Beetles and Fires?
Page: Previous  1, 2, 3 ... 13, 14, 15
Helirich
Helirich is offline
PostPosted: Fri Sep 20, 2013 7:11 pm    Post subject: Reply with quote
Somewhere in this thread, I saw where someone recommended a fire extinguisher rated for burning metal. I went to Lowes and didn't see anything like that. Where do you get a small one like that?
1970VWGUY
1970VWGUY is offline
PostPosted: Sat Sep 21, 2013 5:32 pm    Post subject: Reply with quote
What about a big filter that bolts to something and wouldn't hang off the carb?
I just googled the MB clamps...they do look much neater than the ordinary hose clamps we all use..
1970VWGUY
PostPosted: Sat Sep 21, 2013 5:46 pm    Post subject: Reply with quote
http://www.ebay.com/itm/SBC-BBC-350-Chrome-Fuel-Fi...0799774435
http://www.kartek.com/Product/1078/FRAM-High-Performance-Fuel-Filter.aspx
1970VWGUY
PostPosted: Sat Sep 21, 2013 6:27 pm    Post subject: Reply with quote
Something nobody thought about....doesn't the new gasoline with ethanol eat rubber...ruin carbs...eat hoses....
http://www.cuda-challenger.com/cc/index.php?topic=84105.0
Looks like fuel line replacement should be a yearly event....
1970VWGUY
PostPosted: Sat Sep 21, 2013 6:32 pm    Post subject: Reply with quote
Know Your Fire Extinguisher ABCs
Fires are classified based on the type of fuel involved. Likewise, portable fire extinguishers are classified by the type of fires they are designed to extinguish. There are five basic classifications of fuel and extinguishers, and extinguishers are labeled with either letter-shaped or pictorial symbols that indicate what types of fires they are intended for.
Classifications of Fires and Extinguishers
more here
http://www.utexas.edu/safety/fire/extinguishers/abcs.html
1970VWGUY
PostPosted: Sat Sep 21, 2013 7:59 pm    Post subject: Reply with quote
this says the fuel line for a 70 bug is 3.5mm...so where do we find out what size hose we need?
http://www.carid.com/1970-volkswagen-beetle-fuel-delivery-parts/item-7842965.html
VolkzBitz Premium Member
VolkzBitz is offline
PostPosted: Fri Oct 11, 2013 3:11 am    Post subject: Reply with quote
I can install the screwed in barbed fitting.
http://volkzbitz.com
Quality VW Solex carburetor restoration
[email protected]
Der Vergaser Meister
Hyperspace
Hyperspace is offline
PostPosted: Fri Oct 11, 2013 3:28 am    Post subject: Reply with quote
Found another fire vector on my beetle when I installed the painted fuel tank. There is a braided vent hose that runs almost in parallel to the fuel inlet pipe.... right underneath this fuel gas filled braided line runs a fat cord of elecrical wires, mine had a burn in like RIGHT underneath the braided hose....
If you can't fix it with a hammer, it is an electrical fault.
Photo's http://www.thesamba.com/vw/forum/album_search.php?search_author=Hyperspace&show_results=summary
don't_bug_me
don't_bug_me is offline
PostPosted: Fri Oct 11, 2013 6:31 am    Post subject: Reply with quote
I can't believe it's 2013 and people are still burning up their vw's
70 Street Baja http://www.thesamba.com/vw/forum/viewtopic.php?t=566113
"Necessity is the mother of invention"
joseph928
joseph928 is offline
PostPosted: Mon Feb 17, 2014 7:40 pm    Post subject: fire extinguisher Reply with quote
Blue Bug Found a good use for my 2nd drink holder, my fire extinguisher. And no holes to drill, real easy to get out. Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
scottyrocks
scottyrocks is offline
PostPosted: Wed Dec 14, 2016 7:49 am    Post subject: Re: Beetles and Fires? Reply with quote
What a great thread. I'll be checking everything this weekend, especially that pass-through, most likely ordering new lines, purchasing a class B extinguisher, and mount it in the car.
I see no problem with using a grommet, as long as it is checked regularly.
