Is this leak a canidate for Subaru conditioner?
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Sat Nov 19, 2016 10:21 am    Post subject: Is this leak a canidate for Subaru conditioner? Reply with quote
Feeling annoyed. Ive done maybe only a dozen or so head gasket jobs and have always followed bentley exactly. Just finished up a job on my latest van and it has already started leaking from the water jacket where it meets the engine, not the head side. Only put on 60 miles. Bentley makes no indication to use sealant on both sides of water jacket seal. Come to find out searching here, using sealant on both sides is proper. WTF Bentley! Anyways never have in the past and guess I always got lucky until now. Moving forward i will always use sealant on both sides of water jacket seal.
So now the Water jacket drips upon startup while cold outside but stops in a few minutes once engine warms. More annoying than emergency. So i first tried to retorque all the head bolts one at a time with new sealant. That slowed it down but did not stop the drips. So short of pulling the heads and re doing the job, is this a case for the subaru coolant conditioner? Ive never used this stuff before as Ive always been concerned about additives to our cooling systems. But ill try it as now that its cold out, I dont feel much like repeating the job. If yes, how many bottles? If no, is there another additive to try?
Thanks
Jason
Type17
Type17 is offline
PostPosted: Sat Nov 19, 2016 10:33 am    Post subject: Re: Is this leak a canidate for subaru conditioner? Reply with quote
You'll be even more annoyed when the your engine overheats due to a clogged radiator. Pull the head off and do it the right way. There are no shortcuts, sorry.
I don't check these forums daily and often loose track of threads and comments. Please PM me a reminder if you're waiting on a reply. Thanks!
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Sat Nov 19, 2016 10:41 am    Post subject: Re: Is this leak a canidate for subaru conditioner? Reply with quote
Which is why I have always been concerned about additives. However, seems like lots of members here use this stuff and no reports of clogging up the rad that I have read
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Nov 19, 2016 11:00 am    Post subject: Re: Is this leak a canidate for subaru conditioner? Reply with quote
Go for the Subaru additive. I am using it in a couple vans. I had that rubber head gasket drip coolant during cold nights. That was about 10 years ago in one of the vans.
Mark
levi
levi is offline
PostPosted: Sat Nov 19, 2016 11:32 am    Post subject: Re: Is this leak a canidate for subaru conditioner? Reply with quote
What I've read on here is that because of the large amount of coolant in our system 2 bottles is the amount to use.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sat Nov 19, 2016 12:24 pm    Post subject: Re: Is this leak a canidate for subaru conditioner? Reply with quote
Add 3 bottles.
Be sure to seal that head up well.
Along with the radiator, and both the front & rear heater cores.
3 bottles should be plenty to get it all.
The reason you see the blue goo mentioned often is a reminder of how lazy the vanagon folks are.
Just pour the goo, and run it.
Hope it's not real cold where you're driving.
Might get a little nippy inside of the van.
T.K.
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Nov 19, 2016 12:29 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
the anti leak stuff might be more appropriate for a well used motor to keep it going, but to fix a leak on a brand new rebuild??? if i was me and I am, id pull the motor apart and figure out why the recent seal install failed.
good luck either way
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Sat Nov 19, 2016 12:54 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
Im fairly certain the failure was due to me not using sealant on both sides of water jacket. Bentley makes no mention of this and in the past I have never used sealnt on both sides with good success, until now. Researching the forums last night I saw it repeated over and over about using sealant on both sides, mostly from Ben. Thats how I will approach the job for now on. Anyways at this point I got nothing to lose going the suby route as this van is my winter beater and sees only 8 miles of driving a day
levi
levi is offline
PostPosted: Sat Nov 19, 2016 1:10 pm    Post subject: Re: Is this leak a canidate for subaru conditioner? Reply with quote
Terry Kay wrote:
Add 3 bottles.....
3 bottles (and up) is only what's recommeded for leaky mouth syndrome.
I've used this stuff in the past and found zero evidence of any goo in the system after a tear down.
Not anywhere.
Terry Kay
Banned
PostPosted: Sat Nov 19, 2016 1:32 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
No, 3 bottles and up are recommended for severe oral orfice foaming.
The guy just got done doing the heads, and he forgot both sides of the seal, and for this, don't do the job right, just pour a perhaps temporary fix in a bottle into the entire cooling system?
I gotta say not only is the guy asking a little off, so are the guys prodding him to pour.
Nuts.
T.K.
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Sat Nov 19, 2016 1:49 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
Nuts.
I love you TK! You may not be a winner with the ladies but you're a winner with me!
levi
levi is offline
PostPosted: Sat Nov 19, 2016 2:16 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
I guess Subaru messed up then, considering they now are going to have to pay for all the damage caused to their own cars while under warranty, for following Subaru recommendations.
I'll bet Subaru neglected to do any testing, research, or analysis on their own product beforhand.
Maybe they were going to but t.k. was too busy to head up the research team, hanging out with Luscious Lydia and painting boats instead.
bluebus86
Banned
PostPosted: Sat Nov 19, 2016 2:38 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
nice photos in below link regarding leak stop. however we dont know how much was used, maybe it is a case of over use, but YIKES,
https://allwheeldriveauto.com/why-you-should-never-use-stop-leak-in-your-subaru/
ps on further examinatiin it looks like one of gelled coolant issue, didnt dexcool have the problem? who knows???
levi
levi is offline
PostPosted: Sat Nov 19, 2016 2:43 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
So, what does the product "stop leak" have to do with the subaru blue.
Terry Kay
Banned
PostPosted: Sat Nov 19, 2016 2:49 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
Go for Four.
WTF is wrong with you maniacs?
If it leaks, don't fix it, jam it full of iatmeal.
If it drips, forget even looking for the problem , pour some more blue goo.
If this was all a life or death situation, like being marooned in death valley or some other atmpit, yea-- pour away your troubles.
But nobody is in this kinda situation, so take the heads off & fix it right.
Bums--& real life hobo's, unbelievable.)
T.K.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sat Nov 19, 2016 2:52 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
@ candyman:
is it possible the leak is, in part, caused by unmatched cylinder heights? But then IF they are, the difference would be small and the "Right Stuff", or whatever, would compensate for that?
At very least i think this thread has spawned a new sig line for me. Wink
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Sat Nov 19, 2016 3:10 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
Terry Kay wrote:
Go for Four.
However, this is not life or death you big sack of sugar😘 This is on a winter beater rig that goes only 8 miles a day. Im quite happy using my aaa if it blows up
levi
levi is offline
PostPosted: Sat Nov 19, 2016 3:25 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
Terry Kay wrote:
If this was all a life or death situation, like being marooned in death valley or some other armpit
Hey, now don't be casting your aspersions on death valley, it's a beautiful place!
As for bums and real life hobo's, they can be interesting and enjoyable to hang out with, unlike bloviating buffoons.
bluebus86
Banned
PostPosted: Sat Nov 19, 2016 3:36 pm    Post subject: Re: Is this leak a canidate for Subaru conditioner? Reply with quote
bums and hobos stay away.
The lice, the TB, the stench, yuck!
death valley can be deadly if you dont bring shade and water. its called death valley for good reason.
is not portland full of bums and hobos? at least death valley has few of them, Ill concede that point.
Rolling Eyes Laughing Shocked Confused Rolling Eyes Crying or Very sad Rolling Eyes
