Sodo Samba Member
Joined: July 06, 2007 Posts: 10866 Location: Western WA
Posted: Thu Jan 19, 2017 3:43 pm Post subject: Syncro Lower Ball joint puller (on-car) Home made tool |
I made another tool. It pushes the Lower Ball Joint out (LBJ) of a Syncro with the cast arms.
I don't know if it will fit the "other" style of Syncro LCA.
I don't know if it will fit the 2WD. EDIT: Does NOT fit 2WD
Spray area with penetrating oil prior. Several days prior is best. Pry off this circlip & don't lose it. New LBJs do not include this clip, and I hear they are NLA.
Ready to push. Tool fits on the (cast version, 1990 Syncro) Lower Control Arm (LCA) with the arm installed on the van. I don't know if it fits the stamped/welded version. I don't know if it fits the 2wd LCA.
View from the underside (cast LCA, 1990).
It's made from a 2 1/2" schedule40 pipe.
Slit, and spread about 0.4" by poundijng a chisel into the gap. It results in an OD appx 3 1/16".
A "plug" welded into the slit holds it apart at the 3 1/16" diameter.
There are some cutaways to clear the ribs in the underside of the cast Syncro Lower Control Arm (LCA).
"Standard Tool" is part of this Harbor Freight Bearing puller set.
======= INSTALLING THE NEW BALL JOINT ========
A 3 1/2" section of 2 inch electrical conduit.
Tightening the (greased) nuts pushing the conduit down, pressing the balljoint into its bore
Ready to go! Grease zerk modification is described in THIS THREAD.
Incidentally, it also fits in this location as a bushing to press the Syncro Front Wheel bearing out. You will need other components (all-thread rod & spacers etc) to push the bearing out but this is your bushing.
Anyway that's how it can be done if a guy has a shop and can build tools. Here's another homemade Syncro tool: Syncro Tool - Front Axle press (trail tool)
There are lots of ways to build this tool, and if you see pics of one way it helps to understand. And then you can decide how to do it 'your way'. Hope it helps. _________________
....KTMs, GasGas, SPOT mtb
Pcforno Samba Member
Joined: October 14, 2014 Posts: 607 Location: Santa Fe, nm
Posted: Thu Jan 19, 2017 7:28 pm Post subject: Re: Syncro Lower Ball joint puller (on-car) Home made tool |
| Sodo- the LBJ "safety" clips are available through chris at T3 techniques. Just installed them on mine and they fit perfect |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Thu Jan 19, 2017 7:45 pm Post subject: Re: Syncro Lower Ball joint puller (on-car) Home made tool |
Wow, you are fast becoming the ultimate "guerrilla tool maker" for the Syncro!!! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17323 Location: Brookeville, MD
Sodo Samba Member
Posted: Fri Jan 20, 2017 12:16 pm Post subject: Re: Syncro Lower Ball joint puller (on-car) Home made tool |
Thanks Doug, Dave. But you guys are easy, (....tool nuts.)  _________________
....KTMs, GasGas, SPOT mtb |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19104 Location: Retired South Florida
Posted: Fri Jan 20, 2017 1:07 pm Post subject: Re: Syncro Lower Ball joint puller (on-car) Home made tool |
| Innovative tool. For information, I am pretty sure the lower ball joint is pressed into the spindle housing of the 2WD, so I don't believe your tool will work with 2 WD vanagons. Thanks for sharing. |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Sodo Samba Member
Posted: Sun Jan 22, 2017 12:39 pm Post subject: Re: Syncro Lower Ball joint puller (on-car) Home made tool |
Thanks Kevin. I think of other Samba members faced with this job, and they wonder about what tool might work in lieu of a hydraulic press. Or doing it "on-van" seems like a valid desire. Seeing a tool that works helps to understand what needs to be done.
I have a hydraulic press, I'm just doing this for sport - to make something that "seems useful", like a "prepper". The fact that it's only fits the cast arm Syncro takes it back a notch dangit. I'm procrastinating deciding which shocks to buy so it serves as a distraction. Shocks are standing in the way of putting this van back together. _________________