The first step to preventing catastrophes, before even doing routine checks, is knowing what to look for.
scottyrocks
PostPosted: Sun Dec 18, 2016 2:47 pm    Post subject: Re: Beetles and Fires? Reply with quote
I bought a class B/C, 2.5 lb. unit at Ace yesterday. It's in the car behind the driver's seat.
I also checked the fuel lines in the engine bay. Everything looks new and properly fastened.
Mavans
Mavans is offline
PostPosted: Sun Dec 18, 2016 3:16 pm    Post subject: Reply with quote
Most metals won't really burn, the ones that do can't readily be put out by a fire extinguisher. I don't know if it's still the case, but the Navy used to push burning airplanes overboard as the magnesium could not be put out once it caught fire. Putting water on a metal fire can cause an explosion, using CO2 can actually feed the fire. They only go out when they are completely deprived of all oxygen or all burnable material.
EVfun Premium Member
EVfun is offline
PostPosted: Sun Dec 18, 2016 4:15 pm    Post subject: Re: Beetles and Fires? Reply with quote
Class D fires extinguisher is used for metal fires. They are not common or cheap.
They will not work on burning lithium batteries as those carry their own oxidizer. I mention this only because some of those are making their way into motorsports as high current light car batteries.
Wildthings wrote:
Mavans
Mavans is offline
PostPosted: Sun Dec 18, 2016 5:03 pm    Post subject: Re: Beetles and Fires? Reply with quote
True... a class D extinguisher can put out a metal fire if you can completely cut off all oxygen from the metal by smothering it with powder. Takes a large extinguisher for a very small amount of metal. Not something feesible for a car extinguisher. It's been many years since my fire fighting training, but I seem to remember you needed like a 5 to 1 ration of powder to metal (weight) to have a chance of putting it out.
MichaelRecycle
MichaelRecycle is offline
PostPosted: Tue Jun 22, 2021 7:15 am    Post subject: Re: Beetles and Fires? Reply with quote
Hi, all.
I'm new-- I hope I'm posting in the right place.
I recently bought a '74 Super Beetle. While out riding around with my son in the back, he noticed the metal bar that spans the base of the back seat was getting hot on the battery side. Is this normal? Is the heat coming from the battery?
I've included photos here of the battery's current state; I'm hoping someone here can offer some advice.
Thank you!
birddog1
birddog1 is offline
PostPosted: Tue Jun 22, 2021 11:20 am    Post subject: Re: Beetles and Fires? Reply with quote
MichaelRecycle wrote:
Hi, all.
Thank you!
I'll take an educated guess at what happened. The stock battery group for a VW comes with a plastic shield over the positive terminal to prevent the spring in the bottom seat from coming into contact with it. That can easily happen with additional weight in the back seat and our now tired saggy seat springs . So people without that shield or even with it for extra protection will put a rubber mat/ piece of wood/etc over the battery to prevent the seat spring from coming into contact with the battery terminal.
I can't tell if it's just the light in the pic but that negative/ground strap looks pretty wasted. I would replace it.
MichaelRecycle
PostPosted: Tue Jun 22, 2021 11:58 am    Post subject: Re: Beetles and Fires? Reply with quote
Thank you.
I bought some terminal covers (and a fire extinguisher!) and I've got a rubber mat I'm going to put down, too.
Also, you're right-- that strap is toast. Thanks so much for the tip.
hulbyw
hulbyw is offline
PostPosted: Wed Jun 23, 2021 12:38 am    Post subject: Re: Beetles and Fires? Reply with quote
From the photos it looks like it may be an incorrect battery for a Beetle. I would have thought it should have a battery with recessed terminals with insulation over the positive. If it were mine I would also re route or lengthen the yellow/red trace earth wire so it doesn't stretch across the positive terminal as well.
Cheers
Q-Dog
Q-Dog is offline
PostPosted: Wed Jun 23, 2021 2:20 am    Post subject: Re: Beetles and Fires? Reply with quote
The original group 42 battery not only has recessed terminals, it is also one of the shortest automotive starter batteries available.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Page 15 of 15
