Lee Hedges Samba Member
Joined: November 09, 2000 Posts: 813 Location: San Diego
Posted: Tue Jan 03, 2017 4:09 pm Post subject: Rear Axle Serial Number Location? |
Where do I find the rear axle serial number on a Type 3?
I'm trying to discover whether the rear subframe that came with my early-62 T34 is original to the car or from something else.
The VIN # is #0 001 200 and the front axle serial number is only partially visible (XX24), as the rubber snubbers were removed by a previous owner.
For comparison sake the VIN # of my other T34 is #0 001 776 and the front beam serial number is 2157. I'd really like to check both of my T34 rear axle serial numbers to set some concrete numbers.
BTW, the Type 3 chassis # chart does not correspond to the known numbers on my Ruby T34. The chart says end of Sep 61 should be VIN #0 002 051, end of Oct 61 should be #0 003 991, & end of Nov 61 should be #0 007 184. So you can see that by this guide my #0 001 776 would have been built in mid-Sep 61 but the birth certificate says it was born 14 Nov 61. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71502 Location: Phoenix 602
Posted: Tue Jan 03, 2017 4:52 pm Post subject: Re: Rear Axle Serial Number Location? |
Lee Hedges wrote: |
I wonder if that is because of Karmann production times. _________________ How to Post Photos
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35883 Location: Conejo Valley, CA
Posted: Tue Jan 03, 2017 5:08 pm Post subject: Re: Rear Axle Serial Number Location? |
BTW, late front axle serial numbers were inked on the out surface of the right shock mount tower. I've never noticed a indent-stamped number.
So are you looking for a subframe serial number, or the transaxle serial number? |
Posted: Tue Jan 03, 2017 5:17 pm Post subject: Re: Rear Axle Serial Number Location? |
Looking for the location of the rear axle number listed in the Chassis # chart. Would that have been on the subframe? |
KTPhil  Samba Member
Posted: Tue Jan 03, 2017 5:52 pm Post subject: Re: Rear Axle Serial Number Location? |
Lee, I always assumed the Samba tables were the transaxle numbers, but I have never pulled out the table and crawled underneath to see and confirm.
I noticed the number series is the same for Type 3 as for Type 34, but that doesn't answer your question. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4507 Location: Illinois
Posted: Tue Jan 03, 2017 8:54 pm Post subject: Re: Rear Axle Serial Number Location? |
IIRC, there are numbers under where the front transmission mount attaches to the subframe - I used to have a subframe that was not attached to a car but it's in California now.
I searched through my photos and didn't seem to take any of this area and I think it'd be a right bitch to find installed in the car. |
65Nsqback Samba Member
Joined: September 17, 2004 Posts: 1256 Location: Grantsville UT
Posted: Tue Jan 03, 2017 9:40 pm Post subject: Re: Rear Axle Serial Number Location? |
The number will be on the right side of the transmission theres a flat area (sometimes covered in layers of gear oil) should look like this
This is the transmission serial number as far as I know there are no numbers on the actual subframe
Hope this helps _________________ Wow look at that THAT'S A "SHOW CAR"!!
you can't be something your not...be your self by your self stay away from me
__________________________________
I'm Trying to help you.......but you don't hear me... |
Posted: Tue Jan 03, 2017 9:52 pm Post subject: Re: Rear Axle Serial Number Location? |
65Nsqback wrote: |
Hope this helps |
Kris - on the subframe that you now have - check out the area around where the two studs come out of the middle for the front trans mount. I recall seeing numbers... |
Posted: Tue Jan 03, 2017 9:57 pm Post subject: Re: Rear Axle Serial Number Location? |
ataraxia wrote: |
65Nsqback wrote: |
Hope this helps |
I'll check it out
But IIRC in the passed I have never been able to find numbers on any of my subframes have a few that are out of cars now I don't see any numbers on them..but I'll double check _________________ Wow look at that THAT'S A "SHOW CAR"!!
Posted: Tue Jan 03, 2017 10:15 pm Post subject: Re: Rear Axle Serial Number Location? |
Ok so on the three subframes I have out (not under cars)one has no numbers and the other two have what I would call "casting numbers" on the center mount and yes your right there on the top side of the subframe just behind the mount _________________ Wow look at that THAT'S A "SHOW CAR"!!
Posted: Tue Jan 03, 2017 10:18 pm Post subject: Re: Rear Axle Serial Number Location? |
Got pics?
Posted: Tue Jan 03, 2017 10:28 pm Post subject: Re: Rear Axle Serial Number Location? |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23364 Location: Kimball, Mi
Posted: Tue Jan 03, 2017 11:01 pm Post subject: Re: Rear Axle Serial Number Location? |
KTPhil wrote: |
BTW, late front axle serial numbers were inked on the out surface of the right shock mount tower. I've never noticed a indent-stamped number. |
Phil, the early cars were stamped thru at least 64, as my T-34 still had it's original front beam in place. I never knew there was a rear stamped number, so I didn't go looking for it.
I have pics of the front stamping in my build thread and in my gallery. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
