined: January 14, 2016 Posts: 33 Location: Charleston, SC
Posted: Mon Mar 07, 2016 10:43 am Post subject: Unknown Switch on Engine Case |
I could not find this in the Bentley or the Wilson book. I tried search Samba but didn't have any lucky probably because I don't know what it is so it makes keyword search very difficult.
Can anyone tell me what this switch/sensor/or other electrical device this is on the right side of the engine case facing the flywheel for a 1974 VW Type 1 stock sedan standard? (alternator version, fuel pump) Any help would be greatly appreciated.
Thank you!
Wide View
Close Up
View from flywheel side
[/img] _________________ '15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Mar 07, 2016 10:52 am Post subject: Re: Unknown Switch on Engine Case |
TDC sensor for VW diagnostic system used at the dealers.
I sure hope that's a before pic, all that RTV looks scary  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 07, 2016 11:05 am Post subject: Re: Unknown Switch on Engine Case |
Thank you! No one could figure it out.
The engine is still in pieces so haven't cleaned up the RTV. Still have to trim and clean it up. Is it detrimental to the build? _________________ '15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Mon Mar 07, 2016 11:08 am Post subject: Re: Unknown Switch on Engine Case |
| JCockrill wrote: |
The engine is still in pieces so haven't cleaned up the RTV. Still have to trim and clean it up. Is it detrimental to the build? |
If it looks like that on the outside just think what the inside looks like... oil pumps and passages don't like RTV sealant _________________ 66- Ghia
76-Beetle |
Posted: Mon Mar 07, 2016 11:10 am Post subject: Re: Unknown Switch on Engine Case |
The RTV was placed on the middle to outside edge of the case halves before putting it together. There are no cylinders or anything else attached so will take a light and look in to see how the interior is faring. Any RTV and I will pull it apart to reseal. _________________ '15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build |
Randy in Maine Samba Member
Posted: Mon Mar 07, 2016 12:15 pm Post subject: Re: Unknown Switch on Engine Case |
Just ordered some. Will be here end of the week. _________________ '15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Mon Mar 07, 2016 1:43 pm Post subject: Re: Unknown Switch on Engine Case |
| I love that color of rtv. |
Zundfolge1432  Samba Member
Posted: Mon Mar 07, 2016 4:23 pm Post subject: Re: Unknown Switch on Engine Case |
| Rtv room temperature vulcanizing. Looks like shit I'd use aviation permatex or pretty girl AKA gasgacinch. The hardcore here like curil or even hylamar or yamabond anything but rtv . Rtv doesn't completely squeeze out and it's been known to get into the oil supply and foul things up. |
ldj1002 Samba Member
Posted: Mon Mar 07, 2016 5:23 pm Post subject: Re: Unknown Switch on Engine Case |
I think you are lucky you didn't know what that switch was and showed a photo of it. Otherwise you would have put that in service with all that RTV.  |
Posted: Mon Mar 07, 2016 5:40 pm Post subject: Re: Unknown Switch on Engine Case |
| I'd run it as is what's the worst that could happen ? |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Tue Mar 08, 2016 5:22 am Post subject: Re: Unknown Switch on Engine Case |
| Zundfolge1432 wrote: |
I'm sure it would be fine, like just pounding a bad rod bearing back into place and putting the engine back together. |
Posted: Tue Mar 08, 2016 7:41 am Post subject: Re: Unknown Switch on Engine Case |
| I can see humor is wasted on you, chill out please. |
