pyrOman Fire Master
Joined: July 21, 2003 Posts: 12546 Location: Over 2002 posts deleted!
Posted: Fri May 27, 2016 7:19 pm Post subject: 85.5 Stroker Pistons??? |
Alright, I did not bother to search!
I'm working with what I got, a stroker 78 crank in a clearanced case but stock bored. Are there anywhere some stroker 85.5 jugs or even 87s?????  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3842 Location: Eastern WA
Posted: Fri May 27, 2016 7:27 pm Post subject: Re: 85.5 Stroker Pistons??? |
gkeeton Beat me to it, they are on sale now too! _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Fri May 27, 2016 9:52 pm Post subject: Re: 85.5 Stroker Pistons??? |
The barrels need modification to clear the throws of the crank. |
modok Samba Member
Joined: October 30, 2009 Posts: 27662 Location: Colorado Springs
Posted: Fri May 27, 2016 9:56 pm Post subject: Re: 85.5 Stroker Pistons??? |
Being 34mm pin height, they are perfect for 80 stroke.
78 stroke, you will need longer rods or deck the case to get the deck height in normal limits. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7834 Location: Videbaek Denmark
Posted: Sat May 28, 2016 3:34 am Post subject: Re: 85.5 Stroker Pistons??? |
modok wrote: |
Yes. But personally I would rather stay at 78ish stroke and do what´s necessary to get correct deck height. 78/78,4 stroke and stock length rods is 1,75 RR. 5,5" rods are just shy of 1,8 RR both can work well. This setup can deliver very good overall power. anything from a stomp puller to a nice 130 hp daily driver. Going 80/82 mm stroke messes with something in the combo and makes it very difficult to get the tuning right. Dont ask me why, because I can´t explain it. It just is so.
T |
pyrOman Fire Master
Posted: Tue Sep 27, 2016 12:27 pm Post subject: Re: 85.5 Stroker Pistons??? |
Great feedback, thanks!
However, this concerns me:
Quote: |
STROKER Piston & Cylinder Set, 85.5mm x 82mm Cast, Type 1. These can be used on 78-84mm stroked cranked, and slip into 1300-1600cc cases. This cylinder set fits a 90mm case opening, and a 93.8mm head opening. These will withstand 7500 RPMs, and are tolerant of around 8psi boost!
Pin Height is 1.335". Wrist pins have a .155" wall thickness. Pistons utilize a 2mm, 2mm, 5mm ringset.
Already have a set of 94s I could use, but don't really want to open up the case. Are there any known stroker 85.5 piston/cylinder set ups already out there?  _________________ Some people are so busy being clever they don't have time enough to be wise. |
AlteWagen Troll
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15599 Location: Deep in the 405
Posted: Tue Sep 27, 2016 2:43 pm Post subject: Re: 85.5 Stroker Pistons??? |
pyrOman wrote: |
Already have a set of 94s I could use, but don't really want to open up the case. Are there any known stroker 85.5 piston/cylinder set ups already out there?  |
The 85.5 set ACN sell are for stock 1600 case. That is the outside diameter measurements of a stock 1600 jug. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
pyrOman Fire Master
Posted: Wed Sep 28, 2016 5:57 am Post subject: Re: 85.5 Stroker Pistons??? |
Kool!
I did get a quick response from them assuring me that the case does not need machining!
Been waiting for a while to not just find these but coming up with the extra $$ for them. Just ordered them yesterday!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
pyrOman Fire Master
Posted: Tue Oct 04, 2016 9:23 am Post subject: Re: 85.5 Stroker Pistons??? |
Got the jugs on the weekend!!!
Wow! Just 4 days! Anyway, was back from camping early enough to do a preliminary fit and did have to grind a tiny bit on the bottom of the cylinders to clear the rod nuts, less than a quarter of an inch. Needing to dig out the heads and pushrod tubes and the process of seals and torqueing it all taking longer than the time I had, decided to stop there. However, I expected the need to shim the cylinders but, though the pistons clear the crank, they have way too much deck height!?!
