Up in smoke... Bus fires... don't let it happen to you! FAQ
Page: Previous  1, 2, 3 ... , 31, 32, 33  Next
aerosurfer
aerosurfer is offline
PostPosted: Wed Mar 22, 2017 8:12 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
You are fine, if not overthinking it a bit.
As long as you have proper rated hose it will work anywhere in the system a metal pipe was. The clip on the underside of the bus the metal pipe was in is different than the one used for rubber line in that spot, but nothing a zip tie can't fix to support to help support that long piece.
Also make sure you are using a proper FI filter, which you will need that small section of larger diameter hose between the filter and pump
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
BayCreamPuff
BayCreamPuff is offline
PostPosted: Thu Mar 23, 2017 5:21 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
I use a rubber fuel line in place of the metal return line and it works fine. The length of the feed line feels a little long for a rubber hose in my opinion.
The metal line should be easy enough to replace. Summit Racing caries a wide variety of fuel rates stainless steel lines. It's a low pressure area so no need to add any flares to the ends. The original has a single 45 degree bend at the tank end if I remember correctly. You may be able to get away with a longer length of rubber hose on that side if you want to avoid bending it.
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
mainstreetprod
mainstreetprod is offline
PostPosted: Thu Mar 23, 2017 6:32 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
I'm in the process of replacing all lines. My steel lines are all good, so I'm re using them. Just purchased a fuel filter yesterday and made sure to get a metal rather than plastic one, but was not aware of FI specific filters. What are the issues with using a conventional filter? Seems to me if it doesn't restrict fuel flow and pressure is good it will be fine. I'm putting it before the pump.
busdaddy
busdaddy is offline
PostPosted: Thu Mar 23, 2017 8:23 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
The problem with a carb style filter is surface area, FI constantly circulates the fuel from the tank, many gallons per minute, carb systems only flow a few ounces in the same time. It may work OK when new, but once it starts catching debris it may slow the flow enough to cause pump overheating or cavitation.
Go with the square plastic VW filter, they have been proven to work well in millions of vehicles over many years, and they already have the correctly sized fittings to connect to the tank outlet and pump.
Слава Україні!
cv66seabear
cv66seabear is offline
PostPosted: Tue Apr 04, 2017 7:14 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Pretty cool fire suppression here:
https://youtu.be/Kswau1mGBE8
It's called BlazeCut. Just zip tie it onto the top of the engine bay and when the plastic hits temperature it melts and the suppressant is sprayed under pressure extinguishing the fire.
Seems to work quite well.
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
mainstreetprod
PostPosted: Fri Apr 14, 2017 6:36 am    Post subject: Reply with quote
Traveling Writer wrote:
Maybe that these cars are more prone to burning is also partly simply because of the sheer amount of tinkering (both unskilled and not) that has gotten done on them over their 30+ years on the road. I don't think Datsun Sunnys or Ford Broncos of similar vintages get half the mucking around that our busses have gotten over the years by all their (often teenage or at least very young) POs. Just a thought!
You nailed it! I just went through the fuel line replacement process, and am 100% sure most of the lines I was replacing were original. In my case, that means they lasted 37 years without failing! The ones that had been replaced were generic (non FI) fuel line. If owners and mechanics used the proper FI lines and clamps, replaced them at 10 year intervals and made sure they couldn't rub on tin, I think 99% of these fires would be eliminated. In my case I eliminated my cold start valve as another possible source because I will seldom drive in cold weather. As a final measure I added a Blazecut.
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Apr 14, 2017 6:43 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Just so you will know...the cold start valve does not care if it is winter or summer. It is looking for when the engine is cold (via the thermotime switch), not the weather.
popuppopdog
popuppopdog is offline
PostPosted: Sun Dec 10, 2017 12:37 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Just an FYI if your fuel consumption increases beware. Don't just start putting in more fuel without checking the entire fuel system. 13 years ago I ran out of gas after filling up in Fresno and ran out in Bakersfield , 110 miles, I was 10 miles outside of Bakersfield. All I had was a gallon of Coleman fuel, what do you know it got me there, thanks Coleman and VW. Oh by the way 10 pm at night with 3 small kids and two puppies on our way to Mexico, the guns at the border I will tell about later. 13 years later I have finally started to rebuild my girl and found this....hmmm... thinking I was leaking gas all over town. I am probably changing most of the fuel lines to Kunifer 10, copper nickel alloy used for both brake and fuel, etc etc. another post.
