AAZ Question- Injector Lines
Team WorldTour
Team WorldTour is offline
PostPosted: Tue Mar 29, 2016 9:19 pm    Post subject: AAZ Question- Injector Lines Reply with quote
Ok, so I am looking for new hard-lines. Mine leak. No matter how much I torque on them (to the point I am afraid I am about to tear threads...), they are still wet, and I am still dripping fuel.
Now, are they all the same length (like tuned exhaust)? That's why they are bent the way they are (again, like tuned exhaust)?
I have discovered a local shop that makes hydraulic lines.
Can I get my injector lines done with braided hoses?
(Because they make the hydraulic lines, I'm not afraid of the overpressure)
But, is it possible?
Otherwise, I'm stuck paying $170 for a new set.
http://www.ebay.de/itm/VW-Volkswagen-1-9D-1-9TD-Di...gPE9zJjZYw
I've had these guys do a few lines for me already.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Viva.Sabata
Viva.Sabata is offline
PostPosted: Tue Mar 29, 2016 9:33 pm    Post subject: Re: AAZ Question- Injector Lines Reply with quote
Yes it is possible and likely to cost more than a new set of hard lines. Braided lines also won't fit as well as hard lines so you might end up with wearing issues. Choose wisely!
Sabata
1987 Westy Full Camper, Peloquin 5-Speed 2wd
Team WorldTour
PostPosted: Tue Mar 29, 2016 9:39 pm    Post subject: Re: AAZ Question- Injector Lines Reply with quote
The hoses they offer (so far) have been reasonably priced.
I understand what you say about wear, but they will be secured (zip-ties are awesome!). However, that is one of my concerns!
I'm imagining they will be jumping about wildly from the injectors firing (so, yeah, they will be tied down!).
So, then NOT a good idea?
Click to view image
akyrie
akyrie is offline
PostPosted: Wed Mar 30, 2016 5:21 am    Post subject: Re: AAZ Question- Injector Lines Reply with quote
I suggest to buy the hardlines and make sure to use the rubber buffers between them. I can't imagine soft lines being a good replacement. There is a lot of rubbing and bumping going on down there. What's cheaper, buying the soft lines and then replacing them with hardlines, or just buying the hardlines?
Side note : Gosh, I hope my punctuation was up to thesamba snuff Laughing
Although I got a funny message from the Porsche guys, it read, "what a mighty ship that you must sail"
....has anyone else received that?
82 AHU DK, 1950's Puch-black
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Wed Mar 30, 2016 5:32 am    Post subject: Re: AAZ Question- Injector Lines Reply with quote
Buy the hardlines and the anti-rattle brackets and be done with it. No sense re-inventing the wheel. There's a reason that all manufacturers use hard lines on injection lines.
CHARLIE-DONT-SURF
CHARLIE-DONT-SURF is offline
PostPosted: Wed Mar 30, 2016 5:36 am    Post subject: Re: AAZ Question- Injector Lines Reply with quote
Pre loved set on Ebay UK for £15 ish. Seldom had a set leak except when some monkey had mullered them. Surely you cant be unlucky and have two duff sets?
https://www.facebook.com/Cow-County-Looms-1010851485971680/