Did not have the rings installed when I measured the deck height but still, 0.095" seem like too much! Last thing I did was install the rings but did not have time to recheck the height. Will do that later this week and take some pix too.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
GTV Samba Member
Posted: Tue Oct 04, 2016 9:55 am Post subject: Re: 85.5 Stroker Pistons??? |
pyrOman wrote: |
Did not have the rings installed when I measured the deck height but still, 0.095" seem like too much! Last thing I did was install the rings but did not have time to recheck the height. Will do that later this week and take some pix too.  |
modok wrote: |
_________________ EMPI Power Rules! |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Tue Oct 04, 2016 12:39 pm Post subject: Re: 85.5 Stroker Pistons??? |
yes thats too much, thus the 5.5 rod or cut the case ...not my first thing to do, but some cases need it any way so it's a good way to go on those. or shorten the cylinders. also when you clearance for the rod nuts be sure they have enough rood for some missaliginement uppon assy....and going into other holes.. and the position of the crank(pushed back to the thrust bearing good), and the piston on the rod when checking..many maistakes are made clearancing....and spelling. |
pyrOman Fire Master
Posted: Mon Oct 17, 2016 6:45 am Post subject: Re: 85.5 Stroker Pistons??? |
Okay, thanks all for the feedback/info!
Finally did get it all together and fired up! Got the the stroker pistons and also went with the 5.5" rods which went to zero deck, 0.040" shims took care of that. Stock dual port heads pulled from a dead motor but looking almost like new, a "special bus grind" cam which I have yet to measure, and fed by a Holley (by Weber) progressive carb which was running fine on the Bug's 1600. Also running a 009 distributor on points. Had a hard time getting it to idle and has an intermittent "miss". Took off the carb, blew off all ports and jets, replaced the used plugs with another set of used plugs and at least got it to idle, tough rough. After some tweeking, installed it in the Bug.
It was too late for a test drive but drove it to work today and it ran well. Still with a bit of a miss and does need quite some time to warm up before idle sets. The bottom end was put together with used parts from my pile and of course the oil pressure drops after it warms up. Now, the reason I put this one together was as a spare motor to keep the Bug running while I rebuild its 1600. I do have another 76 or 78 crank which I may use on that rebuild if this set up works out.
Anyway, will prolly do a tune up, swap distributors, adjust, ect. to see if I can make it run/idle smoothly but so far so good.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Mon Oct 17, 2016 8:54 am Post subject: Re: 85.5 Stroker Pistons??? |
pyrOman wrote: |
a "special bus grind" cam which I have yet to measure |
It's the same as an "RV" cam from the 70's. Good thing it's not a 3/4 race cam. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
pyrOman Fire Master
Posted: Mon Oct 17, 2016 9:09 am Post subject: Re: 85.5 Stroker Pistons??? |
vwracerdave wrote: |
pyrOman wrote: |
It's the same as an "RV" cam from the 70's. Good thing it's not a 3/4 race cam. |
Got it from Bill May many moons ago. I threw it in an 1835 also put together with used parts, which of course was short lived as the case started coming apart. But it was a screamer!!! It would squeal the tall tires on the Plump Truck with ease! Mucho power!
I'll try to get this motor to run better, as in smooth. It's pretty much a "test bed". If it does perform as I think it should, I will build a similar one properly with new parts and such. As I said, I already have a brand new 76 or 78 crank. With these pistons and maybe a mild cam, it may be a better choice of engines for the Bug. Plus if it's torqy enough, it may double as a emergency replacement for the Dormy!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Mon Oct 17, 2016 9:12 am Post subject: Re: 85.5 Stroker Pistons??? |
fire it up for a few seconds(20) and turn it off then feal the header pipes carfuly to find the cool one ans that will tell you where to be looking for an issue. |
pyrOman Fire Master
Posted: Mon Oct 17, 2016 10:15 am Post subject: Re: 85.5 Stroker Pistons??? |
FWIW, I did check temps while on the test stand. Though there was difference between them at the pipes, the head temps just at the port exits were within 20 or so degrees from each other. Once I got it to idle and run for a while, I threw it into the Bug. That was pretty much all the time I had to deal with it last night and even with its issues it took me to work (13 miles) just fine with plenty of power, though I didn't "push it" all the way. Work in progress. At least it isn't leaking oil... yet!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Mon Oct 17, 2016 2:15 pm Post subject: Re: 85.5 Stroker Pistons??? |
look for vacume leeks...like dirty stripes on the carpet .there are a few things that can cause your issue. but I dont mess with the hollywebbler progressive stuff. |
pyrOman Fire Master
Posted: Mon Dec 05, 2016 7:56 am Post subject: Re: 85.5 Stroker Pistons??? |
Update: Been running the little stroker on the Bug and it does have great power! Having issues with idling when cold but it most likely has to do with the old carb. Aside from that, cruising at say 70-75 mph and stomping on the pedal, it jumps very quickly to 85!!! It likes it and so do I!!!
I have to take apart the Dormy's engine before Havafew in a couple of weeks. I think I should take this little stroker, put the Dellortos on it and install it in the Dormy just to see how it does!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