John Ghia
John Ghia is offline
PostPosted: Fri Jan 05, 2018 6:40 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
BUS BOYZ
KentABQ Premium Member
KentABQ is offline
PostPosted: Fri Jan 05, 2018 6:46 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
As a by-stander, that hurts to see it. I can only imagine the pain the owner is feeling while seeing the destruction. My heart goes out to him/her.
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
TomWesty
TomWesty is offline
PostPosted: Fri Jan 05, 2018 7:09 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Man that’s sad....
aerosurfer
PostPosted: Fri Jan 05, 2018 7:12 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Bummer indeed....
Any location info or other details about it? Yours?
GEEBEE
GEEBEE is offline
PostPosted: Sat Sep 08, 2018 7:12 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
I will be mfg flurosilicone 7 mm and I will include correct lined clamps
There will be black fire sleeve to slide on and two pieces of heat shrink to secure the sleeve in placeand keeps the sleeve from wicking.
The fire sleeve is aerospace spec
2500 burn test for 15 minutes
I will include his with the engine breather kit
The engine breather hoses are now flurosilicone ( fuel and oil resistant )
Gee-Bee Racing
85 % of my work is aircraft
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
dstimm
dstimm is offline
PostPosted: Sat Sep 08, 2018 8:36 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
I am very excited for mine to come!
1979 Sage Green California Westy.
KentABQ is offline
PostPosted: Sat Sep 08, 2018 9:10 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
I got to see GEEBEE's shop when I picked up my new S-boot. It's a great facility, and Guy is either a genius or very close to it, because I didn't understand about half of what he talked about. And I worked in aircraft maintenance for 15 years. I even knew what a Geebee was, and saw one fly once at a Yakima air show.
If GEEBEE goes into making 7mm fuel hoses, they are bound to be good.
-Kent-
---WildIdea
SGKent Premium Member
SGKent is offline
PostPosted: Sat Sep 08, 2018 10:04 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Does GEEBEE own and/or fly a GEEBEE? As I recall they were the speed racers of the mid-1930's. I've wondered about this because of his business name for sometime.
Xevin Premium Member
Xevin is offline
PostPosted: Sat Sep 08, 2018 10:20 am    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Yes Steve. He does.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=87156
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
ivwshane
ivwshane is offline
PostPosted: Sat Sep 08, 2018 5:14 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Gee-Bee Racing
For those who have purchased all your bus products so far, like me, will they be able to purchase your new stuff only?
For those that aren't aware, gee-bee makes quality stuff! If you care more about quality and longevity over originality, there isn't anything out there that is better, imo.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
TomWesty
TomWesty is offline
PostPosted: Sat Sep 08, 2018 6:08 pm    Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ Reply with quote
Xevin wrote:
Yes Steve. He does.
Nah, I saw a Beechcraft not a GeeBee.
GEEBEE
GEEBEE is offline
PostPosted: Sun Sep 09, 2018 2:35 pm    Post subject: 7mm fUEL LINE Reply with quote
If you want a special shape, I will mfg a steel mandrell and pre-shape it ?
Or
please advise me the length you want and I will send that ..
i WILL INCLUDE FIRESLEEVE AND IT WILL BE MATTE BLACK FABRIC FINISH.
[email protected]
I mfg all the vanagon and Sl300 Gull wing hoses and seals
GB
GEE-BEE RACING
GEE-BEE AERO PRODUCTS LLC
I ALSO REPRODUCE GASKETS USING ONLY SILICONE WITH FIBERGLASS, WE STOCK FIVE DIFFERENT THICKNESS
Page 32 of 33
